Garage Door Opener Mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gonzo1982, Jun 7, 2019.
  1. Jun 7, 2019 at 5:58 PM
    Gonzo1982
    Gonzo1982 [OP] Well-Known Member
    Tullahoma, TN
    2013 MG DCLB TRD Sport
    5100, OME 885, 1.5” Icon AAL, KO2 275/75/17
    I got tired of having my garage door opener on my sun visor so today I did a mod using a momentary switch. Props to @Regnar and @fillsrunner4 for the idea.
    YouTube Video
    https://youtu.be/gMKhbos7fys
    Below are the items I used and a link to a YouTube video I made of what I did. It’s my first video so it’s kinda crappy, but shows you basically what I did.
    Tips I forgot to mention in the video:
    Instead of stranded cable, I used solid wire for the extension. It’s easier to direct through tighter areas
    Use electrical tape to tape down the cable every 4-5 inches. It helps keep the cable together and not twist and get into a mess.
    You have to start from the switch side and feed the long cable through the blank hole
    Items Used:
    Momentary Switch: https://www.aironboard.com/online/p...acement-garage-opener-momentary-led-blue.html
    Wire Connectors: https://www.amazon.com/gp/product/B07CRFTPGY/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
    Male Female Plug Connectors
    https://www.amazon.com/gp/product/B07G932BYS/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
    Striveday™ 22 AWG Hook Up Wire 1007 PVC Solid wire Kit box Electric wire 22 gauge 300V Cable (26.2ft Each Color) https://www.amazon.com/dp/B077HRKYB1/ref=cm_sw_r_cp_api_i_CG6-CbX350BBE
    TNMTX23, Vmax88, Jtcmedic and 4 others like this.
  2. Jun 7, 2019 at 6:16 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
  3. Jun 13, 2019 at 7:42 AM
    Badderup
    Badderup Well-Known Member
    Colby
    Utah
    2006 SWB TRD sport DCLB
    Those wire connectors are pretty cool. Haven't seen any like that before. Have to give them a try.
  4. Jun 13, 2019 at 7:58 AM
    Gonzo1982
    Tullahoma, TN
    Made the splitting a whole lot easier for sure.
  5. Jun 13, 2019 at 8:54 AM
    dofartshavelumps
    dofartshavelumps Well-Known Member
    NH
    2015 SR DCSB 4x4 4.0 MT
    Looks nice. I took the easy way out and bought a mirror with homelink and a compass. Mine was pre wired so all I had to do was pop off the sunglass holder, fish the wire up and plug it in.
