Gas Mileage Sucks After Big Tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wheel-less, Oct 7, 2019.
  1. Oct 7, 2019 at 12:48 PM
    Wheel-less
    Wheel-less [OP] Member
    So I had new tires installed and a 4" lift. Went from 245's to 285's. Also went from 24.6mpg to 19.2mpg. 90% of my daily is on the freeway. looking to improve my gas mileage. I've read about chips, throttle sensors, better driving habits, tire pressure. i'm not sure i will find a way to improve my mileage, just asking if anyone with similar mods has found success? thanks
    broke_down likes this.
  2. Oct 7, 2019 at 12:49 PM
    SpeySquatch
    2016 TRD OR DCSB
    Only option that will/may help is OVtune. Problem is those wide/heavy 285's. The mpg's you are getting with those oversize tires is actually pretty darn good
  3. Oct 7, 2019 at 12:50 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    19.2 isn’t terrible considering your mods.
  4. Oct 7, 2019 at 12:51 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    19 mpg with 285s and a lift is good, could be way worse.
    TFly, Gunshot-6A, Driftfish and 4 others like this.
  5. Oct 7, 2019 at 12:54 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Are you just using the trip computer values or hand calculating? The trip computer is not calculating speed or mileage accurately with the change in tire diameter.
    The larger tire contact patch (extra traction) and the gearing changes caused by a larger diameter tire work against mileage.
    Driftfish and salmonmigration like this.
  6. Oct 7, 2019 at 12:56 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Once you do what you did to the truck you should stop caring about MPGs. Adding armor will make it worst, I get 15/16 on a good day. Smiles per mile now
    Mr-Paul, Gunshot-6A, PapaRee and 9 others like this.
  7. Oct 7, 2019 at 12:58 PM
    Sandman TRD
    Sandman TRD Well-Known Member
    Indy
    2018 Black DCSB TRD Off Road 4x4
    I didn’t even get 19mpg stock! I’m lucky now if i get 16+ with my 265/70/17s. Mostly city driving for me.
  8. Oct 7, 2019 at 12:59 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    I’m sorry if this sounds cheeky, but of course if you change the weight and torque ratio you’ll see mileage adjustments. You can return to stock I suppose. Good luck.
    Post a pic a 4” lift is atypical.
  9. Oct 7, 2019 at 12:59 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Scratchin' 19 or 20mpg's is still pretty decent. Oh, & Welcome to TW. :hattip:
  10. Oct 7, 2019 at 1:00 PM
    mauigrown
    mauigrown Well-Known Member
    2011 4x4 DCSB TRD sport
    You could gut out your interior, maybe even take off your bed for some weight reduction :notsure:
    SandyTaco4x4 likes this.
  11. Oct 7, 2019 at 1:01 PM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    I get like 16mpg lol. If you want good mpg you bought the wrong vehicle
    OffroadJet, GillyLink, BRFab and 5 others like this.
  12. Oct 7, 2019 at 1:12 PM
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    I get 19 driving like a snail. When I lifted and put big tires on my 4Runner I went from 18.6 to about 13mpg. I'd say you are getting good gas mileage for the mods. Also if using the computer mileage it might be off just a bit due to the tire size (you are traveling greater distance than it thinks ;) )
    GillyLink and SandyTaco4x4 like this.
  13. Oct 7, 2019 at 1:15 PM
    Brofessor
    Brofessor Well-Known Member
    Mod it back to stock?
  14. Oct 7, 2019 at 1:18 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Just go back to stock and enjoy your god like mpgs and boring truck.... or deal with the drop in mpgs and continue to drive a kick ass modded truck.
    Choices choices.
  15. Oct 7, 2019 at 1:38 PM
    My Name is Rahl
    Time to regear and rethink your patriarchal brainwashed notion of "good gas mileage"
  16. Oct 7, 2019 at 2:19 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    I’m doing worse on 265’s
  17. Oct 7, 2019 at 2:22 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    I get 19.9 mpg highway wtf w my stock tires/suspension wtfff
    ozpall, camillethetoy and Shelf Life like this.
  18. Oct 7, 2019 at 2:24 PM
    Stocklocker
    17TRDORDCSBAT
    MPG matter very much when travelling long distances without services. That’s not easy to do in many places (gas stations everywhere), but in others it’s a big concern (try the Canol
    Road, NWT etc). One reason I run 265’s is I don’t want to tow a fuel tote like the 4Runner peeps.
  19. Oct 7, 2019 at 2:24 PM
    broke_down
    broke_down highly opinionated with little experience
    2010 Green Tacoma Extended Cab
    Nope. Thats what I have done to my rig and thats the gas mileage I get. I think 60% of the threads on this forum are about this topic - no one has come up with a solution. Smaller tires would fix it. hehehehe.
    You could add a row a Elon's batteries under your bed and mount a 100hp electric motor between your engine and trany as an assist. You would probably get 40-50mpg if you did that. Thats the best solution I've come up with.
  20. Oct 7, 2019 at 2:26 PM
    BarcelonaTom67
    BarcelonaTom67 Lost in Translation....
    Tom
    Laurel County, Kentucky
    2017 Barcelona Red Off-Road DCSB M/T
    My 2017 Off Road is bone stock, still the original factory Goodyear tires. I have 43K miles, all highway so far. You can see in my .sig that even at 19 MPG, you're getting better than I ever have.
    Da Boogie Man, alexplb and Dryfly24 like this.
