Gas light to full only 13 gallons
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jrkuehn38, Nov 13, 2018.
  1. Nov 13, 2018 at 10:10 AM
    Jrkuehn38
    Jrkuehn38 [OP] New Member
    Jordan
    07 double cab long bed
    4” fabtech lift. 33x11.50.
    Just bought a 07 Tacoma double cab long bed and replaced the motor. Now that I’m driving it I thought it just got horrible gas mileage but when I went to fill up it only took 13 gallons. It went from the gas light to full with only 13 gallons and gas gauge isn’t jerking or anything. Stuck float or what? Thanks in advance.
  2. Nov 14, 2018 at 5:10 AM
    96carboard
    96carboard Well-Known Member
    Mine gives me about 15.5 gallons from full to light on. You sure you filled it up all the way? They could also have made adjustments after 2007, so it might be helpful if somebody else with that year could chime in on this.
    I've never looked in the fuel tank on a tacoma, but on other vehicles where I have, the low fuel sensor was separate from the float, so it couldn't be a stuck float impacting it. At least on those vehicles.
  3. Nov 14, 2018 at 5:15 AM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    Tanks are barely over 21 gallons on these trucks. Gas light comes on with around 4 gallons left. So in theory based on my experience you should be able to put around 17 gallons in if you gas up right when the light comes on. Filling up at around 1/4 tank you should only be able to squeeze in around 13 gallons like you did.
  4. Nov 14, 2018 at 5:19 AM
    Clearwater Bill
    Billy
    Largo Florida
    What was the needle position when the gas light came on?
    PintSize likes this.
  5. Nov 14, 2018 at 5:21 AM
    96carboard
    They're actually in *metric*, so 60 liters to the light, 80 liters to dry. At least in theory. The plastic does bulge a bit under the weight of fuel, so in practice, you can get more than 80 liters into it if its dry. I've pumped as much as 84 into it -- without running out.
  6. Nov 14, 2018 at 5:25 AM
    azzwethinkweiz
    Tucson, AZ
    Agreed. I've had scenarios where the pump has said I've pumped amounts just starting into 22 gallons but I know there are other factors at play like pump accuracy and like you said the plastic tank being able to expand slightly.
  7. Nov 14, 2018 at 5:26 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Does it matter?
    Norton, b_r_o and henryp like this.
  8. Nov 14, 2018 at 5:28 AM
    96carboard
    If you want to get nice round numbers, yeah. But it also gives you a bit of insight into the numbers they picked.
  9. Nov 14, 2018 at 5:31 AM
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    Should come on around 17 +/-
    If you've lifted the truck then you may have the front or back higher or lower which would cause the tank reading to be off.
    ejl923 and TerminatorStout like this.
  10. Nov 14, 2018 at 5:35 AM
    jowybyo
    Joe
    Baltimore, MD
    Still have to convert it to gallons since we pump gas in gallons and that’s what this topic is about.
    Anyway carry on. I just hate the metric system so that’s my own personal problem.
    Rick's 2012 and Norton like this.
  11. Nov 14, 2018 at 5:37 AM
    Clearwater Bill
    Billy
    Largo Florida
    Since the truck comes with a rake new, does having the much acclaimed 'level lift' mess up the fuel gauge reading?
    Is there a corrective mod for that?
    Level lift and big tire aficionados need to know! :goingcrazy:
    henryp and PackCon like this.
  12. Nov 14, 2018 at 5:39 AM
    96carboard
    While I do have my own issues with metric units, liquid volume isn't one of them. Sure is nice not to have to guess between US, Imperial, and Chinese gallons.
    Its also very funny when you try to interpret Chinese lengths, because their foot is the same (I think?), but they have 10 inches in a foot.
  13. Nov 14, 2018 at 5:40 AM
    96carboard
    Well I can tell you this; sometimes when I start mine in the morning, the gas light will be on, but when I back it off my driveway, it goes off.
  14. Nov 14, 2018 at 5:45 AM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    I have put 19 gallons in my 2013 before and the light was not on at the time I filled it.
  15. Nov 14, 2018 at 6:03 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Before you freak, this needs to happen on a few tanks before you worry.
    If its just one tank it could be a number of flukes. If its consistent then start going down the list of things it could be starting from easiest to harder:
    Engine air filter
    Air up the tires or buy new ones if their bald
    Spark plugs
    Cleaning sensors
    Checking your brakes
    Buying a new gas cap
    Also if you can find an ethanol free gas station run till you are on fumes abd then fill up. Run two to three tanks. If your mileage still blows... something is up.
    Winter blends in gas may have started in a lot of areas and they have a higher ethanol content which ruins fuel economy.
    I just got my first 17mpg tank... winter blend blues start :tumbleweed:
  16. Nov 14, 2018 at 6:05 AM
    Clearwater Bill
    Billy
    Largo Florida
    (It was a joke) ;)
    Norton, b_r_o and Jimmyh like this.
  17. Nov 14, 2018 at 6:23 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    The OP's question is not about fuel economy. The question is about the "low fuel" light on the gauge, and the amount of fuel he can add to the tank at that point.
    Sterling_vH111 and blu92in99 like this.
  18. Nov 14, 2018 at 6:28 AM
    djthicks
    djthicks Well-Known Member
    Orange County
    07 DCLB TRD Sport
    King's all around Long traveled Methods KO2s
    I have an 07 DCLB also and get around 13ish from light on to full also... truck does have a little rake so that off reading theory makes sense
  19. Nov 14, 2018 at 6:56 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    There is nothing funny about metric/imperial conversions
    When I fill my tank until the pump clicks off, I'm "theorizing"
    When I convert gas volume from imperial to metric to Chinese I'm "using math"
  20. Nov 14, 2018 at 7:02 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    13 seems very low. I pump in about 18-19 gallons and get about 200-220 per tank lol
    Sterling_vH111 likes this.
