Garage flooding-melting snow...
Discussion in 'Garage / Workshop' started by stealthmode, Mar 28, 2018.
  1. Mar 28, 2018 at 12:03 PM
    stealthmode
    stealthmode [OP] Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    I'm looking for some ideas/solutions (relatively cost effective) to stopping spring run off from seeping in at the bottom plate stud and slab on grade.
    Unfortunately when my garage was built they didnt add any kind of curb for the stud walls to bare on.
    The obvious answer is shoveling snow away from the garage and slab, but with the amount of freeze thaw cycles here in Alberta its near impossible to keep up.
    I'm sure some of you have had a similar problem and looking for some ideas. Thanks guy.
    I can post pics of existing structure if it helps.
    Stealth
  2. Mar 31, 2018 at 6:03 AM
    Indy
    Indy Master of all I survey.
    Improve the grading around the structure.
    robssol likes this.
  3. Mar 31, 2018 at 6:14 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    I dug down & put in a length of weeping tile. As long as the water has someplace to go it'll find the easiest place.
  4. Mar 31, 2018 at 6:16 AM
    Indy
    Perimeter drain...
    I found the best option for dealing with snow was to move to Florida .
    robssol, Jeffas7, henryp and 6 others like this.
  5. Mar 31, 2018 at 8:49 PM
    stealthmode
    Alberta
    Did you have to drain the tile into a sump pump or a anything ?
  6. Mar 31, 2018 at 8:52 PM
    stealthmode
    Alberta
    Shorts in December is appealing
  7. Mar 31, 2018 at 8:55 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Texas is a better option if you enjoy Alberta, it's basically the same thing with better weather.
  8. Mar 31, 2018 at 8:59 PM
    FastEddy59
    Eddie
    No, just to a lower part of the yard where the house downspouts drain.
  9. Mar 31, 2018 at 9:20 PM
    Indy
    I've worn pants about 5 times this winter, excluding work where shorts look unprofessional.
  10. Apr 1, 2018 at 11:04 PM
    stealthmode
    Alberta
    Show off. I think 5 times this winter I HAVENT had to wear a toque eh!
    DavesTaco68 likes this.
  11. Apr 1, 2018 at 11:05 PM
    stealthmode
    Alberta
    Into my neighbour's yard then you mean:bananadance:?
    FastEddy59[QUOTED] likes this.
  12. Apr 1, 2018 at 11:06 PM
    FastEddy59
    Eddie
    :D
  13. Apr 1, 2018 at 11:06 PM
    stealthmode
    Alberta
    So you have wintenssed the 4 seasons in one day then? Typical Alberta day.
    FastEddy59 likes this.
  14. Apr 1, 2018 at 11:13 PM
    FastEddy59
    Eddie
    Oh ya, stomped all over Gods creation out there before I pulled the pin on the patch.
  15. Apr 1, 2018 at 11:18 PM
    Tacoma/Taco
    Tacoma/Taco Well-Known Member
    Josh
    Southern Maine
    Tacoma13'build in process
    3inKing coilover with clickerreservoirs 600lb King struts clicker reservoirs Total choas UCA Total choas Race series LCA Total choas bed stiffnners Timberland bump stops front/rear Welded gusset All pro aluminum apex bumper Warn 9000 Pia fog lights Pia off road light led Baja light bar Spider projection lights U bolt flip kit All pro 3in expedition leafs ARB front & rear locker ARB twin compresser Large ARB tank 4:56 gear ratio CBI slider bolt on CBI rear bumper steal Marlin crawler Taco Box 4:7 Optima blue top BFG 285/75R17 mud tires Body mount chop 1.25 wheel spacer Budbuilt Full body armor with crossmember support for dual transfer case skid plate Redirected exhaust Spider headlights warn Synthetic winch line Factor 55 fairlead Fiberglass hood, front-rear fender wells Beaded rims Spare tire mount in bed
    Unfortunately my family house has the exact same problem, especially when we have a huge rains the water seeps in through the cracks in the concrete. We have had tons of different people look at it including a friend of mine who a structurel engineer. The consensus in our case is the whole grarage floor has to be demoed and redone again with a sump pum etc..
  16. Apr 1, 2018 at 11:30 PM
    FastEddy59
    Eddie
    Welcome aboard Josh :hattip:Kinda sucks when a man's home is his castle & you got a moat 2boot. :annoyed:
    stealthmode[OP] and DavesTaco68 like this.
  17. Apr 1, 2018 at 11:50 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Dig french drain around perimiter of building , layer heavy filter cloth in bottom trench and up both sides , install perforated CSA PVC pipe , add clean , washed drain rock to grade , pipe with1/8" to the foot grade minimum away from building
    I wear shorts all year
  18. Apr 1, 2018 at 11:56 PM
    Tacoma/Taco
    Josh
    Southern Maine
    Thanks... How do you guys get the cool animated emojis??
    stealthmode[OP] likes this.
  19. Apr 1, 2018 at 11:57 PM
    Tacoma/Taco
    Josh
    Southern Maine
    Brain fart, I see the light now...:militarypress:
  20. Apr 2, 2018 at 6:45 AM
    Indy
    You don't have to remove the floor to install a sump, just cut a hole and dig.
