Gas gauge showing the wrong level
Discussion in '4th Gen. Tacomas (2024+)' started by el_turks, Jul 14, 2024.
  1. Jul 14, 2024 at 3:56 PM
    el_turks
    el_turks [OP] Well-Known Member
    Southern California
    2024 OR, 2009 PreRunner
    Just FYI, and it will be interesting if any other trucks had the same issue.
    Events:
    After driving a couple of hundred miles it was time to add more gas. I pulled up next to the gas pump and parked the truck (what actually happen was that I put the truck in reverse but since I had my foot on the brake it did not move back) and I turned off the engine. I toped the gas and turned the truck engine on (this is when I noticed that I had it in reverse). I shifted to Drive and got on the freeway. Noticed that the gas gauge showed only 86 miles to go and was low mark. I wondered what happened... did I get scammed at the pump cause I saw the pump taking my money. I stopped at the next gas station and tried to add more gas but no... the gas tank was full. I checked my bank account and yes, the charge for the gas was there. I turned my truck back on and it still showed low gas. I parked for a couple of minutes and turned it back on and no luck, still low. I said fudge it, since I had a long drive ahead of me, and sure enough as I added more miles the gas gauge was moving lower but extremely slow. I figured that it was showing the wrong gas level but trying to compute the estimated gas milage. 200 miles later I was still showing about 25 miles left on the gauge. So it was time to refill and buy something to eat at the gas station. When I restarted the truck, it was showing the right level of gas (full) and estimated miles (289). Not sure if other 2024 models had similar issues but at least you know.
  2. Jul 14, 2024 at 5:29 PM
    balong48
    balong48 Well-Known Member
    2011 Silver 4Runner Limited
    It’s a problem they still haven’t fixed on the Tundra too.
    shakerhood and el_turks[OP] like this.
  3. Jul 18, 2024 at 11:08 AM
    Enaud
    Enaud Member
    2024 Black Tacoma SR5 6 foot bed 4X4
    LED lights for camper shell
    When I bought my SR5, on the way home, the gas guage didn't move at all. I found that if you press and hold the OK button and while holding, turn on the ignition. After about 5 seconds or so, the fuel gauge will recalibrate. That fixed it for me. I've had to do it a couple other times as well, when the fuel gauge doesn't seem to be moving.
    Hope this helps.
    Whitmo58, mtip and el_turks[OP] like this.
  4. Jul 18, 2024 at 11:10 AM
    el_turks
    Southern California
    Thank you... I will try this next time it happens...
  5. Jan 22, 2025 at 11:10 AM
    CesarNYC
    CesarNYC Member
    2024 Black Tacoma SR 4x4 MT
    This happened to me today as well, fuel gauge did not change during filling and I thought something was broken. I drove off knowing that the fuel I just bought was in the tank, and in about two blocks the fuel gauge/estimated miles left corrected itself. I wonder how many people are experiencing this and how often does it happen. This is my first time and I have about 10k on my odometer.
    el_turks[OP] likes this.
  6. Jan 22, 2025 at 11:12 AM
    Bishop84
    Bishop84 Well-Known Member
    We are anticipating an update/recall for this in the near future. All the modern trucks are having issues with this. You are not alone and I can assure you they are working on something.
    They've addressed this in the past on other models.
    el_turks[OP] and shakerhood like this.
  7. Jan 22, 2025 at 2:45 PM
    SchwarzeEwigkt
    SchwarzeEwigkt Well-Known Member
    Central NY
    ‘24 Tacoma TRD Sport 4x4, Solar Octane
    There's actually a couple sections on this in the manual. It details the holding the OK button while starting the engine and keeping it held for 5s until the odometer blinks to recalibrate it. It also mentions how putting in only a small amount of fuel (whatever "small" is) may not update it and how refueling with the engine running may not update it.
    If they went to the trouble to publish it in the manual, then they definitely have known about it for a while. Seems an odd bug to choose to go to production with.
    I found this on p.96 right after the section about recalibrating the fuel level readout:
    ■ Free/Open Source Software Information
    This product contains Free/Open Source Software (FOSS). The license information and/or the source code of such FOSS can be found at the following URL.
    https://www.denso.com/global/en/opensource/meter/toyota/
    I can't help but wonder if everybody's using the same library for their gauge cluster software and there's a fundamental problem with it.
    el_turks[OP] and BearWithMe like this.
  8. Jan 22, 2025 at 5:53 PM
    CesarNYC
    CesarNYC Member
    Thanks for pointing that out in the manual, I did keep the engine running during refueling. On the other hand I put over 14 gallons in when this happened, so not exactly a small amount. Going forward I will refuel with the engine off and see if it ever happens again.
  9. Jan 22, 2025 at 6:45 PM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    Modern vehicle or older vehicle, will not show accurate fuel level if you leave it running, must cycle the key to get correct level reading...
  10. Jan 23, 2025 at 7:23 AM
    el_turks
    Southern California
    Out of the 70 times I have added fuel to my truck this has happened twice. The second time I noticed this, I was not as worried as the first. Yet, I hope they fix this on this expensive truck.
  11. Jan 23, 2025 at 8:57 AM
    SchwarzeEwigkt
    Central NY
    Every car I've ever had besides this Tacoma has updated the fuel gauge and estimated range normally if I fill it with the ignition on. I've watched the gauge climb and the numbers increase.
    Honestly, I don't understand why this ever even came up. Fuel level readings are a problem that was solved more than a century ago and range calculations aren't exactly higher mathematics.
    pAP and el_turks[OP] like this.
