Gallons in the tank when needle at 1/4 line.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by David K, Nov 17, 2010.
  1. Apr 13, 2011 at 7:21 PM
    #41
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Never saw running out, but very true and good points above. I tested the truck only a few times when new so I would know worse case. As a rule, I usually fill up and recommend to re fill when you reach a 1/4 tank or so, way before the light comes on. ;)
  2. Apr 15, 2011 at 9:58 PM
    #42
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Next project I am doing... is taking photos of my gas gauge as it drops showing the position for each gallon... I am using 16 mpg as the refrence point... as that is pretty consistant with my around town driving on this tank.
    So, at 0 and 16 miles and, the needle is above the Full line (0 & 1 gallon down). At 32 miles (2 gallons), just below the Full line, at 48 miles (3 gallons) about 1/3 down from full to 3/4 line... etc.
    I will be on the 3/4 line at 80 miles if I maintain 16 mpg... as that is 5 gallons down.
    I will start a new thread when I have all photos... to the 1/4 line, e light or e line perhaps.
  3. Apr 15, 2011 at 10:17 PM
    #43
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    anybody has a tylenol ??? damn I hate math
    1st thing that came to my mind was:
    If little David has a full tank
    and we take 3/4
    what's left for little David ???
    Thanks for the info though.
  4. Apr 17, 2011 at 4:09 AM
    #44
    RogerRZ
    RogerRZ Well-Known Member
    New Brunswick, Canada
    White '14 DCLB TRD Sport
    Yesterday, I fan mine exactly 50 miles after the light came on, and put 19.8 gallons (75.00 liters) in it. I got 391 miles out on this tank, with about 75% flat two lane driving, cruise control set to 62mph. 19.73mpg. Load range E tires, stock size. I'm tickled pink, as my old Silverado, in similar driving would give me just under 13mpg. At 4000 miles per month, this is a difference of about $500 per month. Cripes, it almost makes the payment...
  5. Mar 13, 2012 at 5:14 PM
    #45
    David K
    Since we have found that the gauge is fairly constant with our trucks...
    Full tank =21 gal
    3/4 line = 16 gal (down 5)
    1/2 line = 12 gal (down 9)
    1/4 line = 8 gal (down 13)
    Light On = 4 gal (down 17)
    E line = 3 gal (down 18)
    If you zero the trip odometer when you FILL the tank, you can see your mileage as you drive...
    FULL = 0 mile on odometer
    3/4 line @ 80 miles (on odo.)= 16 mpg, @ 85 = 17 mpg, @ 90 = 18 mpg
    1/2 line @ 144 miles = 16 mpg, @ 153 = 17 mpg, @ 162 = 18 mpg
    1/4 line @ 208 miles = 16 mpg, @ 221 = 17 mpg, @ 234 = 18 mpg
    Light On@ 272 miles = 16 mpg, @ 289 = 17 mpg, @ 306 = 18 mpg
    E line @ 288 miles = 16 mpg, @ 306 = 17 mpg, @ 324 = 18 mpg
    Run the figures for the normal mileage range your Tacoma gets, mine has had a range that falls between 14.5 mpg and 19.5 mpg, with 16.5 mpg being the average daily driving. If I am mostly highway, it goes over 17 mpg with 19.2 my all time highest.
  6. Mar 13, 2012 at 5:38 PM
    #46
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    FWIW, these numbers don't exactly match my personal experience. As I mentioned in an earlier post, when my needle reaches 1/2 full, whatever the trip reads is 10x my approximate mpg. And that's after I add the 8% difference in odo reading between my 33" Duratracs and the 30" BFG Rugged Trails that came stock on my truck (which is what my speedo/odo are ostensibly calibrated for). So something must vary from truck to truck...?
    So as an example, if my trip reads 150 miles at the 1/2 mark, I add 8% for the tire size difference = 162 miles, and I usually end up at about 16 mpg by the time I refuel.
  7. Aug 16, 2012 at 9:29 AM
    #47
    David K
    Interesting...
  8. Aug 16, 2012 at 9:11 PM
    #48
    Techy
    Techy Well-Known Member
    Montrose, CO
    06 trd off road dbl cab
    Good info!
    Now I don't need to figure out how much is left when I am on E. :)
  9. Sep 16, 2012 at 9:25 AM
    #49
    David K
    Full tank =21 gal
    Thank you... and it is consistently so as I continue to monitor my fuel gauge and record gallons at fill ups... the figures are always withing 1/2 gallon.
    Now, you probably shouldn't go down to E or lower, on purpose... but when your light comes on, try and get to a station ASAP and top it off (if you have a roll of money and can afford to)... 17 gallons (+/- 0.5) should go in when the light comes on... meaning you have 4 gallons still in the 21 gallon tank. The needle is over the E line after one more gallon has been used... for me, that's about 16 miles later around town driving.
  10. Sep 16, 2012 at 11:21 AM
    #50
    JimBCa
    JimBCa Well-Known Member
    Jim
    Bay Area California
    2012 TRD Off Road
    Build Duratrac 265/75R16 Load rated E BAMF Rock Sliders, Pelfreybilt Front bumper and skid plates (3) Pro Runner front and rear shocks,Add-A-Leaf springs ATO (Armor Tech Offroad) hilift mounts, Famous Fabrication cb antenna/flag mount CoverKing Tactical seat covers, Flyzeye dash-light ARE Shell, backup light mod SumoSprings and Stops
    Almost exactly what I got while driving north from bay area to Portland as I approach 2000 miles on it.
    Thank you for a most informative thread covering this subject. I am finding this forum to be one of the best special subject ones I have joined over the years.
  11. Sep 16, 2012 at 11:24 AM
    #51
    Atreyus
    Atreyus WRATH OF ATREYU
    William
    San Gabriel, CA
    2010 Prerunner SR5 TRD SPORT
    5k Headlights HID's DDM, 3k fog HID's DDM, Interior LEDs, License plate LED, Tailgate mod
    If this is correct I've been getting 20.5-21.5 mpg woot!
  12. Sep 16, 2012 at 11:34 AM
    #52
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
  13. Sep 19, 2012 at 9:22 AM
    #53
    David K
    For grins, I wanted to check my mileage on mostly highway driving yesterday. I had to drive to El Cajon, about 94 miles round trip, filled up with Costco gas ($3.97/ gal) then topped it when I got back to Oceanside... 90-95% freeway driving, and mostly not over 70 mph (2000 RPM) with just some rare bits over.
    The gauge had just reached the 3/4 tank line... and I filled it with 5.05 gallons which gave me 18.6 mpg. So, the gauge points continue to be correct as they were checked over a year ago for measuring how much is in the tank.
    FULL TANK: 21 GAL
    3/4 LINE: 16 GAL (down 5)
    1/2 LINE: 12 GAL (down 9)
    1/4 LINE: 8 GAL (down 13)
    LIGHT ON: 4 GAL (down17)
    E LINE: 3 GAL (down 18)
  14. Sep 19, 2012 at 2:59 PM
    #54
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    I find the light to be very consistent as well.
    It's usually close to:
    330 miles = 21.x mpg
    360 = 22.x
    380 = 23.x
    400 = 24.x
    My gauge will gradually fall to within 1/16" of E, stay there for 20 miles, pop the light and within 2 miles of that drop to just left of E, even though there's still 4 gallons in there.
  15. Oct 7, 2012 at 11:19 AM
    #55
    David K
    Light came on, topped tank with 16.7 gallons (which is consistent with my 17 +/- 0.5 gal. findings).. Only this time the cost of gas was $4.75 a gallon!
