gas and milage!!! help HELp!!
Discussion in 'Performance and Tuning' started by oscarito06, May 23, 2010.
  1. May 23, 2010 at 3:28 PM
    oscarito06
    oscarito06 [OP] Well-Known Member
    oscar
    Paramount, CA
    05 PreRunner SR5
    6'' pro comp lift,running board, Pro Comp skidplate,LED licence plate light, Interior LED personal lights,LED dome light
    after i got my life, i saw my gas milage decrease.
    on a full tank i can get 265 miles on a full tank. it holds 16gallons.
    gas here is 2.99.
    how many miles do i get a gallon?
    how can i improve it, without changing my tires. or anything else.
    i have 33''tires. 6''lift. skidplate running boards. procomp 17fuel octane wheels
  2. May 23, 2010 at 9:19 PM
    j1999t
    j1999t Well-Known Member
    Justin
    Northern Colorado
    traded it in
    our tanks hold 21 gallons...
  3. May 23, 2010 at 9:22 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    Tips to improve mileage: lose the lift, get smaller tires and less agressive ones, lighter wheels, no lead foot, drive slower on the freeway, check your oils and make sure they are maintained well, check air pressure in your tires (adding another 5 + psi would be a good idea), things of that nature will help you
    same thing i posted in your other thread.....and the gas tank is still 21, hasnt changed since the other post
    lifts create more drag and more resistance against the wind and such. larger tires have more surface area and having aggressive ones cause more rolling resistance
  4. May 23, 2010 at 9:23 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    After I got my life I went to Kindergarten , then elementary school , and finally high school . I am now a carpenter .
  5. May 23, 2010 at 9:24 PM
    08pretaco
    Oliver
    az
    hahaha....we are gonna side track this thread then he is going to post it again in another section of the forum
