Gas Mileage Dropping
Discussion in '1st Gen. Tacomas (1995-2004)' started by rjstubbs, Oct 30, 2013.
  1. Oct 30, 2013 at 10:47 AM
    rjstubbs
    rjstubbs [OP] Bama Dude
    Bama Dude
    On the road...
    2001 Tacoma
    Occasionally wash
    I recently relocated to Iowa from Alabama in my 2001 2.7L Tacoma X-Cab. My engine light has never been on since I bought the truck new in August 2001. Three weeks after i arrived in Iowa my engine light came on and has not gone off. I just rolled over 220K on this truck and I have never had any major issues with it. My gas mileage was 25 mpg and as of yesterday has dropped to just above 18 mpg. Any Ideas?
  2. Oct 30, 2013 at 11:08 AM
    Madjik_Man
    Colorado Front Range
    Have Autozone or someone read the codes for the check engine light (free service). It'll let you know what your engine is thinking. Would be a good place to start.
  3. Oct 30, 2013 at 11:16 AM
    rjstubbs
    Bama Dude
    On the road...
    2001 Tacoma
    Occasionally wash
    I did and the codes were P1135 and P1130.
  4. Oct 30, 2013 at 11:49 AM
    Inverno4
    Inverno4 Well-Known Member
    Baltimore, MD
    2020 DC Off-Road MT
    Sounds like an A/F sensor, which is your upstream sensor. Gas mileage also gets slightly worse this time of year because of the winter gasoline mix.
  5. Oct 30, 2013 at 1:45 PM
    rjstubbs
    Bama Dude
    On the road...
    2001 Tacoma
    Occasionally wash
    Been driving this truck for 12 years through all four seasons, hot, cold, and everthing else. The engine light has never been on before and my gas mileage has always been between 24 and 26 mpg.
  6. Oct 30, 2013 at 2:25 PM
    Madjik_Man
    Pretty sure Alabama doesn't use winter gas mixes because you don't get many cold front/heavy air masses in the region.
    I'm not a meteorologist, so I could be wrong.
  7. Oct 30, 2013 at 2:42 PM
    rjstubbs
    Bama Dude
    On the road...
    2001 Tacoma
    Occasionally wash
    That makes sense, I will check it out. Thanks for the advice.
  8. Oct 30, 2013 at 2:48 PM
    Manwithoutaplan
    ID
    Sell the truck and get a Prius.
  9. Oct 30, 2013 at 2:49 PM
    iJDub
    iJDub Well-Known Member
    If you're AF sensor is bad it'll cause your MPG to suffer.
  10. Oct 30, 2013 at 4:47 PM
    Inverno4
    Baltimore, MD
    2020 DC Off-Road MT
    I assumed since he said he moved to Iowa, they used winter gas blend there.
  11. Oct 30, 2013 at 4:50 PM
    Madjik_Man
    Yeah, I responded to him to inform him that Iowa is probably different than Alabama.
  12. Oct 30, 2013 at 4:50 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    From another thread:
    You are probably better off replacing the A/F sensor. Winter gas shouldn't cause the check engine light to come on. If you want to buy the part online, look for an "upstream" sensor. Lowest-cost part on RockAuto is NTK Part # 24669 for $130.
  13. Oct 31, 2013 at 2:21 PM
    rjstubbs
    Bama Dude
    On the road...
    2001 Tacoma
    Occasionally wash
    How difficult is it to replace the A/F sensor?
  14. Oct 31, 2013 at 2:39 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Iowa uses high ethanol fuel, which will make your fuel mileage drop also...
    Corn is meant for human, and animal consumption... Not for our trucks...
  15. Oct 31, 2013 at 8:59 PM
    KenLyns
    Belly of the Beast
    Most difficult part tends to be unplugging the electrical connector. Then you just unscrew the sensor from the exhaust pipe with a box wrench:
    http://www.4x4wire.com/toyota/4Runner/tech/O2_Sensor/
