Gas cap check engine light - what am I doing wrong?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SDTaco4x4, Mar 28, 2024.
  1. Mar 28, 2024 at 6:29 AM
    SDTaco4x4
    SDTaco4x4 [OP] Well-Known Member
    San Diego
    2016 Black TRD Sport 4x4
    So I started up my truck yesterday and suddenly got the check engine and trac off lights. I took it to the dealership and the first thing they asked was if I filled up gas recently since it could be the gas cap. I said no, but took a peak anyway incase it got loose somehow. To my surprise the gas cap was GONE. Some dipshit stole it. Why? Who knows, but I got a new one while I was there.
    Anyway, I looked it up online and here, and everyone says it should go away after a few cycles and to let the truck sit for a white. I've done both, including running errands yesterday, but the lights aren't going away. Is there something I'm doing wrong, before I pick up a code scanner from walmart or take it back to the dealership?
    Thanks
  2. Mar 28, 2024 at 6:34 AM
    Little Lion
    Little Lion Well-Known Member
    2018 Barcelonian Sport MT
    :anonymous:Check again to make sure wasn’t stolen again lol
    you can disconnect battery & reconnect, will clear some codes
  3. Mar 28, 2024 at 6:36 AM
    Clearwater Bill
    Billy
    Largo Florida
    Disconnect the negative terminal for a couple minutes.
    Or a parts store should have a scanner they'll use to read codes and clear for you.
    Or there could be codes that need attention.
    wilcam47 and 50Buck like this.
  4. Mar 28, 2024 at 6:41 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    About how many miles did you drive after replacing the cap? Usually have to drive about 50 miles before the codes will clear.
    As mentioned you can try disconnecting the battery to clear codes.
    Chew likes this.
  5. Mar 28, 2024 at 6:41 AM
    SDTaco4x4
    San Diego
    like maybe 20 miles, so not 50.
    wilcam47 and ToyoTaco25[QUOTED] like this.
  6. Mar 28, 2024 at 6:48 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It takes a few days for the pcm to run another self test and see the leak go away. Certain criteria need to be met before it will even run a leak test like fuel level in tank, etc
    Chew and ToyoTaco25 like this.
  7. Mar 28, 2024 at 6:50 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Get out there and lay that mother down
  8. Mar 28, 2024 at 7:05 AM
    Sig Taco
    Sig Taco Well-Known Member
    2021 Taco DCSB
    Icon Rebounds 17x8.5 Toyo 35/12.5/17 JBA UCA, Bilstein 6112/5160, KDMax
    Did you piss off someone from work?
  9. Mar 28, 2024 at 7:44 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Thanks for the gas cap, mine was beat so I just seen another taco, yours I guess, and popped it off and on to mine.
    :anonymous: Kidding. That’s sucks lol!
  10. Mar 28, 2024 at 8:16 AM
    SDTaco4x4
    San Diego
    Thanks for the help guys. So does disconnecting the battery actually help with this?
  11. Mar 28, 2024 at 8:49 AM
    Sig Taco
    2021 Taco DCSB
    Just drive it like you stole it for a few days. Driving with a check engine light never killed anyone.
    Stevie17 likes this.
  12. Mar 28, 2024 at 8:50 AM
    SDTaco4x4
    San Diego
    UPDATE: disconnecting the battery worked! Thanks everyone!
  13. Mar 28, 2024 at 9:57 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  14. Mar 28, 2024 at 9:58 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    nice! Dooley noted, thanks for the follow up!
  15. Mar 28, 2024 at 10:48 AM
    bgavin
    bgavin Well-Known Member
    Orangevale, CA
    2023 Tacoma Access Cab, V6, 4WD, A/T, OTT Medium/Spicy
    CURT Mfg front receiver, anti-theft cages around cats
    I installed a new locking gas cap supposedly correct for my 2023... and got the check light.
    I put the stock cap back in place, and drove for a week... ECM did not clear the check code.
    My friends at the local shop read the codes, saw it was emission related, and cleared the code with the stock cap in place.
    No more check lights.
