Gas mileage wrecked/Do not buy Falkens
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cutter_, Dec 18, 2020.
  1. Dec 20, 2020 at 5:58 PM
    #121
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    That's not even the example I was immediately thinking about, but you are absolutely correct!
    I was thinking of the Quigley conversions on Ford econolines :D
  2. Dec 20, 2020 at 6:05 PM
    #122
    Abeyancer
    Jimmie
    PNW
    Now you're getting into the realm of sprung vs unsprung weight ... which can be it's own spin on this rabbit hole of a topic regarding MPG.
    Is the rust solely on the frame? Are we talking corrosion on the wheel rims instead? So many factors!!
    High Noon and Black DOG Lila like this.
  3. Dec 20, 2020 at 6:08 PM
    #123
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Yes
    Maybe
    Depends
    Abeyancer likes this.
  4. Dec 20, 2020 at 6:14 PM
    #124
    Abeyancer
    Jimmie
    PNW
    But if you scrape the rims of you brand new mounted tires on the curb often enough, you'll safe all that added ff/ww weight
    High Noon likes this.
  5. Dec 20, 2020 at 6:15 PM
    #125
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    so you're telling me all the first gen four-door guys on here had 4x4 added to their trucks?
    You sir, are an idiot.
    frizzman and El Taco Diablo like this.
  6. Dec 20, 2020 at 6:16 PM
    #126
    Kwikvette
    Fresno County
    4 run, 2 don't
    With enough rust, you'll get countless MPGs...
    Cause the frame will be broken and you can't drive it :luvya:
  7. Dec 20, 2020 at 6:19 PM
    #127
    Black DOG Lila
    Virginia
    Previously established fact
    CygnusX191[QUOTED] likes this.
  8. Dec 20, 2020 at 6:19 PM
    #128
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    :rofl: :cheers:
  9. Dec 20, 2020 at 6:23 PM
    #129
    Black DOG Lila
    Virginia
    You will find many so afflicted here.
    Proceed with forethought.
    Best just to recognize their shortcomings and humor them.
  10. Dec 20, 2020 at 6:23 PM
    #130
    Kwikvette
    Fresno County
    4 run, 2 don't
    Toyota says it's normal :burp:
  11. Dec 20, 2020 at 6:59 PM
    #131
    Cutter_
    Cutter_ [OP] I probably could have googled this
    2002 Super Air Nautique Build
    Old Man Emu lift, 2 10" JL subs
    40 miles uses a quarter tank of gas when topped off. How does the gas mileage of a Honda Ridgeline and Ford F-250 crew cab compare?
  12. Dec 20, 2020 at 7:22 PM
    #132
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    It doesn't matter because they're all used for extremely different jobs.
    also any money you would save on fuel economy on those new vehicles you're going to lose the fact that you're purchasing a new vehicle. Even if it's used, new to you is still a lot more expensive than a truck you already own.
    frizzman and High Noon like this.
  13. Dec 20, 2020 at 7:38 PM
    #133
    goldentaco03
    goldentaco03 Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    How did you go from ~250mi/tank to now 160mi/tank...you sure you’re not leaking gas or somethin?
  14. Dec 20, 2020 at 7:48 PM
    #134
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Sounds like he's leaking brain cells at this point
  15. Dec 20, 2020 at 8:17 PM
    #135
    Kwikvette
    Fresno County
    4 run, 2 don't
    Well, no one cares about Ridgelines and, it can't compare to the F250 cause that thing uses no gas!...
    It'd use diesel :rofl:
    CygnusX191 and Black DOG Lila like this.
  16. Dec 20, 2020 at 8:30 PM
    #136
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Sooo...8.88 mpg. Our old 1990 suburban did better than that with no overdrive and a 7.4l v8...while pulling a trailer.
    Either your truck needs work, or your numbers are whack.
  17. Dec 20, 2020 at 10:19 PM
    #137
    Cutter_
    that’s what I’m saying people keep saying “it’s a truck” but I’m getting GARBAGE gas mileage for a truck even
  18. Dec 20, 2020 at 10:20 PM
    #138
    0xDEADBEEF
    Yeah the 'its a truck' excuse is one of the stupidest copouts.
    I'd have a good look at your brakes.
    CygnusX191 likes this.
  19. Dec 21, 2020 at 5:06 AM
    #139
    goldentaco03
    Liam
    NJ
    No I’m saying, earlier in this thread you said you were getting around 250 a tank and now you’re saying 40/quarter or 160 a tank. I think you need to get some hard MPG data not miles per tank and report back. I’ll get 90 miles for the first 1/4 or my tank, but the last quarter will only last about 50 or less. Old truck, old sensors, old fuel sender. The needle doesn’t drop linearly anymore.
  20. Dec 21, 2020 at 5:52 AM
    #140
    Black DOG Lila
    Virginia
    Max stupidity
