Garmin Inreach 66i
Discussion in 'General Tacoma Talk' started by FishWolf, Dec 14, 2024.
  1. Dec 14, 2024 at 3:14 PM
    FishWolf
    FishWolf [OP] Well-Known Member
    R Something
    2011 Toyota Tacoma
    Total Chaos Urethane Upper Control Arms FOX Factory Series 2.5 Remote Reservoir Front Coilover Shocks FOX Factory Series Remote Reservoir Rear Shocks 1-1/2” Rear Lift Block Kit Nitto EXO Grappler Tires (285/70R17) Method Fat Five Wheels – Custom color (17x7) Warrior Products Front Winch Bumper w/ D-Ring Mounts & Brush Guard Wurton 5” LED Light Bar (pair) – Installed in Front Bumper Warn Zeon Winch w/ Steel Cable & Fairlead (installed in Front Bumper) Warrior Products Rear Bumper w/ Integrated Hitch and D-Ring Mounts Wurton Scout Series LED Cubes (installed in Rear Bumper) Warrior Products Bolt-On Side Steps Warrior Products Platform Roof Rack Warrior Products Platform Air Dam Warrior Products Bed Rack Warrior Products Bed Support Tie Bar for Warrior Products Tacoma Bed Rack Bolt-On Spare Tire Mount (installed on Bed Rack) Warrior Products Black Diamond Plate Aluminum Tailgate Trim Warrior Products Black Diamond Plate Aluminum Sideplates Warrior Products Black Diamond Plate Aluminum Entry Guards sPod Switch Panel and Relay Kit Borla Cat Back Exhaust System Custom Vinyl Wrap
    Just bought one of these units 2nd hand for $250, ive been eyeing the Garmin Montana etc but so expensive, this is a pretty good deal and has Inreach, maps etc. Its small but can also be carried around hiking and put on a bike etc..my question is does anyone else use this unit and whats a good mounting set up for my truck, thanks
  2. Dec 14, 2024 at 3:38 PM
    JoeMongo
    JoeMongo perennial noob
    Jonathan
    SF Bay Area
    2024 TRD Offroad Premium, MT
    RCI Rock Sliders, RCI Skidplate, Diamondback tonneau
    I've had one for several years. I have several of it's predecessors that I have used for decades. It's a great handheld (think "hiking") GPS and you can install any map set that you can find or buy, unlike most of the purpose built GPS devices.
    Download Garmin Express and Garmin Basecamp. Invest a bunch of time learning how to use each and then you can plan out whatever trip you like. The platform is incredibly powerful and also more than a little complicated. There is a way to do anything that you can think of using a GPS to do, if you can figure out how that works in Basecamp and the 66i. I usually use Basecamp to create tracks instead of routes and then just follow the track that I created or one that I found on the interweb someplace.
    If you want a mount to hold the 66i someplace in front of you on or near your dash, take a look at the RAM ball mounts. They make many many mounts and they make a specific holder for the 66i. The RAM ball connection between the mount that attaches to your dash and then connects to the 66i holder with a ball joint so that you can adjust it to face you.
    If you want to use the inReach to save your ass some day, you have to be subscribing to their monitoring service. They have many levels of service plans. I think the cheapest is $8/month.
    j.
  3. Dec 14, 2024 at 3:42 PM
    FishWolf
    R Something
    2011 Toyota Tacoma
    What a thorough reply! Ya i did some research and this seemed like a great all around unit, the trade off being small screen, but i also want to carry around fishing etc, im not sure the Montana would have worked for that, so being a small screen id like to get as close to my face as possible in truck, was the ram mounts you mentioned suction to glass or drill into dash? They probably have both
  4. Dec 14, 2024 at 4:29 PM
    JoeMongo
    Jonathan
    SF Bay Area
    There are RAM mounts and/or bases that clamp to things, both round and/or square, suction cup bases, bases that can be semi-permanently installed with double sided tape, and other methods that I can't remember right now. My favorite for inside a vehicle or on my motorcycles is to use extra heavy duty velcro. Sometimes I use velcro and also secure the base with a zip tie. I tend to do that on my KTM enduro dirt bike.
    Just take a look at the RAM ball web site and then dive down the rabbit hole that is Amazon.
    j.
