Garage air compressor recommendations
Discussion in 'Garage / Workshop' started by The1youluv2hate, Sep 24, 2012.
  1. Sep 24, 2012 at 11:07 AM
    The1youluv2hate
    The1youluv2hate [OP] Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
  2. Sep 24, 2012 at 11:12 AM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    I have a craftsman 33 gallon. It does good for everything except running my die grinder any more than a couple seconds. I wish I would have saved and bought a 2 stage. I would say buy the biggest your budget allows.
  3. Sep 24, 2012 at 11:33 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I just bought one a little while ago and here's what I learned when researching mine (I'm not an expert, just repeating what I read). There's 2 things to consider when buying a compressor, duty cycle and tank volume. Depending on what you're doing with the compressor, you might be able to get away with a smaller compressor and a large tank. Sure, when the tank is empty, it takes a while to fill back up but if you do small projects at a time, by the time the tank is empty, you're done anyways. Otherwise, you need the higher duty cycle. Makita always used to make decent stuff, never had any issues with them. I ended up with a Bosch compressor. It works well for me as I mostly just run air nailers and use it for tire fills, I don't have many air tools.
  4. Sep 24, 2012 at 11:36 AM
    The1youluv2hate
    Peps
    SAnta Paula CA
    Good info thanks guys
