Garage/ Shop heater
Discussion in 'Garage / Workshop' started by chadderkdawg, Dec 9, 2013.
  1. Dec 9, 2013 at 8:14 AM
    chadderkdawg
    chadderkdawg [OP] Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    I have a 500ish square foot garage and 200 bucks to buy a heater for it, looking for any suggestions on the best options.
  2. Dec 11, 2013 at 9:56 AM
    gtokarski
    gtokarski Well-Known Member
    George
    Dublin, CA
    06 4x4 xtra cab silver
    OME 886, AAL, ARB Bumper, XRC8 Winch, Sony MEX-N5000BT, and one angry beagle.
  3. Dec 11, 2013 at 4:50 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
  4. Jan 20, 2016 at 3:30 PM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
  5. Jan 23, 2016 at 2:35 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I have Hot air oil
    A Nice Wood Stove
    A Radiant Propane heater
    Kerosene forced air heater.
    One thing that makes a big difference is a ceiling fan to push the hot air where you want it.
    Nothing like being up on a ladder to bring that point home
    They have been picked up over the last 25 years they all work go for different heating needs depending on what I need at the time.
    Just what do you need heat all the time in the winter or something to bring the temp up fast for a few hours on the weekends??
  6. Jan 25, 2016 at 3:31 PM
    Smashing
    Smashing Well-Known Member
    Rochesterish NY
    2017 DCLB Sport
    3 year old thread. Hope he's figured it out by now
  7. Feb 12, 2016 at 6:06 AM
    MarAgt
    MarAgt Well-Known Member
    Lugoff, SC
    Silver Tacoma TRD
    I have a 24' x 24' pole barn, so the ground is about 480 sqft. But, it has a lot of open roof area.
    I also have a Mr. Heater Portable Big Buddy Propane Heater and i works very well. But, for that size shop you'll probably need two. They are nice because you can hook them to a 20lb tank and they are rated for indoor use; unlike a lot of the torpedo heaters which are not rated for indoor use. And, since these are rated for indoor use, they give you backup heat for the house if it's needed.
    I considered putting in wood stove, but unless you spend a significant amount of time inside your shop, the time it takes to get going and warm up is a bit slow. If you're in your shop all of the time, then a wood stove would be real nice.
  8. Mar 9, 2016 at 7:38 AM
    Assforkr
    Assforkr Well-Known Member
    MA
    03 taco
    I'm in a 15x12' single bay with 7 foot ceilings and plaster all the way around. Definitely lacking in insulation. Do you think a single big buddy heater would suffice? I'm about to prep to spray epoxy and need to temper the air.
  9. Sep 26, 2016 at 8:56 AM
    MarAgt
    Lugoff, SC
    Silver Tacoma TRD
    I know I am very late getting back to you on this one. But, if you only have a 7' ceiling, I would bet that one of these would be sufficient to keep it warm.
  10. Sep 28, 2016 at 6:15 PM
    Assforkr
    MA
    03 taco
    Haha. No sweat. Just in time for the next cold cycle here in mass. I bought the big buddy and it got me to 75-85 degrees after an hour or so. Enough to paint the VW at least.
  11. Nov 17, 2016 at 7:30 AM
    Lifeofbrian
    Lifeofbrian Longing for the far East
    Brian
    Westminster, CO
    2010 TUNDRA 5.7 Rock Warrior
    Stuff
    Just what I was looking for! winter is coming and I want to be able to work in the garage without ending up like the guy from the shinning![​IMG]
