Garage door opener relocation.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jay7108, Mar 16, 2008.
  1. Mar 16, 2008 at 9:38 AM
    jay7108
    jay7108 [OP] Active Member
    Chicago IL
    08 TRD Sport LB 4x4 Debadged
    Halogen back up lights,wade oe,avs inchannels,led lights,deezee bed mat, more to come.
    I found the idea on TN and decided to give it a try, about $4 in parts and 30 min. to complete. Overall very easy to do and now I dont have to listen to the remote rattle around in the sunglass holder in the overhead console. The red momentary switch in the dash is the new door opener remote, I installed that switch in place of the big remote.
  2. Mar 16, 2008 at 10:47 AM
    Don G
    Don G Old Goat
    Southern Tier New York
    "08" Tacoma Access Cab TRD Sport 4X4
    OK! !! I give up:) What did you do:confused:
  3. Mar 16, 2008 at 10:51 AM
    jay7108
    Chicago IL
  4. Mar 16, 2008 at 11:05 AM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    Do a DIY on this. Part #'s, where bought, how to do. I just keep my remote in the tray to the right of the steering column. It's slanted and doesn't really rattle that much but like your idea. Thanks
  5. Mar 16, 2008 at 11:13 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2025 Underground SR5 RWD Double Cab
    Clazzio seat covers,
    I use the same location. It is double-sided taped (heavy foam type) just above the removeable part of the tray on the left hand side. Just out of sight.
  6. Mar 16, 2008 at 11:57 AM
    gavonder
    gavonder She's Kickass!
    Ct
    08 TRD Sport Access Cab
    Sunroof, Leer Cap w/ Thule rack, Factory Running Boards, Fog Light Mod, Hood Struts, Scangauge, w/homemade mirror mount, AC/Defrost mod, Rear Spring TSB, TRD Center Caps
    How is the switch connected??
  7. Mar 16, 2008 at 1:41 PM
    JTDTacoma
    JTDTacoma Well-Known Member
    08 4X4 Double Cab TRD Sport
    I removed the visor clip on mine and used double-sided tape and secured mine to the inside of the coin-tray door just below your button in the pic. Open the little door and it's right there, close it and it disappears. Plus it doesn't rattle. Just can't use the coin tray for coins now but I never did anyway. Simple, hidden, secure, cheap, etc.
    I like your idea though, looks great.
  8. Mar 16, 2008 at 3:17 PM
    CtryBoyInMT
    CtryBoyInMT Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    I may be mistaken, and if this isn't the way he did his set up, I'm sorry.
    He split apart his remote from his garage door opener, soldered a wire to each of the two contact points, ran the wire leads to the momentary switch of your choice and install in a switch blank.
  9. Mar 16, 2008 at 3:39 PM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    On my truck there is a compartment in front of the ceiling map lights for a garage door opener. There's a button on it that pushes the remotes button. I guess it's not included on the fancier trucks.
  10. Mar 16, 2008 at 3:48 PM
    CtryBoyInMT
    Kind of surprising, huh!
    I guess we get a compass and temperature, but heck if I ever remember too look up there!
    If I can't figure out what direction I'm driving or if it's too cold out to open the windows, Take my truck away.
    I've got a home-link in my headliner, now. So it's water under a bridge in my book.
  11. Mar 16, 2008 at 5:45 PM
    06tacoma
    06tacoma Well-Known Member
    Tampa FL
    06 PreRunner SR5 XS-P Trd Longbed Double Cab
    20" enkei wheel,BFG G-Force tires, BHLM, Smoked tail lights, 2 RE Audio 10s, Quantom 900watt amp,10000K HIDs headlights and fog lamps,Borla exhaust, Borla drop in filter,Debadged tailgate,Painted black tacoma badges
    pretty nice
  12. Mar 16, 2008 at 8:47 PM
    gsm
    gsm Well-Known Member
    Raleigh, NC
    08 Tacoma Regular Cab, 2.7L, Impulse Red Pearl
    DIY OEM Fog Lights on anytime, DIY OEM Cruise Control, Removed 2ndary Air Filter, Rear Speakers Mod, Traction Bar/Helper Spring Mod, Red Brake Drums and Rotors, Stainless Steel Exhaust Tip, Door Sill Protectors, Taco Bed Mat, Custom Front Mud Flaps (Mudguards), TRD Bucket Seats (pending)
    I used double stick foam tape and stuck it on the removeable plate that goes around the parking break pull handle. Out of the way and almost un-noticeble, but in easy reach when needed.
    But I like the push button idea. I thought about something similiar but couldn't find a button I liked (didn't look too hard I guess).
    A link to TN where this is posted or a write up for DIY would be nice though.
  13. Mar 17, 2008 at 3:52 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Excellent ! So what do you have for us without a garage door... or a garage ? :D
  14. Mar 17, 2008 at 4:13 PM
    Roland
    Rhode Island
    /sigh I typed out a great response but I decided to mod myself. :p
  15. Mar 18, 2008 at 9:53 AM
    mmatheny
    mmatheny Well-Known Member
    Dickinson, Tx
    2017 SR5 DCSB Magnetic Gray Metallic
    BakFlip MX4
    Mine has a garage door opener place behind the lights on the roof. Yours doesn't??
  16. Mar 18, 2008 at 2:02 PM
    4x4x4trd
    North Texas
    Some don't.
  17. Mar 18, 2008 at 2:04 PM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    thats not how this site works, we thrive on great responses :)
  18. May 16, 2008 at 6:34 PM
    atebit
    atebit What's all this, then?
    The basement of the Alamo
    18 Inferno TRD OR 4x4 AC
    Does anyone know an easy way to get the door on this compartment off without having to remove the entire console from the headliner? I was going to try and squeeze the side/sides of the door with a trim tool to see if it would pop out, but it appears to be in there pretty tightly.
  19. May 16, 2008 at 6:50 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
    The door's hinges (for lack of a better word) are about 1/2" long on both sides. I broke one of them trying to get the door off, and now mine is held in with some screws where the plastic broke. It would be easier to take the whole console down to make sure you don't break your door. The cosole is just held in by one screw and two plastic clips near the windshield. Take out the screw, and give a firm tug on the front (closest to the windshield) you should hear 2 pops from the plastic clips, and then the console simply falls down. Nothing to it.
  20. Jan 15, 2009 at 6:52 AM
    lsarg27
    lsarg27 Member
    Cape Cod.
    4x4 double cab long bed
    Tonneau, cold air intake, TSB
    You should label the button. Maybe NITRO, or BOOST, or EMP or something fun
