Gas mileage problems with 06 Tacoma V6
Discussion in 'Technical Chat' started by pl87pll, Jul 30, 2011.
  1. Jul 30, 2011 at 7:10 PM
    pl87pll
    pl87pll [OP] Member
    Preston
    Georgia
    06 Tacoma 4wd Access Cab
    K&N Cold air intake,Dual exhaust Magna Flo.
    I have a 2006 Tacoma Access Cab v6 4wd 6 speed manual and a few months ago I got a dual exhaust magno flow put on my truck hoping to get better gas mileage, but instead I am getting worse gas mileage now. I also have a K&N cold air intake. Before I put any of those on I was getting around 310 miles on a tank. Now I am averaging around 260 a tank. I was mainly wondering why this is happening and if its time to change the spark plugs out or get a tune up, I just hit 71,000 miles. Or mainly if theres anything I need to do to keep my truck running good. Appreciate any tips, thanks.
  2. Jul 30, 2011 at 7:21 PM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    You're on the pipe too much. Lay off the loud pedal
  3. Jul 30, 2011 at 7:21 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    X2
  4. Jul 30, 2011 at 7:29 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Spark plugs should be changed every 20-25 thousand miles. http://www.tacomaworld.com/forum/technical-chat/30479-how-spark-plug-change-1-gr-fe.html
    I don't have any experience with k&n intake systems, but I heard they wont do much or anything for hp gains or MPG's for 2nd Gen trucks.
    A exhaust system will also just about do nothing for hp and MPG's, the only thing it will just about do is make your truck sound better. They do a lot for older cars, but modern cars...not so much.
    Change the plugs, see if that helps, also run some injector clearer through, clean the MAF senor, clean the throttle body. If that doesn't do the trick, then you may want to try putting on your old air intake and or exhaust.
  5. Jul 30, 2011 at 7:30 PM
    pl87pll
    pl87pll [OP] Member
    Preston
    Georgia
    Haha, trust me Ive tried driving slow and easy for a couple of full tanks and still no difference...
  6. Jul 30, 2011 at 7:37 PM
    PAlittlematty
    Beech Creek, PA
    I miss my taco
    Not slowin down. Its when ya shift. No more than 2k rpm. I gained almost 2 mpg just by doin that
  7. Jul 30, 2011 at 7:38 PM
    pl87pll
    pl87pll [OP] Member
    Preston
    Georgia
    Thanks bakotruck for the info. I will definetly look into that, I just recently got out of the marines, used to be stationed in 29 palms, CA and now im back in georgia and I was just wondering if elevation factors with the air difference could be affecting this also?
  8. Jul 30, 2011 at 7:44 PM
    pl87pll
    pl87pll [OP] Member
    Preston
    Georgia
    Ok Ill try that also, I usually go close to 3k
  9. Jul 30, 2011 at 9:15 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Intakes and exhaust simply don't increase mpg.
    More air needs more gas to make more power, but not using more power doesn't use less gas than stock.
    http://www.fuelsaving.info/power_economy.htm
    Higher altitude usually means better mpg. Thinner air means lower wind resistence along with less power.
  10. Jul 30, 2011 at 9:22 PM
    kcbmx
    kcbmx doing my thing.
    Marco
    Bakersfield CaLiFoRnIa
    2tr-fe 4wd
    spit cup, weathertech floor mats, riffle rack, and bilsteins.
    there's your problem lol, seriously keep it under 2k and i think youll see a difference...
  11. Jul 30, 2011 at 9:23 PM
    jjw1
    jjw1 Well-Known Member
    Jesse
    Citrus County Florida
    2011 Super White DCSB TRD OR PreRunner
    Weather Tech Floor Liners, Truxedo Bed Cover, OEM Silver Step Bars, Debadged, Colormatched Satoshi, Wet Okoles, OEM Roof Rack, Bed Mat, Locking Gas Cap, and removed Mud Flaps
    I think so. Last Summer we were out in AZ and we were looking at buying a used Jeep to put behind the RV but my uncle said it wasnt a good idea because something with the throttle body and the intake due to the elevation and thickness/thinness of the air
  12. Jul 30, 2011 at 9:26 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
  13. Jul 30, 2011 at 9:56 PM
    pl87pll
    pl87pll [OP] Member
    Preston
    Georgia
    Alright awesome , appreciate the info.. one more thing.. what would be the best air pressure for 265/75/16 tires?
  14. Jul 30, 2011 at 10:11 PM
    06aztaco
    06aztaco Screw you guys, I'm going home.
    Cole
    Phx AZ
    06 Prerunner 2.7
    I would bet the duals are hurting, these engines need stock backpressure for scavenging effects.
  15. Jul 30, 2011 at 10:17 PM
    pl87pll
    pl87pll [OP] Member
    Preston
    Georgia
    I was thinking that also, my brother who works for lockheed being an aero. engineer or some crap like that was trying to explain to me the same thing what your saying.
  16. Jul 30, 2011 at 10:45 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I would think if changing the exhaust would make gas mileage go up, then the engineers at Toyota would have done that before the truck went to the dealer to be sold.
    I think that if you want to increase performance or mileage on a late model vehicle, then it needs to be a package deal. Change the exhaust for more airflow, then have to change the intake as well, change the intake, now you need head work and new camshafts, new programming for the computer, etc.
    Not against modding a vehicle, but I have done small things in the past and it usually doesn't pay off for me in terms of cost of operation. All I would expect from an exhaust is a different sound.
  17. Jul 30, 2011 at 10:47 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I can second the below 2K rpm shifts. Makes a big difference for me. It's a boring way to drive though.
  18. Jul 31, 2011 at 4:28 PM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    Changing the exhaust to the dual system changed the back pressure. It most likely improved power at the expense of gas milage. Most add on mods are usually for power not gas milage as I think you are finding out. Todays vehicles are factory tuned for the best gas milage they can get to meet state and federal regulations. Several years ago one of the GM divisions I think was Pontiac tried every gas savings devices on the market and they found they had very little or no impact on gas milage and often decreased the gas milage. For more power there are lots of things you can do but at the expense of gas milage.
