Gas Mileage Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Keenolife, Nov 27, 2015.
  1. Nov 27, 2015 at 11:15 AM
    Keenolife
    Keenolife [OP] Member
    Columbus, MS
    2015 Grey Tacoma TSS
    Plastidip'd emblems
    So I drive 2015 Toyota Tacoma TSS 4 x 4. When my truck was stuck I was getting about 15/18 mpg. Then I got New 17 inch you hostage wheels and bigger tires, 285/70 R/17, my gas mileage drop to about 14/17 MPG with my old wheels strapped down in the bed of my truck. A few days ago I decided I wanted a new Flowmaster muffler with dual exhaust. Currently I'm driving down to Texas from Mississippi and I just gassed up and I did the math and I got 11 mpg highway. Does anybody know if my new Flowmaster with dual exhaust pipes is the reason for this significant drop in gas mileage?
    lemons likes this.
  2. Nov 27, 2015 at 11:31 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Are you compensating for the bigger tires when figuring mileage. Your current tire has about 7% greater circumference compared to factory tires. Meaning your odometer is reading about 7% less. If your odometer is showing you drove 300 miles, you actually drove about 321 miles. You're probably getting better fuel mileage than you think.
    That would partly explain the drop from 15/18 down to 14/17. I have no clue why you are suddenly getting only 11 mpg hwy.
  3. Nov 27, 2015 at 1:13 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    So I've had a very notable loss of 1-2mpg's since it got cold. About the same time I switched to 8" wheels instead of the factory 7" wheels.
    Early morning drive TO work when it's cold my MPGs showing on my meter are much lower than my drive home. All that being said though my Fuelly account tracks my MPGs and it's noticably dropping the last 3-4 fill ups.
    The change to 17" 285's isn't without side effect though!!
    I used to get 19-20MPGs over all with just a K&N Air Intake mod.
    After adding skids, aftermarket wheels, and cold weather I'm doing about 17MPGs now.
  4. Nov 27, 2015 at 6:41 PM
    Keenolife
    Columbus, MS
    Plastidip'd emblems
    Thanks Marshall that makes so much more sense now. My next question, is there a way to re calibrate my odometer to compensate for the bigger tires?
    Kyitty, that's one of my next mods is a k&n cold air intake.
  5. Nov 27, 2015 at 6:56 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    From experience I can tell you the only difference is... loud. Over 3k RPM is loud.
  6. Nov 28, 2015 at 7:59 AM
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
    Fill your truck with 91 or above and the-check. Made a difference in mine.
  7. Nov 28, 2015 at 8:01 AM
    Clearwater Bill
    Billy
    Largo Florida
    Noisemaker. Save your money.
    Kyitty likes this.
  8. Nov 28, 2015 at 8:34 AM
    Tacoma005
    Tacoma005 Well-Known Member
    Bellingham, WA
    2005 DCSB TRD Off-Road 4X4
    KMC Crank Rims, 30" Baja Designs light bar, HomerTaco front grill
    On a recent road trip I set my cruise control at 60mph at left it for almost the entire trip. 24.7mpg I got that day, and thats with the 4.0L V6. If I stomp on the gas my mpg will go way down. On average I get about 17/20mpg.
  9. Nov 28, 2015 at 9:27 AM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    I agree. I've considered removing mine but I don't want to deal with it. Personally I found it to be a PIA to install.
