Gas mileage wrecked/Do not buy Falkens
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cutter_, Dec 18, 2020.
  1. Dec 18, 2020 at 3:25 PM
    Cutter_
    Cutter_ [OP] I probably could have googled this
    2002 Super Air Nautique Build
    Old Man Emu lift, 2 10" JL subs
    I have yet to pinpoint the EXACT issue, but I had Falken H/T Wildpeaks 265/70/16s installed on my truck back in August and every gas tank I've been getting since then fluctuates extremely.
    I bought my truck in 2016 and it had two A/T BFGs in the back, and two off-brand A/Ts in the front. I would get 300 miles on a tank. Google says I have an 18.5 gallon tank on my 2002 6cyl 5VZ-FE prerunner.
    Fast forward to August of this year, the tread is worn down a lot and I'm due for new tires. I have Falken Wildpeak H/Ts put on with the expectation the switch from A/T to H/T will improve my gas mileage, past the current 300 mile a tank I was getting.
    Fast forward to today, and I have been getting sub ~250 mile tanks since the tire change. I just got 200 miles on a tank the lowest since the tire change, and the first since my full OME suspension upgrade. What the hell is going on? I had my injectors cleaned last year by the dealer, no change. I plan on doing 33" 285/70/17 A/T tires next month, at this rate I'll be getting 8 MPG!!!!!!!!!!!!!!!!
  2. Dec 18, 2020 at 3:31 PM
    TacoTyusday
    TacoTyusday Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
    Did you size up wheels/tires at all? Seems you also installed a lift? Did you install any armor or other weight?
    My truck on stock suspension and 265/70/16 Hankook Dynapro AT/Ms was getting about 18.5 average mpg. After my suspension lift with a new leaf pack, and armor/sliders, and sizing up tires to E-rated mud terrain 285/75/16, I now get about 14.5-15 MPG calculated at each fillup.
    If this is a gradual decline over the years in MPG, then it's probably none of the reasons I mentioned. Maybe MAF/throttle body?
  3. Dec 18, 2020 at 4:05 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Holy shit that's a long read.
    I didn't read all of that but will immediately say; you do realize we're in the colder season right?
    Winter blend fuel sucks.
    2004Taco, bahndrvr, Tacotoast and 8 others like this.
  4. Dec 18, 2020 at 4:06 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Having added that lift though would definitely lower your MPGs a bit.
    Tacotoast, Lawfarin and CygnusX191 like this.
  5. Dec 18, 2020 at 4:19 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Try new plugs and clean the MAF, maybe
    michael roberts and Rock Lobster like this.
  6. Dec 18, 2020 at 4:22 PM
    Cutter_
    New plugs + wires in July
  7. Dec 18, 2020 at 4:23 PM
    Toywoodsguy82
    Toywoodsguy82 Well-Known Member
    Patrick
    Oregon
    2007 Silver DCSB TRDOR 2017 black crewmax tundra
    Body Armor front and rear bumpers Method 703 Wheels Falken wildpeak AT3’s Ironman Foam Cell Pro kit
    Well I’m in the same boat as you but I understand that I just added weight (tires and wheels) and lifted my truck and went up in tire size... I went from 17.5 plus to nothing above 14.8. I’m not mad it comes with the territory
    Astr0Aar0n, Bleep100, BOMBS and 2 others like this.
  8. Dec 18, 2020 at 4:24 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Seconded on the plugs and MAF. At the very least pull and inspect them for fouling.
    Also, I'll say the obvious, what's the air filter look like?
  9. Dec 19, 2020 at 12:18 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    *omg I added a bunch of weight and turned my truck into a sail, why do my mpgs suck!*
    read between the asterisks, please
  10. Dec 19, 2020 at 4:47 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    OP To arrive at these numbers you are using a calibrated fuel cell so the quantity of fuel is a measured amount each time.
    To many others factors that can`t be controlled enter into the equation to come even close to a real number
    CygnusX191 likes this.
  11. Dec 19, 2020 at 4:59 AM
    Clearwater Bill
    Billy
    Largo Florida
    What were the previous tire sizes?
    If a tire change were the core issue, the MPG would not 'fluctuate extremely'. Because the tires stay the same.
    Calculate actual MPG. MPT doesn't exist unless you run it dry; it's just a theory. Not saying your MPG hasn't dropped, but MPT is a lousy reference point
    Well, based on your cause and effect method, the suspension just cost you 50 miles per tank.
    Thatbassguy and doublethebass like this.
  12. Dec 19, 2020 at 5:00 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Are the Falkens E loaded? 10ply much heavier than a C or even P load tire? That would be the problem right there, nothing wrong with the Falkens themselves other than being heavy.
    Also as other mentioned winter blend fuel ain't going to help you, and if you haven't been getting gas at the same gas station every time that could add variance.
    What other mods or maintenance or weight adding to the truck have you done recently?
    You're not running a K&N oiled filter are you?
    Bad ju-ju junks up the MAF.
    CygnusX191 and Wyoming09 like this.
  13. Dec 19, 2020 at 5:20 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You have provided no useful information. Miles per tank is useless unless you drive each tank until the truck runs out of gas. What were your miles per gallon before, and what are they now? Until you know that information you're just guessing about everything. And if you never calculated miles per gallon previously you have no hard data to compare it to today. You can calculate MPG's today, but don't really have any idea how much different, if any, to the truck previously.
    Your odometer simply counts wheel revolutions and does the math based on the circumference of the factory tires to calculate the distance you've driven. If you change to a larger tire the circumference changes and it takes fewer revolutions to travel the same distance. When that happens your odometer is no longer accurate. You are actually driving farther than you think. If you went to a larger diameter tire you may be driving the same miles per tank as before and just don't know it. Even if you stay with the same size tire a new one will be about 5% larger in diameter and will throw the miles off by about that much.
    What size and load rating were the old tires? What PSI are you using in the new tires? What PSI in the old tires? Under inflated tires can reduce fuel mileage by 1-3 mpg
    265/70/16's are an optional factory size and are the same diameter as the more common 245/75/16's that come from the factory. They are just about 3/4" wider. That should have had no real impact on fuel mileage and as you suspected your fuel mileage should be better if you replaced an aggressive AT tire.
    The lift could change MPG's by 1-2 MPG.
    My 2007 came with P rated 265/70/16's. Years ago I upgraded to an E rated 265/75/16. They are 15 lbs each heavier and 1" taller than stock. Same width. I did not modify my suspension. My truck still gets exactly the same fuel mileage as it did 13 years and 210,000 miles ago when it was new.
    I suspect you have another issue and it just showed up at the same time as a coincidence. I also have a 2014 F150. I had new front brakes installed and new tires installed within a 2 week period just over a year ago. I upgraded to a heavier, larger, more aggressive tire on the Ford and THOUGHT for months that I'd lost 2-3 mpg due to the tires. But when my front brakes wore out after only 15,000 miles I discovered the mechanic installed them incorrectly and they had been dragging slightly on the rotors. The mechanic made it right and replaced the brakes at no charge. My fuel mileage returned to pretty close to the original mileage. I'm now about 1/2 mpg worse instead of 2-3 mpg.
  14. Dec 19, 2020 at 5:21 AM
    Jensen518109
    Jensen518109 Some day I Will Be Like the Cool Kids
    Garrett
    2021 DCSB Metallic Grey
    Yeah think there is something else at play. A lot of the wisco guys I have talked to have falkens on oem wheels that are a size up and still get great fuel mileage like 20 or so. So Idk what you did but there is something wrong.
  15. Dec 19, 2020 at 5:28 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Put 32 in Falkens on my truck. Mpgs are still the same.
    Not sure where the regear point is on a first gen , but rule of thumb with 2/3 gens is anything larger than 33in tires should be regeared.
    Jensen518109 likes this.
  16. Dec 19, 2020 at 5:45 AM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    8mpg is a little extreme, but tires will throw off odo and winter gas. AT tires are heavy, so eh.
  17. Dec 19, 2020 at 5:46 AM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    You're in the ballpark still. It's a truck.
    ruffridha9 likes this.
  18. Dec 19, 2020 at 6:54 AM
    SellyKlater
    SellyKlater Well-Known Member
    Ponce Inlet, Fl
    2004 Tacoma 3.4L Double Cab TRD
    3" ome lift 883. Fnfx pros.
    I'm lucky to get 220 miles per tank plus maybe 25 miles for tire size adjustment. So under 250 a tank city driving with ac on full time. That's driving like a bat out of hell though.
    Cutter_[OP] likes this.
  19. Dec 19, 2020 at 7:31 AM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    I remember when forums had actual information and a certain level of mechanical understanding was expected...
    Wyoming09 likes this.
  20. Dec 19, 2020 at 8:07 AM
    Cutter_
    It’s possible the brakes are dragging I did new pads and rotors back in March and the rotors are already chewed through/no longer smooth
