Gas flap screw
Discussion in '3rd Gen. Tacomas (2016-2023)' started by blind bernie, Jun 8, 2022.
  1. Jun 8, 2022 at 10:46 AM
    blind bernie
    blind bernie [OP] Member
    I recently purchased one of the gas cap holders for my 2017 wWhite 4x4 SR (henceforth referred to as Snowball). However, when I went to remove the screw behind the gas flap it would not come out and now the head is boogered up. What is the part number for this screw or, alternatively, what is the screw thread pitch and length so that I can drill it out and replace it?
    six5crèéd likes this.
  2. Jun 8, 2022 at 10:56 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    M6-1.0 X 10MM
    Can you put a pair of vice grips on the head and remove it?
    CusterFan likes this.
  3. Jun 8, 2022 at 11:02 AM
    blind bernie
    I tried everything that I could think of. Penetrating oil, vice grips, screw drivers. Finally the head stripped and I just need to drill it out carefully. Thank you for the screw size! I just recently got my first Tacoma after three different Z-71's spread over 14 years and I have learned so much on this forum.
  4. Jun 8, 2022 at 11:06 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Be careful with the fuel door, the hinges are pretty flimsy if you haven't already noticed. The screw in mine was really tight when I put my holder on as well. Good luck with the removal :thumbsup:
  5. Jun 8, 2022 at 12:00 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    six5crèéd[QUOTED] likes this.
  6. Jun 8, 2022 at 12:05 PM
    CusterFan
  7. Jun 8, 2022 at 1:54 PM
    TacomaBlu
    TacomaBlu Well-Known Member
    2017 TRD Sport
    6in Procomp 35in Toyo M/T 18x9 Mamba M13
    If you have a dremel make a slot (for flat head screwdriver). Heat the screw, I used a blow dryer. Should back right out!
