Gas milage?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TCB2020, Nov 3, 2023.
  1. Nov 5, 2023 at 8:07 AM
    #41
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    It was only 15 miles of driving, but interstate speeds of 70-75mph -
    Flat arizona highway - I can get this kinda mileage often.
    I think the key is getting up to speed steady as she goes - maintaining the speed -
    As evidenced by several, it can be done.
    TacoSR523 likes this.
  2. Nov 5, 2023 at 8:07 AM
    #42
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Is that hand calculated or are you trusting the readout on the dash. IME the numbers on the dash are almost always optimistic. In some cases less than 1 mpg. Other vehicles are off by 2-4 mpg and always high compared to hand calculated. Even for a 3rd gen 26 mpg seems too high. I could believe 22-23, maybe 25-26 occasionally under perfect conditions.
    My 2007 4X4 DC with a cap will usually be right at 20 mpg hwy. For normal every day driving 16-17 mpg. I have gotten 22 on one tank under ideal conditions in mountains where I wasn't able to get over about 55 at any time and there were long downhill stretches where I could coast.
  3. Nov 5, 2023 at 8:19 AM
    #43
    19992021Taco
    19992021Taco Well-Known Member
    1999 and 2021 Tacoma
    Haha I was thinking the same thing. I's actually usually around 17.5 - 18 and I am not light on the gas pedal. Overall I don't stress on the MPG, but since I drive a lot I do pay attention...
  4. Nov 5, 2023 at 5:23 PM
    #44
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Au gratin with cheddar
  5. Nov 5, 2023 at 9:07 PM
    #45
    axxkicker
    axxkicker Well-Known Member
    brett
    Unbelievably, Alabama
    2018 Tacoma TRD Off Road
    I have a 2 inch lift and 285s. I average between 15 and 18, depending on highway speeds and idling time. 26mpg would be magical.
  6. Nov 5, 2023 at 9:23 PM
    #46
    czukie
    czukie Well-Known Member
    Colorado
    ‘23 Tacoma Access Cab
    2016 TRD Sport AC w/ 2" lift, E-range AT's size 275/70/17, and 600 pound camper with KD Max tune: 16-17 mpg
    2017 TRD Off Road DCLB w/ no lift, E-Range KO2's size 275/70/17, and 300 pound camper (vagabond) with OTT Tune: 18-19mpg
    2023 TRD Off Road AC w/no lift, C-Range Duratracs size 265/75/16, and 175-200 fiberglass topper with no tune (yet): 19-23mpg
    All of this is at around 6k ft of elevation and about 25% of which is mountain passes. Mostly using 87 gasoline, but will occasionally fill up with 85 if I'm staying above 8k ft for a while
  7. Nov 5, 2023 at 9:27 PM
    #47
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The Manual only comes in 4x4
    RedWings44[QUOTED] likes this.
  8. Nov 12, 2023 at 5:54 PM
    #48
    Nixin
    Nixin Turbo Gang
    OC, Ca
    Black 24 TRD ORP
    That actually seems pretty good
  9. Nov 12, 2023 at 5:56 PM
    #49
    Nixin
    Nixin Turbo Gang
    OC, Ca
    Black 24 TRD ORP
    I typically get 19.5-20.5mpg per tank, but I do notice that when I actually do the math, Tank trip mileage divided by gallons of gas filled, its always around a half gallon MPG lower than what the screen says
  10. Nov 12, 2023 at 5:58 PM
    #50
    Nixin
    Nixin Turbo Gang
    OC, Ca
    Black 24 TRD ORP
    I feel like if you spent an entire tank driving highway in ideal conditions you could top out at 28 max, absolute max.
  11. Nov 13, 2023 at 4:54 AM
    #51
    Barryo56
    Barryo56 Well-Known Member
    Barry
    White TRD Off Raod
    none
    ^ speed manual and I've never gotten above 21MPG, usually 19-20.
  12. Nov 13, 2023 at 5:48 AM
    #52
    1dayKapaa
    1dayKapaa Well-Known Member
    Northern VA
    2019 Tacoma DCLB
    14.8 checked yesterday. I’m on 35x12.50MT.
  13. Nov 13, 2023 at 6:45 AM
    #53
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    23 ish running secondary roads 25-50 mph.
    17 ish running interstate 65 mph.
    I tend to run 5 over but am pretty gentle stopping and starting.
    My truck idles a lot and tank avg isn’t as good.
    Small lift and 285/75/16s, ARE cap also.
