Gas Hog?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JCNiest5, Dec 18, 2016.
  1. Dec 18, 2016 at 10:08 AM
    JCNiest5
    JCNiest5 [OP] Active Member
    JV
    2018 Toyota Tacoma TRD Off Road 6' Bed
    Hello all! Just got myself a new '15 Tacoma TRD Sports and I'm a little surprised on how much gas it uses. On a full tank, I only get about 250 miles (give and take). Is it because it's winter and super cold here and I usually warm up my truck until it's warm before driving? I think it's a 16 gallon tank? That's like 15 MPG, that's horrible to me. It's using more than a Tundra with a 5.7L engine with more than 300 HP. Unless my idling consumes a major part of the gas, I think this truck is a lemon.
    What's your thought(s)?
  2. Dec 18, 2016 at 10:16 AM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    Just some interesting facts below......
    Your tank is 21.1 gallons.
    The 5.7 tundra has 383 HP.
    And you are literally idling away most your fuel to get the car warm. Ive done it before. It will be around zero outside for a week and if i warm it up to steady state temperatures each time (6 days in a row) it eats a quarter tank of fuel just doing that. that and a combination of winter fuel is what is causing the problems.
    Also your truck is really only going to get between 15-18 mpg in the winter.
    There is nothing wrong with the truck from the sounds of it.
  3. Dec 18, 2016 at 10:26 AM
    JCNiest5
    JV
    Okay, thanks for the reply. A little happier now, at least. Just had to vent out at the low MPG I'm getting (compared to the dealer sticker on the window). I hope it's just the winter (warming up the truck, winter gas, the cold temperature, etc).
    I've just realized there is a long thread about this already. Too eager to post without reading/searching.
  4. Dec 18, 2016 at 10:29 AM
    Mossyjaws
    Mossyjaws Well-Known Member
    VA
    2015 dclb
    Footprint Gas Pedal
    Sounds normal to me. Mileage on these trucks varies greatly with the conditions. Around town about 15.5 for me with no warm up time. 100% highway I have seen 20....a couple times. I am disappointed if I compare it to a full size in terms of mileage vs power. Really like these trucks and have had a thing for them for 25+ years. While there are many appeals to the Tacoma fuel mileage is not one of them.
  5. Dec 18, 2016 at 10:37 AM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    Sounds about right for the Tacoma. Our trucks are not know for excellent gas mileage, my son has a 2017 Tundra that gets 15.5 mpg which is slightly less than what I get
  6. Dec 18, 2016 at 10:42 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Have you done the math and actually figured your fuel mileage. Depending on how I drive mine, and how close to empty I push it I'll get 250-375 miles on a tank. But that number means nothing. With my normal every day driving I average about 17 mpg. On the open road 19-20 mpg is the norm and under ideal conditions I've gotten as much as 22 mpg on a few tanks.
    A Tundra will get 13-14 mpg in everyday driving and at best 18 mpg on the road. The fuel mileage difference isn't huge, but enough to matter. I bought my Tacoma to have a smaller vehicle to maneuver around tight spots, not for fuel mileage, that is why the Honda is in the driveway.
    The size of the fuel tank can be misleading too. The Tundra has a much larger tank and which may help to create the illusion of better fuel mileage. My F-150 has a 36 gal tank and gets almost exactly the same fuel mileage as the Tacoma. But being able to go 600 miles between fill-ups makes it seem much better than it is.
    RBTaco likes this.
  7. Dec 18, 2016 at 10:45 AM
    JCNiest5
    JV
    Hmmm...Now I'm starting to feel a little remorse about getting the Tacoma when I should've gone for a Tundra. I like the comfy ride and everything auto on the Tundra. Not even a Power Seat for my Tacoma Sports.
  8. Dec 18, 2016 at 10:46 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Fill tank , drive , re-fill tank , miles travelled divided by fuel put back in
    ta da
  9. Dec 18, 2016 at 10:48 AM
    JCNiest5
    JV
    I will just ride it out and find out the MPG in the summer. It's very cold here in MN.
  10. Dec 18, 2016 at 10:51 AM
    Blahma
    Blahma Well-Known Member
    Montana
    2017 Tacoma TRD Off Road Double Cab LB
    My new 2017 has about 550 miles on it and I tracked the last tank and only got 11MPG. Granted it is cold and 4x4 has been engaged the the whole tank given all the snow we have had. Hope gets better. Will continue to track it.
    JCNiest5[OP] likes this.
  11. Dec 18, 2016 at 10:52 AM
    JCNiest5
    JV
    OMG!!! I'm freaking out even though it's not my truck! Aaaa!!!!!!
    Mush Mouse likes this.
  12. Dec 18, 2016 at 10:58 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    if you were looking for fuel economy should have gotten the 2.7l 4 cylinder bout 22mpg on winter fuel and 23-24 mpg on regular gas
  13. Dec 18, 2016 at 11:00 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    That's right around what I get with my 4.0 in the winter. It spends about 80% of the winter in 4x4 due to ice and snow. The extreme cold doesn't help either.
  14. Dec 18, 2016 at 11:02 AM
    Pigpen
    Dan
    Northwest Montana
    Fuel economy blows during engine break in.
  15. Dec 18, 2016 at 11:03 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    How are you figuring out what mileage you are getting?
  16. Dec 18, 2016 at 11:11 AM
    JCNiest5
    JV
    Empty tank (gas light on). Fill it up. Reset Trip A to Zero. Drive until gas light comes on again. Divide Trip A mile by how many gallons it took to fill up the tank. I thought it was 16 gallons, but another poster said it's 21.5, so it's even worse than the 15 MPG I thought I got... 11.63 MPG! OMG! I'm freaking out now!
  17. Dec 18, 2016 at 11:15 AM
    Pigpen
    Dan
    Northwest Montana
    You should only be dividing by the number of gallons you put in, not the volume of the tank. If you have bigger than stock tires, you need to account for their actual size. This will give you an approximation of mpgs. Even if you fill up at the same pump every time, you're calculations won't be exact.
  18. Dec 18, 2016 at 11:17 AM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    Maths are hard - but gas is cheap.
    def67 likes this.
  19. Dec 18, 2016 at 11:24 AM
    OZ-T
    Peter North
    British Columbia
    reefnfeef likes this.
  20. Dec 18, 2016 at 11:33 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Wear a jacket in cold weather. My Tacoma, with temps in the high 20's will be up to normal temperature within 2 miles driving city streets.
