Gas lock cap recommendations
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kevrev1735, Aug 18, 2021.
  1. Aug 18, 2021 at 1:12 AM
    Kevrev1735
    Kevrev1735 [OP] New Member
    Kevin
    2016 Toyota Tacoma trd off-road
    I have a 2016 Tacoma trd off-road. Just bought a gas cap lock last week had no problems until today driving home from work. My TRC off light and check engine light was on. Anybody know a gas lock cap that doesn’t trigger any lights on the dash at all.
  2. Aug 18, 2021 at 2:01 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I haven't seen a locking gas cap that you can't grab with pliers push down really hard on and twist off.
    I would just stick to OEM no problems and effectively just as secure.
    If you really feel the need to lock your cap I would drill into the door and get an all weather cabinet lock and cut a slot in the fender flare for the tang.
  3. Aug 18, 2021 at 4:02 AM
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
    Or maybe just cut the head off a cabinet lock & stick it on with 3M tape. (A mock up of a locked door.) Gas thieves will look elsewhere.
    vivid02 likes this.
  4. Aug 18, 2021 at 4:14 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    In modern vehicles it is all but impossible to steal gas anyway, you can't get a hose into the tank. Put the factory cap back on it and don't worry about it.
  5. Aug 18, 2021 at 4:34 AM
    tonyreo
    tonyreo Well-Known Member
    Tony
    N.E. Ohio
    Yes, I thought Toyota has a "screen" inserted into the neck of the tank so a hose can't be inserted.
  6. Aug 18, 2021 at 4:43 AM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    Yes, they have something inserted in the neck of the gas cause I tried to siffon some with a hose to fill my gas mower up and could not get it in all the way.
  7. Aug 18, 2021 at 5:00 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I've got the start locking gas cap which has been fine so far...had it for 1 1/2 years now. In my case its not a matter of someone low life siphoning my gas, but dumping some nasty chit in your tank. We've had vandalism on my road every year. If they can't get into your tank...they'll move on to the next target, or in my case kick in my mailbox.
  8. Aug 18, 2021 at 5:07 AM
    Nirango kid
    Gilles
    Ontario
    Yeah, low life fuckers have nothing else to do but vandalize other peoples properties for kicks or whatever reason they have.
  9. Aug 18, 2021 at 5:20 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I have a Stant P/N 10504 locking gas cap. Toyota Canada sells this exact part as a Toyota accessory at the dealer parts counter at twice the price, P/N C0170-00020.
    A wave rake is cheaper and easier to conceal than channel locks. Hell the gas door itself with its thin wire hinge can be pried open very easily. Either solution is just a low-security deterrent against tampering.
    Key-Rei[QUOTED] and zoo truck like this.
