Gas cutting out while driving
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ROBBS-COMA, Apr 12, 2019.
  1. Apr 17, 2019 at 12:36 PM
    #41
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    Maybe you got some debris in there by accident, or hit that non detergent stuff a few times.:(
  2. Jun 23, 2021 at 5:28 PM
    #42
    prise
    prise AZ's Toaster Strudel Low T Andrew
    Prise
    Rally Runner 04 GX470
    I have an 07 6spd manual and I’m having this engine stall then resume issue. Started off happening every once in a while when I take a turn now it’s gotten to the point it’s every time I drive but even when I slow down to turn into a business or go over a speed bump I’ve had the engine completely die.
    New URD fuel pump and in line filter upgrade
    New CAI filter for the URD intake
    New spark plugs
    MAF and Throttle body cleaned (throttle body was gunky)
    No improvement so far gonna try this brake adjustment thing.
    Found another group talking about a power steering pressure switch as well. Thoughts?
    OP did you ever find a solution?
  3. Jun 23, 2021 at 8:16 PM
    #43
    ROBBS-COMA
    ROBBS-COMA [OP] Well-Known Member
    ROBB
    Bethlehem PA
    2008 TACOMA 4DOOR TRD SPORT 4X4
    NONE YET
    Yep, had the brake pedal adjusted, problem solved. Hope you find out what yours is...
    prise likes this.
  4. Jun 24, 2021 at 6:37 AM
    #44
    prise
    Prise
    Thank you for the info!!
  5. Jun 24, 2021 at 6:59 AM
    #45
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Bravo. @Muddinfun called it well.
