gas mileage with 33s and 35s
Discussion in 'Off-Roading & Trails' started by bigman612, Aug 30, 2011.
  1. Aug 30, 2011 at 3:34 PM
    bigman612
    bigman612 [OP] New Member
    i have a 09 tacoma, 4 cyl manual 4x4. what type of gas mileage would i get with 33s and 35s?
  2. Aug 30, 2011 at 3:45 PM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    13.2968
  3. Aug 30, 2011 at 3:47 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    actually its 16.7394 and 13.2967. but close.
    in reality op, it depends on what tire how wide and so forth. with 33s on a 4 cyl look to drop about 3 and with 35s look to drop about 3 more and go through clutches every couple months. unless you re egar
  4. Aug 30, 2011 at 3:47 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    i get 24ish outta my 255/85/16's which are 33.1". Im looking into getting some 315's soon, once I can find someone wanting to buy my wheels and tires locally then I can report back. The largest tire your going to find on a DD 4 cylinder is a 305/70/16 around here
  5. Aug 30, 2011 at 3:51 PM
    97yota4wd
    Eric
    Mesa, AZ
    but your geared:D
  6. Aug 30, 2011 at 3:52 PM
    08pretaco
    az
    Ya, and OP I would strongly urge you to re-gear if you go that big. I am over-geared and love it!
  7. Aug 30, 2011 at 3:53 PM
    vprgts
    vprgts Well-Known Member
    Walter
    Centreville, VA
    Tacoma Sport TRD 4x4 DC LB
    265/70/17 BF Goodrich K02, OEM 17" 4Runner Trail Wheels, Bilstein 5100's, OME 887 coils, single Deaver rear AAL, Plasti dipped black front bumper cover and badges. TRD pro grill, trd auto shift knob, truxport roll up bed cover, painted red front calipers, tinted front windows, vital 2-way auto remote start. Hood scoop LED light bar. Bumper Auxbeem 32” LED light bar with Caliraised brackets. Infinity reference speaker upgrade with dynomat. 1.25 spidertrax wheel spacers. Supernova V.4 LED low beam H11 bulbs.
    Stock tires on my truck around town is 285-300 miles before the gas light goes on. I just slapped 35's on and now around town with stock gears is like 220-240 before the gas light goes on. Sucks but gotta pay to play =) lol
  8. Aug 30, 2011 at 3:55 PM
    DOT
    DOT Well-Known Member
    Jobin
    Littleton CO
    2007 FJ
    3'' toytec lift
    yeah but what about running 33's or 35's and full armor ?
  9. Aug 30, 2011 at 3:55 PM
    JAG
    JAG Well-Known Member
    i get around 17.5 city with my 33 a/t's on my 06 dbl cab. I have a tonneau cover too... idk if that helps much. :eek:
  10. Aug 30, 2011 at 3:55 PM
    08pretaco
    az
    you also have a V6 and probably not taking into consideration your actually going father than the 220-240 miles due to the increase in size :) so its not as bad as you think
    if my math is correct, 35's are 13.6% larger. 220x1.136 is around 248.6 :D which still sucks but is better than 220
  11. Aug 30, 2011 at 4:00 PM
    luk3
    luk3 I <3 the mall
    luke
    Isle of Palms, SC
    stanky taco
    Camburg spindles, All Pro leaf pack
    My very best was 22.1 mpgs with bfg at 285/70/17 no regear. I usually get under 20 though.
  12. Aug 30, 2011 at 4:03 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar/Ontario, CA
    08 TRD 2wd converted to 4wd
    Estock
    :laugh: this would be in the Offroad n trail section :rofl:
  13. Aug 30, 2011 at 4:41 PM
    vprgts
    Walter
    Centreville, VA
    Thanks for the clarification :)
