Gardening Thread - Show me your gardens!
Discussion in 'Garage / Workshop' started by Noelie84, Mar 28, 2014.
  1. Mar 23, 2025 at 10:32 PM
    #6981
    r3k
    r3k Well-Known Member
    last years harvest
    this is pic from washington state where i sent a large USPS box full of mangoes
    this is from arizona
  2. Mar 24, 2025 at 4:51 AM
    #6982
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Need my address??
    shakerhood and Pablo8 like this.
  3. Mar 24, 2025 at 4:58 AM
    #6983
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Grown in AZ?
    wilcam47 likes this.
  4. Mar 24, 2025 at 5:39 AM
    #6984
    r3k
    florida
  5. Mar 24, 2025 at 5:46 AM
    #6985
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Very nice. My brother has grown a few small mangoes in so cal. Nothing like that - very jelly!
    shakerhood, Barsoom and wilcam47 like this.
  6. Mar 24, 2025 at 5:48 AM
    #6986
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    I am enjoying my last pint jar of red gooseberry jam. So there is that. That bush is a delicious delight from heaven and a thorny devil from hell.
  7. Mar 24, 2025 at 8:22 AM
    #6987
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    My blueberries are covered this year with blooms. Should be a good year.
    Next couple of weeks will be all about taking care of the transplanted trees, making sure they root properly.
    Need to start saving for an Amish built greenhouse next. We could really use one.
    shakerhood and wilcam47 like this.
  8. Mar 24, 2025 at 8:30 AM
    #6988
    wilcam47
    Will
    Bourbon state
    What ph are your blue berries at? I got bud forming...
    shakerhood likes this.
  9. Mar 24, 2025 at 8:33 AM
    #6989
    Barsoom
    NW GA OTP
    Not sure ,to be honest, have not tested in a year. We've been dumping coffee grounds at the base all winter, though.
    wilcam47[QUOTED] likes this.
  10. Mar 24, 2025 at 9:19 AM
    #6990
    wilcam47
    Will
    Bourbon state
    I just planted them fall. They look like they are taking hold. I used a ph meter said around 6
    shakerhood and Barsoom[QUOTED] like this.
  11. Mar 25, 2025 at 6:18 PM
    #6991
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    what is the best weed killer to use in the yard? I want to get rid of the weeds....
  12. Mar 25, 2025 at 7:21 PM
    #6992
    Pointeman
    Pointeman Well-Known Member
    Mark
    2013 Pyrite Mica Tacoma DCLB
    6" Fabtech Amp Research hydraulic steps Front Runner Cab Rack Leer 100xr topper w/rails 17” Black Rhino Warlords Dark Tint 295/70R17 Nitto Ridge Grapplers
    In the bed or in the grass?
  13. Mar 25, 2025 at 7:28 PM
    #6993
    Pointeman
    Mark
    Ms. Sue if you want organic and safe for the pups you can mix 1 gal of 5% vinegar ( or stronger) with a cup of salt and 2 tablespoons of dawn dish soap in a sprayer and spray directly on the weed. Best when sunny and warm ish. It will kill anything so be careful what you spray.
  14. Mar 25, 2025 at 7:33 PM
    #6994
    ImpulseRed008
    Susan
    SC
    It's most of the yard.... hmmmmmm
  15. Mar 25, 2025 at 7:33 PM
    #6995
    ImpulseRed008
    Susan
    SC
    Sorry, missed this... most of the yard
  16. Mar 25, 2025 at 8:26 PM
    #6996
    Pointeman
    Mark
    Well depending on the type of weeds you are dealing with that could be a lot of spot spraying. But might be worth the time and effort. On several of my residential properties I had pretty good luck with a fertilizer maintenance program that started in the fall with an application of dolomite lime (careful to apply evenly to avoid bright green spreader lines) and then continued through the year with an application of high nitrogen and then culminating with an application of commercial weed and feed as needed as spring turned to summer. Healthy lawn minimizes weed growth. Soil Ph plays an important role in this. Chelated iron will also work. It’s a liquid application you can find info on YouTube or online. Broadleaf weeds love to absorb iron and will by nature over dose (turn black and die) on it whereas grass will only take in what it needs. (There are some limits to this though and you don’t want to over treat as it will affect your soil ph). I’ve used Scott products with success on some of my properties where they provided materials. I prefer 1/2 dosing more frequently than full dose applications when possible. If you want chemical application (herbicide) Tri Mec or 2 4 D will kill broadleaf weeds but not the grass. Crossbow is a 2 4 D product that was used to kill clover in sheep grazing pastures and is safe after 24 hours. But like any herbicide it easy to over apply and then bad juju happens. I have always steered clear of round up products ( just my opinion) but they do have an in lawn herbicide. Masks, gloves, respirators and a surfactant or sticker is recommended. I did not use much herbicide. When I did it was for blackberries because it killed plants dead to the roots. I could reclaim an entire yard for less than a gallon of solution which is a 1/4 cup of chemical. So three options to try. Hope that helps.
  17. Mar 26, 2025 at 12:13 PM
    #6997
    THatt
    THatt Well-Known Member
    Upstate SC
    1996 Tacoma 2.7L MT 4X4
    Got my garden plot turned but holding off planting till mid April. Took forever for it to get dry enough to turn.
    Replaced corner posts and reworked the electric fence this weekend.
    Bizquick, la0d0g, 308savage and 5 others like this.
  18. Mar 26, 2025 at 2:40 PM
    #6998
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    A Kildeer laid eggs in the driveway, they blend right in with the gravel.
    Gamehenge, ACEkraut, Barsoom and 3 others like this.
  19. Mar 26, 2025 at 2:52 PM
    #6999
    wilcam47
    Will
    Bourbon state
    Thats a big garden
    shakerhood, Barsoom and 308savage like this.
  20. Mar 27, 2025 at 7:30 PM
    #7000
    14Tacos4me
    14Tacos4me Well-Known Member
    Daniel
    Hendersonville, TN
    2014 Blue Ribbon DCSB TRD OR 4x4
    -Fox 3 inch lift -SOS Streamline front bumper with Smittybilt x20 winch -Mobtown sliders -Mobtown IFS & Trans skids -DV8 Rear bumper - Look at the build thread
    Beginning to put a few things in the ground, the Greenhouse was definitely nice to have this year for storing some dormant plants and getting an early start with a lot of other stuff.
    My front bed, so far I’ve got some potatoes and bush peas in it that just started to sprout, but soon it’ll mostly be corn, beans, and pumpkins.
