Gas Mileage Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by santa4x4taco, Sep 18, 2016.
  1. Sep 18, 2016 at 4:10 PM
    santa4x4taco
    santa4x4taco [OP] Well-Known Member
    just wondering what could be wrong..im not doing anything different and havent even put my new tires on, but my gas mileage went from 20-21 mpg to now about 16-17. i do hear a clicking type noise every once in a while tho, could it be the cvs or that cat? not sure
    i have billy 5100s set at .85 and everything really that i have read is saying that lift wouldnt necessarily cause a drop in mpg, that it is the size of the tire that would. i mean im expecting to be around 16-17 when i put my new tires on, im just wondering why my gas mileage has gone down with nothing being changed? anyone know what could be the issue?
    thanks for any input
    car78412 likes this.
  2. Sep 18, 2016 at 4:29 PM
    10trdtaco
    10trdtaco American Infidel *DON'T TREAD ON ME*
    Shayne
    Lynchburg, VA
    2010 Tacoma TRD Sport DCSB
    4" lift 33-12.50-17 Atturo Trail Blade M/T 17" HELO TRD Satoshi Blackout Grill Tinted headlights with caliraised led headlights ... More to come
    What motor? Auto or 6speed? Clicking could just be the notorious taco tick... need more specifics... tire size could definitely be a factor I get 16mpg and I drive like a grandma... plugs been changed? Air filter condition? Gas being used? ...
  3. Sep 18, 2016 at 4:46 PM
    santa4x4taco
    4.0 V6
    Auto
    doesnt sound like an engine click or anything..almost metal on metal, pretty sure its cvs tho
    regular unleaded
    air filter changed with oil change 500 miles ago
  4. Sep 18, 2016 at 5:02 PM
    10trdtaco
    Shayne
    Lynchburg, VA
    Ok good and good ... I use premium and notice a slight change... seafoam every month in your gas to clean out fuel system, when were the spark plugs changed last? ... metal on metal ... hmmm if it's the cvs, any vibes? Patterns with the noises?
  5. Sep 18, 2016 at 5:06 PM
    santa4x4taco
    just bought it in july..havent checked spark plugs..but i will now. and yea noise is with accelerating and turning while accelerating. i wouldnt necessarily say theres vibrations tho i guess there might be a little. either way would cvs even be a cause for gas mileage?
  6. Sep 18, 2016 at 5:47 PM
    10trdtaco
    Shayne
    Lynchburg, VA
    I'd check wheel bearings/hubs first... those are known for going bad... your mileage at 16/17 doesn't sound that bad to be honest ... how long have you owned the truck?
  7. Sep 18, 2016 at 9:35 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Just throwing this out there. Does your clicking stop when the brakes are applied? I just had a clicking that would increase with speed. For some reason my front passenger side caliper was holding too much pressure on the brake pads. They were dragging on the rotor and clicking when the rotor would make a full rotation. The sound would dissapear when brake pressure was applied. I pulled the assembly apart, pressed the caliper pistons back in and reinstalled everything. Clicking stopped and everything seems to be working fine again.
    10trdtaco likes this.
  8. Sep 19, 2016 at 1:29 AM
    10trdtaco
    Shayne
    Lynchburg, VA
    This could effect mpg's lol
