gas mileage going from 31X10.5 to 32's or 33's
Discussion in '1st Gen. Tacomas (1995-2004)' started by gsanderson, Nov 21, 2009.
  1. Nov 21, 2009 at 10:22 AM
    gsanderson
    gsanderson [OP] Member
    Nashville, TN
    95.5 Tacoma X-cab 4X4
    I have a v-6, 5spd extended cab... currently replacing rear leafs with 4 leaf pack but not sure how much lift that will give as not specfied... if not what I want I will add new shackles to add 1.5" or so more...
    replacing the rear leaf because they are sagging...
    Will then install my billy 5100's and add the 2.5" that I can get from the shocks, if that matches or is less than the rear...
    Not sure what the 31X10.5 will look like with this lift but I may want larger tires...
    Those that have gone up in tire size what does it do to your gas mileage?
    I mainly drive highway to work ever day so I do not want to kill my mileage... currenlty get 20mpg consistently...
  2. Nov 21, 2009 at 10:32 AM
    rustyshakelford
    rustyshakelford Well-Known Member
    Brett
    Magnolia, TX
    i just showed my truck on my build thread (rustyshakelford) and i did a 3" from toytech and im running 31x10.50x15s. check out the pics and let me know if you want some better ones. I like the way it looks but when the tires wear out, ill go a little wider instead of taller
    brett
  3. Nov 21, 2009 at 10:43 AM
    gsanderson
    Nashville, TN
    looks good... If I get that look with 31's then that will be fine with me...
    What paint did you use on the wheels as I would think about doing the same...
  4. Nov 21, 2009 at 11:22 AM
    rustyshakelford
    Brett
    Magnolia, TX
    i went to autozone and bought rust-oleum high performance wheel paint. I sprayed them with simple green and scrubed them down, quickly sanded them, primered them and finally painted them. the paint runs very easily so use it lightly and do several coats. i bought two cans and still have some left over after doing all four wheels, rear bumper and grill.
    brett
