Gas gauge not accurate
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rjsmall, Jul 30, 2024.
  1. Jul 30, 2024 at 11:04 AM
    Rjsmall
    Rjsmall [OP] New Member
    Hi all - recently replaced complete fuel pump unit due to failure, 2005 4.0 taco crew cab. OEM unit which included sending unit etc.
    Son ran out of gas twice when needle dropped below 1/4 tank. The gauge was accurate before the fuel pump unit replacement.
    Hoping for alternative solutions rather than dropping the tank again. thanks for the help in advance.
  2. Jul 30, 2024 at 11:59 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    All you can do is test the sending unit.
    You don't have to drop the tank.
    Find the the ID2 connector.
    Test resistance of the pins 2 and 5 and see if it matches what the gauge says. - Pin 2 (Orange wire) / Pin 5 (Yellow/Black)
    [​IMG][​IMG]
    zguy1 likes this.
  3. Jul 30, 2024 at 12:18 PM
    agmason
    agmason Well-Known Member
    Austin, Texas
    2007 Prerunner 4dr LWB
    Should charge for this level of service TnShooter!
    TnShooter likes this.
  4. Jul 30, 2024 at 12:34 PM
    Rjsmall
    Wow seriously. Thank you Tnshooter!
