Gas fill overflow
Discussion in '3rd Gen. Tacomas (2016-2023)' started by marjamr, Jan 10, 2018.
  1. Jan 10, 2018 at 3:16 AM
    marjamr
    marjamr [OP] Well-Known Member
    Mark
    2017 Silver Tacoma SR
    Western Defender snow plow
    I have a 2017 SR 4x4 with utility package. Have filled the gas tank twice since purchase. Each time as the tank reached full and the pump nozzle shut off a significant amount of gas shot out the fill opening and ran down the side of the truck. This doesn't happen with our other vehicles when we fill up at the same pump. Is this an issue common to Tacoma’s?:confused:
    SOSC likes this.
  2. Jan 10, 2018 at 3:29 AM
    Modesto Tacoma
    Modesto Tacoma Well-Known Member
    central california
    LIMITED 4X4
    I know filling my truck there really isn't room to top it off. Are you Just letting it stop by itself or you topping it off? If it stops by itself and shoots out gas first I'd try another pump if it happens again. Take it to dealer. They will check and also fill up the tank for free while checking it lol
    inwood customs likes this.
  3. Jan 10, 2018 at 3:30 AM
    Rider4
    Rider4 Well-Known Member
    2017 Tacoma TRD PRO
    Same gas station both fill ups?
    shakerhood and 2016Tacoman like this.
  4. Jan 10, 2018 at 4:54 AM
    a400ryan
    a400ryan Well-Known Member
    Garson Manitoba Canada
    2015 SR5 DCLB
    I have a bad habit of topping it up with up to 2 extra litres after clicks off with no issue
    gargamel05 likes this.
  5. Jan 10, 2018 at 5:26 AM
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    That sounds infuriating
  6. Jan 10, 2018 at 5:33 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I know it seems offensive, but are U guys setting the nozzle all the way in and down? The fill neck did seem a bit small but I've never had any issues.
    gargamel05, 2016Tacoman and SOSC like this.
  7. Jan 10, 2018 at 5:38 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    What I was thinking. My truck doesn't do this.
  8. Jan 10, 2018 at 5:40 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
  9. Jan 10, 2018 at 5:54 AM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    My Truck has never done this in the 2 years plus that I have owned it.
  10. Jan 10, 2018 at 6:39 AM
    marjamr
    Mark
    I just hold the pump until the nozzle clicks off. I have always done that.
    Junkhead likes this.
  11. Jan 10, 2018 at 6:40 AM
    marjamr
    Mark
    No. Now that I think of it. Two diff stations, two diff pumps.
  12. Jan 10, 2018 at 6:42 AM
    marjamr
    Mark
    That’s it.
  13. Jan 10, 2018 at 6:45 AM
    xlucidx
    xlucidx Well-Known Member
    2017 TRD Off Road DBCB SB
    this was my thought.
    after the pump kicks off on me I always give it another quick shot. Never had problems spilling out.
    maybe try a different pump?
    my previous car was a G35 coupe and the way the gas filler tube thingy was made (at an angle) I actually had to pull the pump about halfway out or the pump would kick off.
    That made it very easy to over fill and spill down the side.
  14. Jan 10, 2018 at 6:50 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Offending users live in Oregon?
  15. Jan 10, 2018 at 7:17 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    If you want to treat the symptom, just slow the pump down when you get to the last gallon or two on the fillup.
    over60 likes this.
  16. Jan 10, 2018 at 7:34 AM
    05tacoalltheway
    05tacoalltheway Well-Known Member
    Brian
    2010 FJC
    I had this happen when I went up high in elevation..back down to low..back high..low again.
    Gas came out on the first fill up around 7k feet and then the next 2-3 fill ups regardless. Has not done it again though.
  17. Jan 10, 2018 at 7:38 AM
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    Many fill ups (15K miles) and I just let it click off and have never had an overflow. You have an issue and should take it in.
  18. May 15, 2019 at 4:27 PM
    Jacked Burton
    Jacked Burton Well-Known Member
    35s 4.30s 6speed TruTrac Fx Pros Bilstiens Dakars
    Tires: 35/11.5/17 Toyo AT3s Wheels: FN FX Pro Gunmetal 17s with TRD center caps Zinc Metallic lettering. Yukon 4.30 gears with TruTrac Front Suspension: OME 887 w/5100s, Freedom Offroad UCAs n Superbumps Rear: Archive Hammer Hangers,Dakar Mediums, Bilstien 5125s Ubolt flip n Superbumps, Headlights: Selfmade Retrofits URD shortshift kit Airaid CAI No name throttle controller
    Bump for more answers.
    I know mines a 2nd gen but my truck does this more than 50% of the time. Never had another car or truck that has done this as frequently.
  19. May 15, 2019 at 4:45 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    My wife’s old WRX did this, I traced it to the gas tank vent. The system needs to be closed (no venting) when running, but needs to be open & vented when you fill up. (This is the cycling you sometimes hear on the Tacoma when it’s been parked for some time). There was a purge valve on her tank that was stuck in the closed position. Could be the same thing on the Tacoma, some blocked vent line or broken purge valve. Other thing that can commonly create this is a full charcoal canister.
    DriverSound likes this.
  20. May 15, 2019 at 4:50 PM
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    51k miles on my '16 utility pack. Never an overflow, but the pump shuts off fairly close to that point, with maybe 1L of volume remaining.
    mgmdclb likes this.
