Gargling sound coming from my muffler... What could it be?? (youtube link)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 808Raider, Aug 20, 2010.
  1. Aug 20, 2010 at 2:55 AM
    808Raider
    808Raider [OP] Well-Known Member
    HAWAI'I
    '10 PreRunner SR5 AC
    Bilstein 5100s @1.75, AAL TSB, Pro Comp 7089s, 265/75/16 Firestone Destination A/Ts, Debadged, Black Billet Grille, Tinted, Nerf Bars, Mudflaps Removed, AFE Pro Dry-S Air Filter, Secondary Air Filter Removed, Sock Decals,
    My 2010 is only 9 months old and I've got this ridiculous sort of gargling sound coming from my muffler when I start it up in the morning. I live in hawaii so i dont think its because its from being too cold and I have no ideas. Take a listen and maybe you can figure it out..it gets really bad around :11. Thanks in advance
    http://www.youtube.com/watch?v=r-QbJpUyGu4
  2. Aug 20, 2010 at 2:56 AM
    808Raider
    HAWAI'I
    oh and the sounds coming from inside the muffler, not like its something that is loose.
  3. Aug 20, 2010 at 3:22 AM
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    Check the entire run for loose anything. Check to make sure the heat shields are not touching anywhere. There is a welded on heat shield to near the spare. make sure it's still welded on both sides. Look for dirt rocks inside that shield too.
    Still can't find it.? When it's cold use a rubber mallet to tap different places and see if you can isolate where it's coming from. Maybe a bunch of gecko's climbed into it, and now it's just bones.
  4. Aug 20, 2010 at 12:01 PM
    808Raider
    HAWAI'I
    Thanks I'll check that out. Anyone else?
  5. Aug 20, 2010 at 1:44 PM
    tacopromatt
    tacopromatt Matt's Pro Taco
    Austin, TX
    2017 Cement Tacoma TRD Pro AT
    Could be a broken baffle inside muffler. Bang on the actual muffler w/ your fist and see if you hear anything.
  6. Aug 20, 2010 at 1:51 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    check the catalytic converter heat shields too. They can rust out at the seams and rattle.
  7. Aug 20, 2010 at 2:03 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Muffler Bearing. :anonymous:
  8. Aug 20, 2010 at 2:14 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    I have the same problem but I get the gargling in low RPMs because of the current intake/exhaust setup I have. I do not have enough air going in to come out and thats the reason why mine makes the noise... :(
    EDIT: I should have listened to the gargling before I commented lol sounds like theres something lose in the muffler. Has nothing to do with what I am talking about and the sound is completely different haha
  9. Aug 20, 2010 at 2:51 PM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    Yah brah I have it to...pisses me off
  10. Aug 20, 2010 at 3:05 PM
    JAG
    JAG Well-Known Member
    hm... take it to the dealer you are under warranty with a 2010. :) don't let them shorten your peddle though on the recall thing for the accelerator pedal.
  11. Aug 20, 2010 at 3:06 PM
    toojayz
    toojayz Well-Known Member
    Jim
    Northern NJ
    2011 TRD Sport 4x4 DC MGM SB
    lol
  12. Aug 20, 2010 at 3:20 PM
    numbah57
    kahai
    Maui, Hawaii
    Could the muffler belt need re-tensioning?
  13. Aug 20, 2010 at 3:29 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Check all heat shields and anything that might be loose like posted above. If all is good take it to the dealer and have it replaced. Or buy new exhaust.;)
  14. Aug 20, 2010 at 7:46 PM
    808Raider
    HAWAI'I
