Gas Mileage with payload (Help I'm dumb)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by R490, Dec 10, 2018.
  1. Dec 11, 2018 at 5:57 AM
    R490
    R490 [OP] Well-Known Member
    Upgrayedd
    VA
    I usually do keep it under 2k when I can, merging and stuff I obviously have to ring it out a little bit.
    PackCon[QUOTED] likes this.
  2. Dec 11, 2018 at 6:12 AM
    SSgt spike
    SSgt spike Well-Known Member
    Forsyth County Ga.
    2009 Tacoma TRD sport SR5 extended cab 4.0 6 speed
    Bull bar, 4" lift with rough country shocks FN TRD PRO wheels, MBRP XP SS cat back exhaust P 265-70-17 Goodyear Wrangler AT tires and 20" 240-watt LED light bar
    It is a 4wd pickup not an economy car. If you want fuel economy get a small car. I would not expect to get more than 17 mpg out of these trucks unless you want to drive it below the speed limit and get rid of any extra weight in the truck. I have BFG Rugged terrain P265-70-17 and a 4 inch lift on my 09 TRD Sport V-6 6 speed. I can't get anymore than 16 MPG. It is what it is I know I am not going to get anymore than that and accept it. I cleaned the MAP sensor, changed the plugs and my FN TRD Pro wheels are lighter than my stock sport rims. My mileage hasn't changed with any modification or tune up. I don't drive like a little old lady but I don't beat the truck . After I hit 75 MPH I can watch the gas gauge drop but again that is something I have accepted. I get better fuel mileage with my F-350 Powerstroke even when it is loaded doing 80 mph on the highway. So basically what it comes to is you have to accept these trucks suck in the fuel mileage department and no matter what you do to them your gas mileage is going to suck unless you get a 2WD Prerunner and drive the thing like a little old lady.
  3. Dec 11, 2018 at 6:16 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    To be fair even the new diesel trucks except maybe the cummins suffer from huge fuel economy drops hauling. My old 7.3 super duty would only loose a couple MPGs where these days they go from like 22 unloaded to 12-14 loaded. Now that would be loads that would be about the same scale as our trucks can haul.
  4. Dec 11, 2018 at 6:42 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    All though it takes energy to move weight it basically has no wind resistance that is a killer in fuel mileage it is also why a Tacoma does not do real well on fuel it sits high with a lot of frontal area. If you put even a 1100# empty box trailer behind it it going to take a big hit. If I pull my camper 11 to 13 by itself pretty steady 18.
  5. Dec 11, 2018 at 6:49 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    check the air filter
  6. Dec 11, 2018 at 9:47 AM
    96carboard
    96carboard Well-Known Member
    That's pretty terrible mileage. Glad I have a 4-cyl.
    You're also dealing with garbage winter gas right now.
    There are precisely two conditions in which payload can impact your fuel consumption;
    1) If the payload sticks out and creates aerodynamic drag.
    2) Under frequent accelerations.
    If you're just cruising on the highway with a load that does NOT impact aerodynamics, then there will be no impact on fuel consumption.
    Nope. More motor = more fuel consumption. Less motor = less fuel consumption.
    And FYI: I get about 24 mpg while pulling cars on a flatbed trailer at 80 kph (50 mph). The trailer *alone* is about 2000 pounds.
  7. Dec 11, 2018 at 4:18 PM
    R490
    Upgrayedd
    VA
    That's weird because the GMC Sierra 5.3 I used for work got way better gas mileage than my Tacoma. SCLB 2wd though.
