Gas Mileage: 400+ per tank - Good?
Discussion in 'Performance and Tuning' started by ShaneHD, Feb 15, 2011.
  1. Feb 16, 2011 at 7:21 AM
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2016 F150 Lariat 4x4
    5100s (2.5" front), OEM Raptor wheels, 315/70/17 BFGs, Undercover, tint, Weathertechs.
    This is almost identical to mine. 60ish it dips below full, and 110-120 I'm at the 1/4 tank. Then 180-200 half tank, 250-275 3/4 tank, and 320-340 as the light comes on (17ish gallons). I never get the 400 before the light comes on though.
    I drive 72 on the highway almost exclusively. Light to moderate acceleration, etc. Not a hypermiler but I'm conscious of the gas gauge. But in KS, with all the driving I do, 60 mph just isn't going to happen. I'm satisfied with still pulling 19-20 mpg with my driving style. What pisses me off is when I don't change my driving style but get 16-17 (winter, ethanol, etc). Best I've gotten was 22.5 in the mountains of CO, as crazy as that is.
  2. Feb 16, 2011 at 7:34 AM
    ink junky
    ink junky I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
    They're just jealous OP.
    :p
  3. Feb 16, 2011 at 7:35 AM
    bfaisok
    bfaisok Active Member
    Bryan
    Texas
    06 Tacoma
    ToyTec ultimate lift, ProComp 7032, GY Wrangler Silent Armor 265/75/16, ARE MX cap with windoors/sliding windows and roof rack, Aluminess front bumper, AFE air cleaner, scored a intermitent wiper switch from salvage
    I just did a bunch of mods and came down from 400 to 330 before the light came on. It was my first tank since the mods so I will be keeping my eye on it. I found that before the mods to get 400 a tank I had to keep it below 68-70 with low RPM shifts, 68-70 was like a sweet spot.
  4. Feb 16, 2011 at 7:39 AM
    ink junky
    TACO LOVER
    TEXAS
    OK GUY, if my calculations are correct you aren't even getting 300 miles to the tank :p
    Just converted km to miles
  5. Feb 16, 2011 at 7:42 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    You guys need to realize a couple things.
    1) Looks like the OP has no weight carrying mods
    2) Mostly freeway driving
    3) He goes slow, he is the one you people get mad at for going under the speed limit :p
    Now from the posts I have read, everyones got lifts, tires, ect and have commutes (from my perspective) that are not all freeway driving. So with all the additional mods and city driving you all do, its simply impossible to achieve his numbers.
    And I also agree with the rest of the people that say post up the MPG not the miles per tank...who knows, for all we know you could be driving the tank to bone dry and filling her up with 20-20.5 gallons which would make your MPG 20, 19.5 instead of filling up right around the light 16-17 gallons, 25-23.5 MPG.
  6. Feb 16, 2011 at 7:50 AM
    cvillechopper
    cvillechopper Jackass to the masses
    Charlottesville, VA
    '24 DCSB TRD Off-Rd, Premium Package
    Console lock-box, Studly Driver
    Unfortunately there is one flaw in how you are reporting these numbers. You say that you get roughly 100 miles per 1/4 tank. Have you actually made it to 400 miles on a tank or are you extrapolating from the 1st 3/4 tank? the marks are inexact and have different drop rates so the gas used to get to the first 1/4 tank mark does not necessarily equate to the gas used to get from the 1st to the 2nd, etc.
    Also, what gusotto seems to be trying to say, if in an unnecessarily rude way, is that you really only get a true measure of mileage using the mpg. It's the average so driving differently at different times does not effect the number. It's still going to look at the entire tank's worth of driving. People fill up at different times (some fill up with 1/4 tank remaining, some go 20 miles past the E mark) so calculating mpg is the best comparison.
    that being said, getting 400 miles out of a tank is quite an accomplishment. The fact that it's mostly highway driving at a steady and reasonable speed is why it's so high.
    EDIT: looks like some folks beat me to the punch while I was typing.
  7. Feb 16, 2011 at 8:17 AM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    2001 Tacoma 4X4 SR5 Extended Cab
    Sorry if you took it the wrong way but I just wanted to catch your attention.
    MPG is the only way to figure gas mileage as the fuel tank indicator drops different, depending on position of the float.
    Running a tank until almost empty isn't very wise because if the fuel pump is in the tank, it needs the fuel around it to help cool the pump.
    All you are doing by running to almost empty is using up the life of the fuel pump. People forget the pump needs the cooling of the surrounding gas.
    Replacing a fuel pump isn't cheap.
  8. Feb 16, 2011 at 8:20 AM
    SuperWhiteTaco
    SuperWhiteTaco Well-Known Member
    Kevin
    So Cal
    '11 SW Prerunner DCLB
    4" Camburg Spindles, 5100's, 285/70/17 Terra Grapplers, 17x9 XD Addicts, Window Tint, Seat Covers, Flowmaster 40, Debadged, 6k HID's
    hahaha damn im pullin like 320 a tank thats crazy. well im always goin 85 on the freeway hahaha:rolleyes:
  9. Feb 16, 2011 at 8:24 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I average 18.5 MPG , calculated in US gallons in my V6 DCLB .
    Impressive numbers if accurate OP.
  10. Feb 16, 2011 at 9:10 AM
    ShaneHD
    ShaneHD [OP] Taco Tuesday
    Fort Worth TX
    2010 Tacoma CrewCab TRD
    Like I said, I have gone 425miles without filling it up again. Sure I may have been under a gallon of gasoline, but it does it.
  11. Feb 16, 2011 at 9:22 AM
    cvillechopper
    Charlottesville, VA
    So that works out to just over 21 MPG. Not unheard of for highway miles. I'm averaging right around 18.6 for the life of my truck (keep every receipt then put the data into a spreadsheet) and have had a few tanks averaging over 20.5 on the highway when loaded down. It's still pretty damn good but the fact that you're taking the gas down to the limit is really the main driver.
    Like gus said, there's potential for wear on the fuel pump doing that regularly. My main concern is that you have no idea when you'll run out of fuel taking it past the E. Hope you carry a gas can...
  12. Feb 16, 2011 at 9:25 AM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Essex county NY
    23 trd OR DCSB 4x4 silver
    a cross on my rearview Circle mirror Scotch guard seats
    Most I have gotten was 368 miles.
    That was with on 19 gallons to fill.
    I could have rode an extra 40 miles I guess on the last two gallons but I am not sure where tank turns from empty to dry.
    I think on mine the fuel guage is not prefectly consistant (or our tanks are shaped like some sort of hour glass):
    First 1/4 about 100 miles
    2nd 1/4 about 80 miles
    3rd about 110 miles
    last 1/4 about 130 miles (but think i have fuel left for an extr 40 miles)
  13. Feb 16, 2011 at 10:31 AM
    Sheepshead45
    Sheepshead45 Well-Known Member
    NC
    PreRunner SR5
    Last time I filled up it was at 403 miles, took 18.3 gallons = 22mpg.
    I still had a couple of gallons left, so I could have gone roughly 440 miles before running it dry.
    This is a 2010 prerunner 4cyl 5 speed manual, 75% highway.
    Backing into the math, you have to get at least 19 mpg to hit 400 miles on a tank, and that's running it dry. 4X4's, 6 cyl, and slushboxes probably won't get there.
  14. Feb 16, 2011 at 10:35 AM
    OZ-T
    Peter North
    British Columbia
    Since I started keeping track with Gas Cubby in November , I average 18.5 MPG in a V6 , 4x4 , auto . Rural driving , hardly any highway , and some 4x4 in snow .
  15. Feb 16, 2011 at 10:37 AM
    #35
    PB65stang
    Patrick
    Kansas City
    Agreed, I can get 19 or so pretty easily in my 4x4 DCSB auto.
  16. Feb 17, 2011 at 9:34 AM
    #36
    ShaneHD
    Fort Worth TX
    325 miles with 1/4 tank left!
  17. Feb 18, 2011 at 7:46 PM
    #37
    ShaneHD
    Fort Worth TX
    Filled up today. Light had come on 10 miles before I filled up....and had 426.2 miles on the tank.
    Not bad!
  18. Feb 18, 2011 at 7:55 PM
    #38
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    i got 400 once all highway 70mph. fully loaded too with 4 people and the bed FULL
  19. Feb 18, 2011 at 7:55 PM
    #39
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    wow, im jealous..Most of the time I cant go over 200 miles in a tank before fill up.
  20. Feb 19, 2011 at 11:30 AM
    #40
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    just did my first oil change last weekend since i got my truck and have had an INCREDIBLE improvement in mpg. I was gettin around 17mpg before, and now I'm at half a tank left and 205mi on the trip. thats 22.7mpg!!!
    i hope i can make it to 400 this tank, and every one there after
