Garsha91's Chevy 63s experimentation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GARSHA91, Mar 4, 2016.
  1. Mar 4, 2016 at 3:15 PM
    GARSHA91
    GARSHA91 [OP] YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    Alright. So I finally took my leafs apart and I'm wanting to do a thread as I continue with these for bushings and equipment and just general cleaning and thoughts.
    First step was to take them apart. Started by taking the hangers off and going to clean those up and sell for a few bucks since I won't need them anyway.
    Then I took off the bolts on the u that keeps the top leafs together. I then did the center screw to take them apart completely and clean them
    This is how they sit. I'm going to soak them in white vinegar for 24 hours and then scrub any access with tinfoil dipped in the vinegar. I'm using tinfoil since it's not as abrasive as steel wool and I don't want to mess these up. Ordering some por15 for later in the process.
  2. Mar 4, 2016 at 3:15 PM
    GARSHA91
    Chicago
    Decided to experiment with the shackles and some white vinegar today
    Going to let them soak for about 27 hours and check them when I get home from work tomorrow
    Took them out after 27 hour soak
    Didn't come off as easy as I thought. New pieces will be soaking for about 45 hours before looked at
  3. Mar 4, 2016 at 3:15 PM
    GARSHA91
    Chicago
    Started the soaking process
    I did try another product as well and it worked really well I was surprised.
  4. Mar 4, 2016 at 3:16 PM
    GARSHA91
    Chicago
    The process has begun
    This was just from the angle grinder. These weren't dipped in vinegar but I don't think you really need to do it. I've exposed some metal but I'm more concerned with getting the rust gone so I'm happy. The ones soaked in vinegar should be easily to do. These are now soaking to make removing the bushings easier :thumbsup:
  5. Mar 17, 2016 at 10:38 AM
    GARSHA91
    Chicago
    So I've been working on the 63 leafs this weekend. I've tried different things to remove the rust. Fastest is the flap wheel. Hands down. I'm going to sand them by hand so look isn't terribly important right now. Plus I'm painting it with por-15 so it should be fine.
    I did try some loctite rust remover
    It did work but too much patience and effort compared to the flap wheel.
    I also tried rust remover drone Home Depot. Same review. Not as fast but still works if it's something small you want to take light rust off.
    Also white vinegar loosens it up but it takes wayyyyyy too long
  6. Mar 17, 2016 at 10:38 AM
    GARSHA91
    Chicago
    Got some work done on Easter. Process now goes:
    White vinegar soak
    36 grit flap disc
    60 grit flap disc
    100 grit on sander
    220 grit on sander
    Clean off with water then paint them.
    Haven't done the 220 grit yet
    Before and after with 220
  7. Apr 22, 2016 at 10:17 AM
    GARSHA91
    Chicago
    Finally got some painting done.
  8. Apr 22, 2016 at 10:18 AM
    GARSHA91
    Chicago
    Also if your bushings are too small you're going to need these depending on diameter.
  9. Apr 22, 2016 at 10:20 AM
    GARSHA91
    Chicago
    Here's my measurements
  10. Apr 22, 2016 at 10:22 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Did you take the inner diameter on the last pic?
  11. Apr 22, 2016 at 10:23 AM
    GARSHA91
    Chicago
    The second one is inner diameter. The last one is outer. First is width
    geekhouse23 likes this.
  12. Apr 22, 2016 at 10:26 AM
    TwoTrack
    TwoTrack Well-Known Member
    Clint
    Tampa, FL
    2005 Tundra 4x4
    Are you painting the mating surfaces with graphite paint?
  13. Apr 22, 2016 at 10:27 AM
    TacomaZL
    TacomaZL Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    Sub'd
    GARSHA91[OP] likes this.
  14. Apr 22, 2016 at 10:30 AM
    GARSHA91
    Chicago
    I'm using por 15. I also found this paint defender I wanna use on my kings and was thinking of testing it out on the leafs
  15. Apr 22, 2016 at 10:31 AM
    GARSHA91
    Chicago
  16. Apr 22, 2016 at 10:42 AM
    2nd screen name
    2nd screen name Tacodelaplaya
    Bob
    LV/SD
    06 AC Sport Prerunner
    Front: Maxtrac, DK heim UCA, 6112 Rear: AP expos, Fox 2.5 RR DSC Fn fivestar with General reds
    check out wd-40 liquid rust remover. that stuff works great. it looks like your already past that though.
  17. Apr 22, 2016 at 10:44 AM
    GARSHA91
    Chicago
    Yea. I tried a bunch of stuff but didn't workout too well. I still need to clean the other leafs and paint them. And the leafs with the u on them bc there's not enough space for what I have so gotta get creative
  18. May 5, 2016 at 4:45 PM
    GARSHA91
    Chicago
    Did some more sanding and painting. Almost there
    If you don't have one. I suggest investing in a small sander. Sooooooo much quicker
    You will also need plenty of sandpaper and flap discs
    As for painting. Use a foam brush. Leaves no brush marks or hairs. Get ones with wooden handles bc the plastic ones will poke through the foam. No good.
  19. May 5, 2016 at 4:48 PM
    pilau
    pilau Well-Known Member
    Las Vegas, Hawaii
    2015 DCSB Tacoma PR
    planning early, gotta get snacks ready!
  20. May 5, 2016 at 4:56 PM
    GARSHA91
    Chicago
    Still trying to find a good way to get in the bushing area. I have a few ideas but idk how well they'll work. Oh well. Trial and error it is
