Gas Mileage
Discussion in 'Performance and Tuning' started by labman626, Jul 4, 2013.
  1. Jul 4, 2013 at 6:20 PM
    labman626
    labman626 [OP] Member
    Hey Guys!
    I have a 2007 Tacoma 4x4 with the 2.7 motor in it and a 5 speed. It does not seem to get the gas mileage I use to. Are there somethings I can check to see if I can improve my mileage truck runs like a champ. It has 130k on it. I want to drive it till I can't anymore. Any suggestions I would appreciate. Thanks!
  2. Jul 4, 2013 at 7:32 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Plugs? O2 Sensor?
  3. Jul 4, 2013 at 8:39 PM
    6spd
    6spd Well-Known Member
    san diego
    2023 4x4
    Do a full tune up.
    -plugs and wires
    -oil change
    -belts
    -make sure battery is good to go(water in battery, posts arr clean)
    -pcv valve
    -air filter
    -fuel filter
    -tranny and diff fluid change
    -coolant flush
    -change wheel bearing grease
    Check anything that effects the health or your engine and anything mechanical that may impede the operation of your vehicle
  4. Jul 5, 2013 at 5:28 PM
    labman626
    Ok new battery and belt a few weeks ago. Due for regular oil change next week. Going to replace plugs and such next week. How do I change PCV valve? Coolant I just drain and replace with new right? How about tranny and differential oil? This is a 2007 standard transmission and 4x4
  5. Jul 6, 2013 at 7:28 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Check your tire pressure and add some if it is to low. Less rolling resistance.
