Gas in oil
Discussion in 'Technical Chat' started by jrowell09, Apr 21, 2016.
  1. Apr 21, 2016 at 9:33 AM
    jrowell09
    jrowell09 [OP] New Member
    Jonathon
    2006 Tocoma base
    3 in body lift.
    Hi all,
    I'm new to this forum, But I Have a 2006 Tacoma with the 2.7l, I just did an oil change right before my wife left to go out of town with the truck. After the oil change I checked the oil level and it was right on the full mark, well my wife drove the truck about 600 miles and she decided to check the oil and believe it or not it was about 3 inches above the full mark, and she said it had a strong smell of gas. A buddy of mine told me that his did that and it was the fuel pressure regulator had went bad and it was pulling gas through the vacuum tube. Has anyone else ever had this issue before.
    Thanks in advance for any help.
  2. Apr 21, 2016 at 9:40 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
  3. Apr 21, 2016 at 11:05 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    3" is quite a bit. Pull the hose and see if it is wet with fuel, it should be bone dry.
