Gas Mileage Sucks After Big Tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wheel-less, Oct 7, 2019.
  1. Oct 8, 2019 at 8:04 PM
    #41
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Did you take into account that the larger tires throw off the speedometer & odometer.....and the computer spot out mpg?
    I’m averaging 19 mpg overall with the v6 and keeping unnecessary idling to a minimum. That’s logging the miles and gas.....the computer has never been right. The other day it's reporting 22 mpg, I used 10 gal and had driven less than 200 mi.
  2. Oct 9, 2019 at 3:36 AM
    #42
    lynyrd3
    Bill
    East Central Upstate NY
    As the title states - yes ,yes it does .
    Chew likes this.
  3. Oct 9, 2019 at 3:37 AM
    #43
    lynyrd3
    Bill
    I need to program my UltraGauge for MPGs o_O
  4. Oct 9, 2019 at 3:40 AM
    #44
    lynyrd3
    Bill
    My UltraGauge says 67 mph when my speedometer says 71
  5. Oct 9, 2019 at 3:58 AM
    #45
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    pics please of a 4-inch lift.. tks
    Chew and lynyrd3 like this.
  6. Oct 10, 2019 at 1:22 PM
    #46
    Adventuredude
    Adventuredude New Member
    Dana
    2015 double cab TRD
    Stock,for now...
    I went from 265/75/16 to 285/75/16 as well, 30" to 32" in plain English.
    Went from 16-17mpg or so to 12-15mpg.
    I might just go back to stock size, for.my own needs I'm not sure I need that compromise.
    I asked Discount Tire about going back to stock. 2 employees felt it was my 3"lift causing the mpg drop and not tire size.
    I think they are crazy, as I feel it is all in the tire size. But curious what others think?
  7. Oct 10, 2019 at 1:26 PM
    #47
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Probably somewhat of a combination, losing aerodynamics and adding rolling weight to the vehicle. Most of us do it all at the same time so hard to tell which plays the bigger role (I'd assume tires, but just guessing). I average 15 mpg with 3" lift and 33s.
  8. Oct 10, 2019 at 1:27 PM
    #48
    Boss hoss
    Boss hoss Well-Known Member
    Richard
    Silverton Oregon
    2021 TRD OR premium access cab.
    Carpet bed liner and Matt, fuel wheels KO 2 tires. Bilstein 6112,5160 frt. lift .white with black leather seats.
    Pay to play as the saying goes.
  9. Oct 10, 2019 at 1:35 PM
    #49
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    :annoyed:
  10. Oct 10, 2019 at 1:37 PM
    #50
    Tacoma_SR5Pro
    Tacoma_SR5Pro Well-Known Member
    '16 SR5 Pro
    19mpg with 4" lift and 285s?
    Consider yourself lucky. I get 16mpg with a 6" lift and 285s.
    The lift does more damage than the tires because of the significant increase in drag.
  11. Oct 10, 2019 at 3:39 PM
    #51
    Hofmann’s Tacos
    Hofmann’s Tacos Professional Asian
    Nor Cal / South FL
    2020 off-road 6MT (SFOB 2.0)
    SFOB 2.0
    Basically, the lift hurts your highway mpg, and big tires hurt city mpg.
    Ol'gray mare likes this.
  12. Oct 10, 2019 at 6:41 PM
    #52
    AZF1504x4
    AZF1504x4 Well-Known Member
    That’s about equivalent of asking Jiffy Lube tech about actual mechanical sh!t. :D
    Boghog1, hfjeff and cosmicfires like this.
  13. Oct 10, 2019 at 6:48 PM
    #53
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    My wife buys the gas. I'm not sure if she would even notice if I went from 18.5 to 14. I'm definitely getting a lift, tires and a badass front bumper.
  14. Oct 10, 2019 at 7:00 PM
    #54
    torsf_tw
    torsf_tw Well-Known Member
    2017 OR DCSB
    I didn't see much of a difference on street driving going from stock to 33, but on the freeway it's running at higher RPM's. I've not really tried to figure out the drop in MPG though.
    Going up a hill at highway speed? Oh boy it's sucking wind and burning gas. Gonna re-gear as soon as I can afford it next year.
  15. Oct 10, 2019 at 7:02 PM
    #55
    Bishop84
    Bishop84 Well-Known Member
    Remove the mirrors and tape off the rad like nascar.
  16. Oct 10, 2019 at 7:52 PM
    #56
    Ol'gray mare
    Ol'gray mare Well-Known Member
    West, Tx
    2017 MGM DCLB TRD OR Geared, locked and tuned, rear disc brakes. 2018 TRD PRO White boss' bone stock
    Build thread coming soon.
    Put a Garmin gps in your truck. Use the mileage from the gps and the gallons when you fill up. You will be surprised when you check your mileage, I was. I make high speed runs on the freeway (75-85 mph) then hit the lease roads, with long periods of idle time on location then high speed run back to home. Getting 17½ to 18½ every day. 3"lift 285-75-16 ko2's e range, full armor, diamond back & front runner rack.
  17. Oct 10, 2019 at 8:03 PM
    #57
    sparechange
    sparechange Well-Known Member
    Snoqualmie, WA
    2016 DCSB OR
    second hand lift, fuzzy dice
    Lifted mine 3 inches a couple months ago and kept the 265's on till they wear out..no change in mpg, still getting the same 16 ish as before
  18. Oct 10, 2019 at 10:09 PM
    #58
    BillyToy
    BillyToy Well-Known Member
    PNW
    2017 Tacoma TRD Pro 6MT
    I'm looking at 265/75/16 KO2s now that my stock tires are at 40k and winter is coming.
    Only reason KO2s is BFGR on sale at Costco for $120 off. $750ish mounted and balanced. Sound decent?
    Change my mind.
    Token anti- thread hijack: what do you think mileage will do from stock?
  19. Oct 10, 2019 at 10:14 PM
    #59
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    The 265/75/16 ko2s only come on E-Rated as far as I know, so I think you’ll see a bigger hit than I did with 265/70/17 C-rated K02. The e-rated 16”s are heavy.
    I believe with your tire choice most people see a 2-3 mpg drop, but others with direct experience should chime in.
    BillyToy[QUOTED] likes this.
  20. Oct 10, 2019 at 10:15 PM
    #60
    BillyToy
    PNW
    I could live with that.
    Is that why you went with the 70s? Now ya got me thinking. Do I care about 70 vs 75 AR? Maybe I don't enough to pay more for gas...
    Hey. Fuck me, I'm on topic!
    Addendum: I just realized, you've got me thinking about new rims now too. Damn you!
    Stocklocker[QUOTED] likes this.
