Gas light quit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco 422, May 9, 2021.
  1. May 9, 2021 at 9:40 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    For anyone interested it isn't a bulb type light it is an LED soldered to the combination meter circuit board...
    Rick's 2012, JGO and Key-Rei like this.
  2. May 9, 2021 at 10:17 PM
    Taco 422
    Taco 422 [OP] Well-Known Member
    USA
    Gen 2 AC v6 TRD SR5 Prerunner
    The problems are: the light seems to be intermittent, I can't go off mileage as I work around the farm.
    When wrapped up in tasks, having the light pop on is a friendly reminder to fill up before heading to town.
  3. May 9, 2021 at 10:57 PM
    Waasheem
    Waasheem
    2007 xrunner
    I’ve had vehicles that the gas gauge didn’t work. There’s a little button poking out of the gauge cluster. If your odometer is showing the vehicle mileage, press and let go of the button, it’ll show trip A mileage. Press and let go it’ll show trip B mileage. Press and let go, your back to vehicle mileage. Press and let go, you’re back in trip A, press and hold it down until it reads O. How I made sure to never run out of gas was every fill up, I’d zero the trip meter. Then when the trip meter climbs close to the mileage when you run out of gas, you know you need to put gas in it. So for example, you zeroed the trip meter when you filled up, you ran out of gas, the trip meter said 200 miles, you know you need to put gas in BEFORE 200, even better to leave yourself a cushion of error and fill up at 190. Pretty fool proof method to never run out of gas, lights working or not. Even though my gas gauge and lights all work, I zero my trip meter and calculate mpg at every fill up. Miles driven / gallons pumped = mpg.
    Where you work has nothing to do with mileage. Unless, for example, you live halfway up a mountain. You have 2 job sites, one at the bottom of the mountain and one at the top of the mountain. On the days you work at the bottom of the mountain, you’re flooring it to make it to work on time, and need to be home by a certain time so you’re flooring it up the mountain home. On the days you work at the top of the mountain, it doesn’t matter what time you start or get home so you drive gently up to work and coast down the mountain home.
    Please forgive my ignorance, I’ve never worked on a farm, so maybe there’s something there that causes miles per gallon and miles driven per tankful to vary.
  4. May 9, 2021 at 11:43 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I know!
    Get a 5 gallon Jerry Can and keep it filled in a bracket in the bed so when you run out of gas you can use it to get to a gas station.
    Yukon DoIt and JGO like this.
  5. May 10, 2021 at 12:04 AM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Although you are not wrong and I do agree, I would add that letting your tank get so low that odds of sucking up debris is greater than with a full or even a half full tank.
    Kind of like putting 100 tadpoles into a 1 acre pond, or those same 100 tadpoles into a 5 gallon bucket. Take a small dip net in each and see what your odds are.
  6. May 10, 2021 at 4:59 AM
    JGO
    JGO Well-Known Member
    South Central Kentucky
    '14, 4 Cyl, A/T, Silver A/C
    My gas gauge has not worked for months. I use trip counter "A" resetting it every fill. When it went bad I took my average MPG multiplied it by fifteen and when the counter gets to around 350 miles, I start to look for a Shell station..
  7. May 10, 2021 at 5:03 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I'm happy if I can get over 200 miles out of a tank.
    Heck I think the best I ever did when I was bone stock was like 265.
    JGO[QUOTED] likes this.
  8. May 10, 2021 at 5:15 AM
    JGO
    I have four, drive 70/30 highway/city and drive like the old man that I am. My average of a year is 24.9, calculating every month to get a stable mileage estimate. No gas gauge makes me rather cautious; it drives Mrs JGO nutty and she tells me I'm nutty for not fixing it. She may be right, I maybe crazy but it just maybe a lunatic she was looking for.
    [Credit to Billy Joel.]
    Jimmyh, Boyk1182 and Key-Rei[QUOTED] like this.
  9. May 10, 2021 at 5:33 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Light or no, does your truck not have a fuel gauge?
    I would have thrown a 5 gallon can in the bed. There is no task that is so distracting that I would ignore a basic need like that. I mean, I admire your work ethic, but take care of yourself first, OP.
  10. May 10, 2021 at 3:14 PM
    Taco 422
    USA
    I get it, it's new rear bumper and swingout time.
    dirtnsmores and Jimmyh[QUOTED] like this.
  11. May 10, 2021 at 4:18 PM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    Be sure to get gas about 20 miles sooner than normal after installing that bumper :rofl:
    Taco 422[QUOTED][OP] likes this.
  12. May 10, 2021 at 4:22 PM
    Boyk1182
    Boyk1182 Well-Known Member
    Northern Colorado
    Based on the first post, 20 miles sooner is good advice regardless of parts.
  13. May 10, 2021 at 4:23 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Dude, fix your truck before adding toys.
    That's like going out to buy new tires after it blows a head gasket.
    :cookiemonster:
    dirtnsmores and whatstcp like this.
  14. May 10, 2021 at 4:52 PM
    Taco 422
    USA
  15. May 10, 2021 at 5:01 PM
    #35
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Is it just the light or does the needle not work either?
  16. May 10, 2021 at 5:06 PM
    #36
    Taco 422
    USA
    The gauge is functional (reacts to a fill, drops predictably).
    I added the backstory to the OP for reference.
  17. May 10, 2021 at 5:07 PM
    #37
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Sprig likes this.
  18. May 10, 2021 at 5:16 PM
    #38
    Taco 422
    USA
    I was waiting for it to turn green.
    The stop sign?
    Yeah, man.
    Steves104x4[QUOTED] likes this.
  19. May 10, 2021 at 8:56 PM
    #39
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Try keeping gas in your tank.You will be replacing a burned up fuel pump the way you are currently doing things.
    Rick's 2012 likes this.
  20. May 10, 2021 at 9:36 PM
    #40
    Taco 422
    USA
    Never would have guessed.
