Gas Gauge and Starting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTom88, Apr 22, 2013.
  1. Apr 22, 2013 at 3:37 PM
    TacoTom88
    TacoTom88 [OP] Gold Member
    Corey
    Northeast Georgia
    '17 DC TRD Sport
    Was looking for some help...
    Lately my gas gauge has become very unreliable. I can fill up the tank and the next day my fuel light is on. The next day it will reflect a more realistic amount. With that problem has came my taco not cranking like normal. It will turn over far more times than it usually does and it cranks up very feeble. It is very strange. Could both of the problems be related to the fuel pump/filter?
    Any advance is helpful!
  2. Apr 22, 2013 at 4:41 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yes. The fuel pump, filter and sending unit are all integrated into an assembly. There could be an issue that would effect both the pump and the sending unit ( low voltage etc ).
  3. Apr 22, 2013 at 5:46 PM
    TacoTom88
    Corey
    Northeast Georgia
    '17 DC TRD Sport
    Thanks! I wonder how much that unit will cost... Something is definitely wrong. Would a computer hookup tell the true story?
  4. Apr 23, 2013 at 6:24 AM
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    Urd sells an upgrade kit that includes an external replaceable filter assembly. Not sure on price, but if you're gonna spend the $$$ anyway might as well go with something easily serviceable down the road
  5. Apr 23, 2013 at 6:43 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    multiple electrical/fuel issues ?
    sounds like the electrical bundle feeding the assembly
    has been pinched or otherwise compromised
  6. Apr 24, 2013 at 6:39 AM
    n1dp
    n1dp Member
    Maine
    Tacoma Access TRD Sport
    I wonder if they share a common ground of some type? Previous poster also mentioned wire bundle problems. Possible a loose connector at the tank with corrosion?
    Not sure how easy it is to access these items near the fuel tank, but worth a look.
