Garage door opener works for gate but not for garage. Suggestions?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2013baja, Apr 8, 2013.
  1. Apr 8, 2013 at 9:18 PM
    2013baja
    2013baja [OP] Well-Known Member
    Markus
    SoCal
    So I got a new 2012 Taco and tried programming the gate and garage door opener (on two separate buttons of course). The gate works but the garage door won't react. The original remotes work fine. Suggestions?
  2. Apr 8, 2013 at 9:27 PM
    Traction120
    Traction120 "Not all those who wander are lost"
    Nathan
    Reno, NV
    2013 DCSB BLK
    SEE BUILD.
    There should be a button on the garage door motor, hold it until it flashes and then hold the home link button.
  3. Apr 9, 2013 at 3:45 AM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    What is the model and year of ur garage door opener?
    It could be an incompatibility of the homelink software to ur opener. Esp if its security + 2.0. I had this problem w my 2012 BMW. I had to get a "homelink repeater". Google that for more info.
  4. Apr 9, 2013 at 8:23 AM
    DirtEater
    DirtEater Well-Known Member
    Surprise, AZ
    2012 has that feature but my 2013 Sport doesn't? Did Toyota go backwards?
  5. Apr 9, 2013 at 8:28 AM
    1ToughTRD
    1ToughTRD Well-Known Member
    Chad
    Pittsburgh
    '13 TRD Sport
    (gone but not forgotten)
    Did you hold the opener button down close to the homelink and then while still holding down the opener also hold in the homelink button until in recognizes the rolling code?
  6. Apr 9, 2013 at 10:49 AM
    2013baja
    Markus
    SoCal
    At first I thought you were stating the obvious, but then I realized you actually had the winning solution. Thanks bro!
    I had been holding the garage door opener remote up to the mirror. The trick was to ignore the remote and instead go into the garage and set it off of the actual opener (motor).
    Seems obvious in retrospect I suppose, but all the manual said was to hold another remote for the same device up to the mirror and program it that way, which worked for the gate opener but as it turns out is not always the correct procedure.
    Thanks for all the suggestions fellas!
  7. Apr 9, 2013 at 11:43 AM
    Traction120
    Nathan
    Reno, NV
    2013 DCSB BLK
    SEE BUILD.
    Glad I could help
