Gas Mileage vs Weather Changes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sabre170, Nov 8, 2019.
  1. Nov 8, 2019 at 7:09 AM
    sabre170
    sabre170 [OP] Well-Known Member
    Drew
    -2016 2WD Tacoma V6
    "Winter" months have started to show up in Texas. Oddly, I've noticed that like flipping a switch, my gas mileage has dropped about 4mpg highway over the past 3 weeks. Almost like clockwork with some cold fronts that passed through.
    Curious if anyone else notices their gas mileage effected this much by changing weather.
    I realize that I'm now in the months of "winter blend" fuel, and winter blend fuel does get worse gas mileage, but I'm noticing a 15-20% decrease in mileage. That seems a bit extreme just for gas blend changes, no?
  2. Nov 8, 2019 at 7:14 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Historically my mpgs drop by several. For me, probably multiple factors adding up.
    • Winter blend fuel
    • Using remote start (sparingly, but still)
    • Longer warm up times burn more
    • It's dark earlier, when I use my truck, I'm taking shorter trips (more city driving)
  3. Nov 8, 2019 at 7:36 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Winter blend fuel just dropped my truck from around 22 down to 20.
    Lucifer1, MoneyMan55 and SDTaco4x4 like this.
  4. Nov 8, 2019 at 7:39 AM
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    this is my first "texas winter" with a tacoma and I just noticed this. i was 16ish city im 13 14 now.
    Lucifer1 likes this.
  5. Nov 8, 2019 at 7:39 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Winter fuel. Bingo!! Always good for a couple in my cars. Tacoma down 2 MPG or so.
  6. Nov 8, 2019 at 7:45 AM
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    For sure there is decline in MPG in the winter, especially so if you do a lot of short trips where it takes half of the trip just to get up to temp. My daily trip to the gym is 3.9 miles through town. In the summer I'll average about 19.5 - 20 MPG if I don't get stopped by a train. Winter time, same trip runs at 16 - 17 MPG. On longer trips with more time at running temp it's not as noticeable, but still the winter gas drags it down about 1 MPG.
    Chew and Lucifer1 like this.
  7. Nov 8, 2019 at 7:49 AM
    sabre170
    Drew
    haha... this was actually my first thought. Tire pressure is all good.
    Yeah, 90% of my driving is on the interstate. I usually get 22-24 on the highway. I'm now getting 18-20
    I'm shocked winter fuel blend can make this big of a difference.
    InfernoChalupa likes this.
  8. Nov 8, 2019 at 7:52 AM
    SDTaco4x4
    SDTaco4x4 Well-Known Member
    San Diego
    2016 Black TRD Sport 4x4
    I don't know if it's a thing with these engines but my truck HATES winter gas. I also see huge MPG drops that I've never seen with any other vehicle.
    tcjacado, shakerhood and rlx02 like this.
  9. Nov 8, 2019 at 7:53 AM
    tacomaccountant
    tacomaccountant Well-Known Member
    Florida
    2019 Metallic Grey SR5 4WD
    Interesting. I noticed a small drop on my last fillup. I did my small lift and tires back in April so this will be the first cold weather with my current setup. I am running around 17.5 now.
  10. Nov 8, 2019 at 8:19 AM
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    For those getting poor cold weather mileage, check your tire pressure. You’ll need to add air compared to summer month driving.
    eurowner, MrCball, BillsSR5 and 2 others like this.
  11. Nov 8, 2019 at 10:42 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Winter blend gas and decreased efficiency in colder temps, im currently getting about 16mpg in the city. That, and i remote start about 5 mins before I leave on 1st start up. All pretty routine.
    shakerhood likes this.
  12. Nov 8, 2019 at 11:02 AM
    pinem56
    pinem56 Well-Known Member
    NE
    2018 TRDOR DCSB AT
    My experience is that the drop in mileage is almost completely due to cold weather and the time it takes for the engine to warm up. In the fall and spring where I live, its not uncommon to have temps below freezing one day, and the next day, temps in the 60s. On the same tank of gas, and same routes, I'll see mileage go from 19 on average to 15 on average with a 30 to 40 degree ambient temp change. It appears the engine runs very inefficiently when it is cold, and it takes a long time for the engine to get up to normal operation temp with below freezing temps. I can drive 5 miles in city stop and go traffic, and still not get my engine up to temp by the time I arrive at my destination.
    If you look at the eco guage, when it is cold, you will see that the mpg is quite low for the first 4 to 5 minutes of driving, then all of a sudden, the mpg will start to increase back to what one would normally see under normal operation. If I had to guess, the Atkinson cycle probably doesn't come online until the engine reaches a certain temp. Everything I have seen with my truck indicates the engine runs very inefficiently when in Otto cycle.
    Shades_Of_Red, Syncros and sunchip89 like this.
  13. Nov 8, 2019 at 11:05 AM
    sunchip89
    sunchip89 Well-Known Member
    Excellent answer, gasoline has the same energy content throughout the year. They just increase the RVP during the cold months
  14. Nov 8, 2019 at 11:06 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Make sure to change out your diff fluid to winter blend as well, helps keeps everything lubed right.
  15. Nov 8, 2019 at 11:07 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Also don’t forget to change your blinker fluid to winter blend
  16. Nov 8, 2019 at 11:14 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Check tires, as already mentioned.
    Also, pay attention to the time change. People are groggy and its going to subtly change the traffic patterns around town. If you start watching for it you'll notice that a lot more people than usual are mindlessly tapping the brakes when rolling in traffic. Those little bitty speed corrections kill mileage way more than weather or fuel blends.
    My mileage started piss poor after the first cold front, but its back up to almost normal now.
  17. Nov 8, 2019 at 11:17 AM
    fiftyxp
    what psi is everyone running?
    k02s specifically?
  18. Nov 8, 2019 at 11:17 AM
    Genypig
    Genypig Well-Known Member
    Yev
    2018 Tacoma TRD OR
    I was getting 20-21 mpgs during the warmer months and now I'm seeing 16-18 mpgs. Kansas got hit hard with winter weather pretty quickly. So I noticed the change in MPG's immediately. I don't know much about winter fuel blend, but if that's the case, then it makes sense. Also, I'm guessing that the colder air temps affect the fuel efficiency in various ways.
  19. Nov 8, 2019 at 11:20 AM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Yes winter gashole does that. Or perhaps the 6 inch lift and E rated 38”s you put on before you participated in Street Outlaws last night had something to do with it?
  20. Nov 8, 2019 at 11:21 AM
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    What size?
