Gas cap mod
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FloridaCementTaco, Jan 1, 2022.
  1. Jan 1, 2022 at 12:29 PM
    FloridaCementTaco
    FloridaCementTaco [OP] Well-Known Member
    OEM running boards OEM bed lights OEM all-weather mats OEM chrome exhaust tip Gator soft, tri-fold tonneau cover 265/75/16 BFG KO2s Removed “chin strap” AC drain extension Rear differential breather extension Bilstein 5100 rear shocks Bilstein 5100 front height-adjustable shocks set at second height OEM tailgate remote lock
    Gas cap mod recommendations?
    OmahTako, sdshack, vivid02 and 5 others like this.
  2. Jan 1, 2022 at 12:30 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Yep, that’s exactly what I do. I don’t see a reason to spend money on anything else.
    Sdswingr, vivid02, philth and 3 others like this.
  3. Jan 1, 2022 at 12:45 PM
    eurowner
    eurowner Duke Sky
    Scoty
    @MESO for the win with his Super Wicked Awesome Gasshole and Never Dangle Again!
  4. Jan 1, 2022 at 12:48 PM
    manwithtools
    manwithtools Well-Known Member
    Dan
    So Cal - San Diego
    2021 Cement Gray Off Road
    Fox 2.5's Deaver Stage 2. 5.29's, 285/70/R17 Front E-Locker
    Yep, I do the same thing. I just hang it over the retainer, I don't see what all the fuss is about.
    philth, WCTRDTaco and Junkhead like this.
  5. Jan 1, 2022 at 12:55 PM
    WA7
    WA7 Well-Known Member
    Craig
    PNW
    2021 Trail Edition
  6. Jan 1, 2022 at 1:02 PM
    WCTRDTaco
    WCTRDTaco Well-Known Member
    2018 Tacoma TRD Off-Road 4X4
    Sdswingr likes this.
  7. Jan 1, 2022 at 1:09 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
  8. Jan 1, 2022 at 1:11 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I do the same
    WCTRDTaco likes this.
  9. Jan 1, 2022 at 1:17 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
  10. Jan 1, 2022 at 1:22 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    I’d like to know how she got where she’s going without the vehicle going up in flames or at the least, gasoline all over the place. Did the videographer think to offer her a bit of advice that this is not a good idea? Looks like she’s done this before, though. Yikes.
  11. Jan 1, 2022 at 1:24 PM
    Hobadger
    Hobadger Well-Known Member
    Mark
    2021SuperwhiteTRD4×4offroad
    Cold air intake - CAT-BACK
    Sweet Jesus, @ least she doubled up the bags! She should have just put it in a Styrofoam cups! Lol
  12. Jan 1, 2022 at 1:47 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    No that’s not Toyota’s solution that’s the door latch you’re hanging it on. Lots of people use that latch method though, been posted here many times. The little loop on the tether allows for strain relief so you don’t break it.
    i let mine hang down, a method I and others have used successfully for many years on many vehicles. :rolleyes:
    Jason TRD OR likes this.
  13. Jan 1, 2022 at 1:55 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    make sure to grease those fuel door hinges. Let those gas caps dangle.
    JGO, DingleTower and davidstacoma like this.
  14. Jan 1, 2022 at 2:00 PM
    davidstacoma
    David
    NC
    That’s a good reminder about greasing the hinges, seen a few reports of bent doors. I need to do that.
    Montana_Actual likes this.
  15. Jan 1, 2022 at 2:14 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
  16. Jan 1, 2022 at 2:21 PM
    Kyebasse
    Kyebasse Jd
    K
    21 Tacoma TRD Off-road
    It doesn’t need a mod. It doesn’t need solution. Just let it dangle. What’s so wrong with that?
  17. Jan 1, 2022 at 2:30 PM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    The “Gas Hole” solves a problem that doesn’t exist, that’s why I got one .326D7909-6E5C-44D3-9B25-D3CDB181C8BF.jpg:cool:
    RustyGreen, Superdave1.0, WA7 and 3 others like this.
  18. Jan 1, 2022 at 2:38 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    ^^Nice way to hold the cap. I suppose a lockable cap can also be put in there.
    The LiftDcustoms has the phrase "Taco Sauce Only" & "Taco" on it which is cheesy but cool.
    I just use the retainer for now and it works fine.
    E
    jwctaco[QUOTED] likes this.
  19. Jan 1, 2022 at 3:39 PM
    davidstacoma
    David
    NC
    3rd gen millennial problem:
    “WTF? I just can’t let my gas cap dangle freely in air like that! *googles gas cap holder, searches TW furiously for solutions to this devastating problem*
    Boomer problem:
    “I blew a danged head gasket! Better grab some tools and stop by NAPA. Back later honey, gotta take the car!”
  20. Jan 1, 2022 at 3:41 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I let it all hang out. Didn't cost a dime.....
