Gas Mileage with an Oil Change
Discussion in '4 Cylinder' started by yota2000, Dec 8, 2014.
  1. Dec 8, 2014 at 6:06 PM
    yota2000
    yota2000 [OP] Member
    Emilee
    VA
    2000 toyota tacoma SR5
    3" tuff country suspension lift
    Hey,
    I have a 2000 tacoma with a little over 125,000 miles on it. I have the oil changed every 3,000 miles with full synthetic oil. I have noticed that towards the time the the oil needs to be changed i get lower gas mileage (about 15 mpg) than when i first change it (about 17 mpg). Wondering why this would happen to my truck.
  2. Dec 8, 2014 at 6:19 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Filthy oil probably has more friction I would suppose.
  3. Dec 14, 2014 at 5:48 PM
    Clearwater Bill
    Billy
    Largo Florida
    There is some other variable you are missing.
    Unless you have a competitive vehicle of some type with a very heavy duty cycle, full synthetic oil should last at least 10-12k. Proven by independent lab studies, and you can have your own oil tested to validate. You are both wasting money and resources.
    And the worst contaminated 3k oil (of any type) would never introduce enough friction to drop 2 MPG.
  4. Dec 20, 2014 at 11:42 AM
    Indy
    Indy Master of all I survey.
    Dino oil every 3k miles is throwing away a lot of good oil. Synthetic every 3k is throwing away a lot of good money. If your oil is so crudded up it's dropping your mpg 2mpg you should be seeing liquid metal pouring out of the oil pan.
    Odds are it's the driving style that's affecting your mileage. And before you say it, no you don't always drive the same :laugh:
  5. Dec 27, 2014 at 3:15 PM
    D38SOCAL
    D38SOCAL New Member
    D38 SoCal
    Reg cab
    2012 Reg Cab 4x4
    Change mine every 4000 does the same thing. Mpg goes to shit when it's around 3500 to 4000. Dnt care what your saying does it every time!!! Also where I live dealer calls for oil change every 5000. Now what???
