Garage Door Issues
Discussion in 'Garage / Workshop' started by whippersnapper02, Feb 8, 2012.
  1. Feb 8, 2012 at 8:39 AM
    whippersnapper02
    whippersnapper02 [OP] Well-Known Member
    Christian
    Yorba Linda, CA
    10 MGM TRD OR 4wd Auto DCSB
    Banks Monster Exhaust, Pop n Lock tailgate lock, Hook-Ups tie down brackets, USA Spec Ipod adaptor, WO seat covers, color matched grill with Grillcraft insert, Tuffy locking bed box
    So we have a sectional door with windows on our standard 2 car garage. A couple of years ago the crappy screw drive opener took a dump so I bought a Craftsman 3/4hp belt drive unit. Everything was good for 2ish years. Last month a spring broke so we had them replaces. I would have done them myself but I don't have the unloading bars and I didn't know where to get the spring. Every since the guy we hired worked on it the opener sounded like it was struggling a bit. Also it sounded like it was trying to rip the door from the well. Well today the panel that the opener arm attaches to was pull off the door almost completely. This panel is screwed into the door but it just stripped the holes. I'm thinking the dude didn't set the correct tension when he replaced the springs. WTF is going on?
  2. Feb 8, 2012 at 8:44 AM
    whippersnapper02
    Christian
    Yorba Linda, CA
    I forgot to add that my uncle said he saw the guy messing with the settings on the opener. He then asked how for instructions on how to adjust the open/close force on the unit. Well i know that this unit has an auto adjust but there is no manual adjustment.
  3. Feb 8, 2012 at 11:50 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    You should be able to adjust the opening force. If not, maybe the spring is too tight.
    As for fixing the door, mine did that once when I forgot I had the slide lock locked into the track and I tried to open the door. I just replaced the screws with some bolts w/ nuts and washers.
  4. Feb 8, 2012 at 1:42 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    Well it self adjusts the opening force. You tell it to adjust and it will automatically adjust the opening and close force when you tell the opener which one to adjust. I will take a look at the manual again. If the springs have too much tension the door would want to pop open right?
    As for the door I will probably come home to a new door because my uncle doesn't like to deal with this stuff.
  5. Feb 8, 2012 at 1:56 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    Force adjustment procedures from the manual:
    ADJUSTMENT STEP 2
    Set the Force
    Theforce setting measuresthe amountof force requiredto
    openand close the door.
    1. Push the purple button twice to enter into the ForceAdjustment
    Mode (Figure 2). The LEDwill flash quickly.
    2. Push the door control or programmed remotecontrol. The door
    will close (DOWN) (Figure 3).
    3. Push the door control or programmed remotecontrol again.The
    door will open (UP).
    4. Push the door control or programmed remotecontrol a third
    time to closethe door (DOWN).
    The LEDwill stop flashing when the force has beenprogrammed.
    The door must travel through a complete cycle, up and down, in
    order for the force to beset properly. If the garagedoor opener
    cannotopen and closethe door fully, inspect the door to ensure
    that it is balancedproperly and is not sticking or binding.
    If the door is not stopping exactlywhere you would like it, repeat
    Program the TravelLimits
  6. Feb 8, 2012 at 3:47 PM
    Tacoma Mike
    Tacoma Mike 41 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    check the "balance " first thing. i always got the door to stay mid level to start the process. I'm not familiar with the auto adjust. My genie chain has manual setting for up and down but they really want the door neutral. I also added a reinforcement plate the shape of a "T" where it attached to the door. Help spread the load. If it pulled it away then i'm thinking the springs are not tight enough. Pull your emergency handle and cycle the door by hand. If it feels heavy to lift then it's to loose. It should also go by itself the last section of door almost up. Double check your down and up stops if there is a manual adj.
  7. Feb 8, 2012 at 3:51 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    Yeah I'm really thinking this guy that worked on it didn't set the tension correctly. All was good until that moron came to change the springs out. I'm not buying a new door. I'll take off the bracket and straighten it out then I will add some kind of reinforcement. I will also have to pick up some spring bars so I can adjust the tension. Lastly I will let the unit auto adjust the force and I will adjust open and close points. No stop sensors to move with this unit. It is all digital.
    Thanks for your help.
  8. Feb 8, 2012 at 3:54 PM
    4wd Boss
    4wd Boss Shake and Bake
    Jefferson
    Big D
    07 4dr 4x4 V6
    Fog Light Mod
    sounds more like a garbage door opener. :laugh:
  9. Feb 8, 2012 at 4:22 PM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    NP
    Here is a pic of my reinforcement. spreads the stress along both stringers.
    you can box it and put a plate on the outside and paint it and sandwich the door in between...
  10. Feb 8, 2012 at 4:58 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    Well it kinda is but only because there is a bunch of crap lying around because my uncle is a horder.
    May I ask where you got that from? I will post pics of the damage later today. For now I told my uncle to manually open it and I hit the lock so no one uses their remote or the keypad to open it.
  11. Feb 8, 2012 at 5:08 PM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    I went right to the hardware store and started looking around. i knew what i wanted and this fit the bill perfectly.
    I don't remember what they called it sorry. I'm sure a big box store ( which names will not be spoken) should have something similar if the mom and pop hardware won't have it.
  12. Feb 8, 2012 at 6:13 PM
    macgyver
    Brad
    Canton, GA
    You can find those in the lumber section at home depot or lowes where they keep all the joist hangers.
    Yeah you're right it's too loose. Good call.
  13. Feb 8, 2012 at 6:17 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
  14. Feb 8, 2012 at 6:21 PM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    Crap.
    don't look like hardly anything is holding that reinforcement on.
  15. Feb 8, 2012 at 6:25 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    I count 5 bolts. 2 at the bottom, 2 that also hold the mount for the opener arm and one on top holding the metal deflector to the door.
  16. Feb 8, 2012 at 6:27 PM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    Ok .Kind of hard to see in the pic..
    Is it a composite sandwich between the outer layers ??
  17. Feb 8, 2012 at 6:27 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    Correction. There are 2 tiny screws not bolts on the bottom.
  18. Feb 8, 2012 at 6:31 PM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    That's just gay... No strength there.
  19. Feb 8, 2012 at 7:21 PM
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    +1 w/ what tacoma mike was saying, ..i'd probably check the counter torque/force too, like he said by pulling the opener disconnect and try opening it manually - i think if it's done right, ..the door should basically stay nearyl motionless ("balanced") when near fully closed position...
    get that fixed if necessary, then reinforce the attachment point similar to what tacoma mike did ;)
  20. Feb 8, 2012 at 7:35 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    The door feels heavy when opened manually. It will fall of I let it go unless it is fully opened.
