Game Changing LCAs (BTFFabrication)
Discussion in 'Suspension' started by ZebraScissors, May 20, 2022.
  1. Apr 26, 2024 at 7:47 AM
    #241
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    XPOTRPR likes this.
  2. Apr 26, 2024 at 7:52 AM
    #242
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    I tried those 333 Fab cams and maybe the two alignment shops I went to just didn't try hard enough, but no one was able to get the alignment to an acceptable place. I ended up going with the Bison octagonal cams and then got a decent alignment first try.
    On that note if someone wants to buy mine and give them a try I'll sell 'em relatively cheap.
    3JOH22A[QUOTED] likes this.
  3. Apr 26, 2024 at 7:55 AM
    #243
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    333 and Poly Performance have fewer settings than Bison. However, the Bison cams have too much slop from folks in my off-road club who tried them, so your steering wheel still goes off-center after wheeling.
    XPOTRPR and BabyBilly[QUOTED] like this.
  4. Apr 26, 2024 at 7:57 AM
    #244
    BabyBilly
    Billy
    2020 TRD
    They had slop with cam gussets welded in? I've been offroad a bit since I got that alignment but nothing crazy. They seem pretty damn tight to me. Maybe something to do with the gusset install?
  5. Apr 26, 2024 at 8:45 AM
    #245
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    FWIW.. I had the Bisons prior to the Poly Taco Tabs. They in fact had a sloppy fit. I didn't even run them once seeing the fitment. The Taco Tabs have been solid and are the best option imo (for 2nd gens anyways, thanks for pointing that out @3JOH22A ).
    They are also really for people that don't care that much about perfect alignment specs. They are based off maximum and minimum numbers on modified Tacomas.. so most alignment shops will see that they are "out of spec" but that's for a stock Tacoma. Poly has the caster/camber preset based off what works for modified/lifted Tacomas. They are truly meant for gaining max clearance and not having to mess with alignments. The only thing I have checked is toe.. and even then.. I have gotten it damn close on my own in the garage.
    Long story short.. if you're chasing alignment numbers or are worried about it.. I'd say don't get them.. or.. maybe get the Bisons since they have more options but just won't hold up to wheeling. But again.. if you're wheeling hard enough to knock them out.. you shouldn't be caring about alignment numbers. So it's just use and personal expectations to determine what works best.
    BabyBilly and 3JOH22A like this.
  6. Apr 26, 2024 at 9:04 AM
    #246
    BabyBilly
    Billy
    2020 TRD
    Both shops knew I wasn't looking for "in spec" alignment numbers. Anyhow I've still got the 333 kit so if the Bison wind up being a bust I can always switch back over and try again.
  7. Sep 20, 2024 at 7:17 PM
    #247
    Dvst8r1K
    Dvst8r1K Night-Taco
    Greg
    2nd gen Black Tacoma SS 4.0l 4-dr 4x4
    1" Toytec body-lift, K&N filter, coolant by-pass, mesh cotton screen delete, TTBS, WeatherTech in channel visors, 2.5" Rancho full suspension kit, Oil Catch Can, Toyo 285/70 A/T-2's, 21.5" light bar in grill, blacked-out grill, de-badged entire truck; and again, more to come.....
    Back to the lower control arms; any group buys for this fall??
    I'm about done with mods, minus these lowers...
    For those who have these already installed, let's hear your reviews.... Thanks!!!
  8. Sep 24, 2024 at 1:57 PM
    #248
    Jseda845
    Jseda845 Well-Known Member
    845 NY
    2019 TRD OR
    Dobinson's MRR coils, Deaver Stage 3 leafs, 295/70/17 Yokohama Geolander MT, ATHFab front & rear bumpers, DRT CMR, WarFab sliders, Archive Garage U-Bolt flip kit, SPC UCA (soon to be swapped)
    Haven’t seen too many people running them or at least not many reviews. Considering them but not sure about towing without the swaybar
  9. Sep 24, 2024 at 2:37 PM
    #249
    Dvst8r1K
    Dvst8r1K Night-Taco
    Greg
    Are you saying these will require eliminating the sway bar??
  10. Sep 24, 2024 at 2:44 PM
    #250
    Charger92
    Charger92 Built for pure function!
    British Columbia Canada
    2007 Tacoma double cab long box
    Wondering why eliminating the sway bar is needed?????
  11. Sep 24, 2024 at 2:52 PM
    #251
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    This makes no sense. The swaybar attaches to the spindle, not the LCA.
  12. Sep 24, 2024 at 2:58 PM
    #252
    Dvst8r1K
    Dvst8r1K Night-Taco
    Greg
    Dunno; but until the answer is revealed, I'll look at Archive, Rago, or the other company for shackle hangers..... 2 b continued...
  13. Sep 24, 2024 at 3:06 PM
    #253
    Jseda845
    845 NY
    2019 TRD OR
    I must’ve misread. My apologies boys
  14. Sep 24, 2024 at 3:12 PM
    #254
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    This thread is for Lower Control Arms.. not hammer hangers.
    As far as reviews of these LCAs goes.. I have posted up several times about them in here. Have been running them for a couple years now with zero issues. Great upgrade. Solid product and quality.
    Also, you dont have to remove your sway bar for these.. LCAs have zero effect on sway bar mounting.
    BabyBilly, SUMOTNK and Jseda845 like this.
  15. Sep 24, 2024 at 4:51 PM
    #255
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Any chance someone knows of a company that'll sell a UCA that's well matched to these LCAs? I'm looking for a UCA that'll be stronger and allow the extra droop of an extended travel coilover, but one without any caster correction because the LCA will handle that. Preferably something ball jointed like the BTF LCA
    JFriday1 likes this.
  16. Sep 24, 2024 at 5:05 PM
    #256
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    Spc is the only one that im aware of that can do the 0 or .25 or 1 degree of caster so that you can max clearence for bigger tires. And clear the coil better at full droop
  17. Sep 24, 2024 at 5:49 PM
    #257
    Dvst8r1K
    Dvst8r1K Night-Taco
    Greg
    10/4. You can still run your sway bar with these lca's. Just got confirmation from Derik Thoma over at DRTfab. Cool dude.
    I'll order these arms at a later date and I'll repost from there.
    Thanks again TW...& DRT
    drtfabrication likes this.
  18. Sep 24, 2024 at 8:13 PM
    #258
    drtfabrication
    drtfabrication Well-Known Member
    Derik
    No problem !
  19. Sep 29, 2024 at 5:52 AM
    #259
    Jseda845
    845 NY
    2019 TRD OR
    What are some alignment/caster specs you guys are getting with these?
  20. Sep 29, 2024 at 7:20 AM
    #260
    drtfabrication
    Derik
    I have my truck set up at 6.8° caster if I remember correctly.
