Gaming PC Build!!!
Discussion in 'Technology' started by Forster46, Aug 5, 2013.
  1. Aug 14, 2013 at 9:54 PM
    #161
    2wheelnut
    2wheelnut Well-Known Member
    Angelo
    Vallejo, CA
    '11 S/C K.I.S.S. "Factory Enhanced" DC TRD OR
    TRD Supercharger, TRD First Gen CAI, TRD FJ Alloy, Toyo OC A/T II 265/75/16, 5100's Front and Rear, OME 885x with 1/4 taco lean spacer, Toytec AAL 1.5" non TSB. TSB not done. WheatherTech Side Window Deflector, Satoshi Grill, T Rex Eyelids, Matt123 Skid Black stamped, Modded Maglite with Maglite mod for driver seat, Bed extender. Full debadging
    Windows wont activate without it. In 3 days your screen goes black and stuff.
  2. Aug 14, 2013 at 10:03 PM
    #162
    Forster46
    Forster46 [OP] Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    My screen resolution is waaay to large for my screen and I can't see the outside of the screen. WHen I go to change resolution there are only two options and teh other is super widesceen, even worse. Do I need to throw in the drivers cd for the gpu or something?
  3. Aug 14, 2013 at 10:04 PM
    #163
    2wheelnut
    Angelo
    Vallejo, CA
    Yep, get the ones from their website. this guarantees that they are the latest version.
  4. Aug 14, 2013 at 10:05 PM
    #164
    Dizo
    Dizo Well-Known Member
    Oliver
    North of 62°, Canada
    2005 DCLB TRD Sport
    Aux Audio-input, 5100's @ 1.75", 2" Wheeler's AAL, LED Underhood Lighting, Anytime ABS-Off Switch,
    If you don't have a legit CD key to verify windows you are verifiably screwed, as another member put it. Go to start -> right click on my computer -> properties and make sure your copy is showing as validated. I bet it isn't, and unless that other member provided you with a CD key you'll be locked out of the OS in a few days.
    There are ... ways around this. PM me if you need a copy of windows at "less than market value" :gossip:
  5. Aug 14, 2013 at 10:07 PM
    #165
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    This is my current case. Built it in 2001, upgraded the mobo in 2003 and the hard drives in 2006.
    Freaking thing doesn't even have USB 2.0 (came out a couple of months later)
    AMD XP2800+ on an MSI mobo.
    The front panel audio connectors have been removed, and the hard drives have been moved to the top of the case, one behind the thermometers (which have been removed) and the other in a removable drive tray with fans.
    Two 120mm fans in the rear, four 80mm fans on the side, one 120mm fan behind the gray panel in front.
    CPU cooler has a 92mm fan... it's a copper base with aluminum threaded pins to pull the heat away.
    One thermostat probe was attached to the back of the GeForce right behind the GPU, and the other was on the bottom of the CPU cooler next to the core (core is thicker than the probe. With the entire case lined with Dynamat, the case temp ran warm on a hot day even with all of the fans, but it was pretty stable and I never had a problem with graphics rendering with the GeForce 2-Ultra.
  6. Aug 14, 2013 at 10:12 PM
    #166
    Dizo
    Oliver
    2005 DCLB TRD Sport
    Retro :headbang:
    Mind you, my cell phone has more processing power!
    Is that thing still kicking? Do you use it much?
  7. Aug 14, 2013 at 10:13 PM
    #167
    Forster46
    Nick
    Mount Vernon, WA
    It says my windows is activated? It even shows a product key.....
  8. Aug 14, 2013 at 10:14 PM
    #168
    2wheelnut
    Angelo
    Vallejo, CA
    Nice! My old build is getting a bit long in tooth but it still kicks ass.
    Nvidia Reference 680i LT
    Core2Quad Q9650 @ 3.8ghz.
    8 gb. RAM
    Samsung 250 SSD boot drive
    Seagate 1tb. storage drive
    EVGA GTX 560ti @ 1.0 ghz. 2200 on the memory bus
    Antec 750w PS
    NZXT Hush case
    I want new tech but I don't game so much anymore.
  9. Aug 14, 2013 at 10:17 PM
    #169
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    I'm still waiting on DD4 before I build a new system
    ...probably be waiting quite a while longer
  10. Aug 14, 2013 at 10:17 PM
    #170
    Dizo
    Oliver
    2005 DCLB TRD Sport
    Don't ask any more questions :) Move on. Yay! Install drivers and get some games on that beast!
    I'll just leave this here ....
  11. Aug 14, 2013 at 10:18 PM
    #171
    2wheelnut
    Angelo
    Vallejo, CA
    Then you're gtg!
  12. Aug 14, 2013 at 10:18 PM
    #172
    Forster46
    Nick
    Mount Vernon, WA
    What game?
    Let's just say, steam is gonna be loving my business here in the next several days
  13. Aug 14, 2013 at 10:19 PM
    #173
    2wheelnut
    Angelo
    Vallejo, CA
    lol, Nice pic.
  14. Aug 14, 2013 at 10:20 PM
    #174
    2wheelnut
    Angelo
    Vallejo, CA
    Add me on Steam
    angetea
  15. Aug 14, 2013 at 10:20 PM
    #175
    Dizo
    Oliver
    2005 DCLB TRD Sport
  16. Aug 14, 2013 at 10:26 PM
    #176
    Dizo
    Oliver
    2005 DCLB TRD Sport
    https://www.humblebundle.com
    They've got a sale on right now. Go pick up:
    Dead Space
    Burnout Paradise
    Crysis 2
    Miror's Edge
    Dead Space 3
    Medal of Honor
    Battlefield 3
    and The Sims 3
    All for $4.73 or whatever you can afford. :)
  17. Aug 14, 2013 at 10:27 PM
    #177
    Forster46
    Nick
    Mount Vernon, WA
    I only have on friend on steam that I don't even talk to. And no games, since my pc's have never been good enough to run any. Now I will be getting a ton of games. If anyone else wants to add me on steam my profile name is redneck46.
    P.S. Does anyone know how to change your steam name lol
  18. Aug 14, 2013 at 10:29 PM
    #178
    Forster46
    Nick
    Mount Vernon, WA
    When my windows boots up or shuts down, the size of the screen is fine. But as soon as im at the desktop or anything else, its huge. I'm gonna try and change it through the gpu utilities but I'm not sure if that is the right place
    Edit: Disregard, on boot up after driver install everything is fixed
  19. Aug 14, 2013 at 10:34 PM
    #179
    2wheelnut
    Angelo
    Vallejo, CA
    Nope, been trying to figure that out for years since my Steam user name is a big fat typo.
  20. Aug 14, 2013 at 10:39 PM
    #180
    Forster46
    Nick
    Mount Vernon, WA
    Shit there is 26 people viewing this thread for the last couple hours and only two people saying anything!
