Gas Gauge Stuck On Full ?
Discussion in 'Technical Chat' started by mavic517, Mar 18, 2010.
  1. Mar 18, 2010 at 4:13 AM
    mavic517
    mavic517 [OP] Member
    tampa florida
    1999 toyota tocoma
    1999 Tocoma: It appears it is stuck. Backround Info:
    I have not filled it up in many months, usually only put
    5 to 7 dollars in it......so the gauge was always around the last 1/4 mark. Last week I filled it up, and I mean
    filled it up, all the way to the top. The gauge moved up,
    all the way up, PAST the full mark. Now, since filling it
    up, I have driven around 45 miles, and the gauge if not
    moving.
    Question(s):
    What could be causing this?
    Is there a fuse that controls the gas gauge?
    Thanks for your help !
  2. Mar 18, 2010 at 4:22 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    It could be stuck- but if you put THAT much gas in it- Might just be that it was that far past the top.
    I think I go about 60-70 miles before my scion registers any fuel usage when I full it really high.
  3. Mar 18, 2010 at 4:24 AM
    mavic517
    tampa florida
    1999 toyota tocoma
    Thanks, I will wait intill I drive more. Is there a fuse that could have blown?
  4. Mar 18, 2010 at 4:26 AM
    crittergitter
    crittergitter Proud to be Canadian Navy
    Stu
    Shearwater, NS
    '06 Tacoma 4WD Double Cab
    Bugger, skid plate, colour coded cap, bed mat, AFE Air Filter, Rear diff breather mod, Chirp on door lock;unlock, ABS mod, Weathertechs front and rear, 60" Hi-lift jack, LED light mod in rear bed, 12V accessory in bed, n more stuff.
    There could be corrosion formed at the top of the sending unit and when you filled it really full it may well have stuck. As Brunes said drive it for awhile and see if it is just overfull otherwise you may have to drop one of the straps and loosen the other and try and jar the tank enough to free the sending unit up.
  5. Mar 18, 2010 at 4:31 AM
    mavic517
    tampa florida
    1999 toyota tocoma
    Thanks for the info. !!
  6. Mar 18, 2010 at 4:34 AM
    rme
    rme Well-Known Member
    Savannah
    Green TACOMA
    XM, Panasonic Stereo, Headlights,Electric Ant,Toyota Deluxe Wheels, Rhino Lining, Cargo Rails
    I got a 95 and when I fill it the brim I usually have to drive about 60 miles before it will start to move. I sure hope its not a sending unit....check the price if don't believe me....ouch.(My sending unit is bad)
  7. Mar 18, 2010 at 4:39 AM
    mavic517
    tampa florida
    1999 toyota tocoma
