Gas mileage!
Discussion in '1st Gen. Tacomas (1995-2004)' started by joeyhunter, Apr 9, 2014.
  1. Apr 9, 2014 at 4:42 PM
    joeyhunter
    joeyhunter [OP] Member
    Lebanon,Pa.
    02 Tacoma
    I got through the 2nd tank of gas in my truck (2.7 ,5 speed , 31.5 tires ) only getting 17.5 mpg. Is that normal? I was hoping for more like 20 -21 mpg.
  2. Apr 9, 2014 at 5:03 PM
    Charlie5280
    Charlie5280 Member
    Charlie
    Denver/Wyoming
    1994 Toyota DX Shortbed
    Bone stock
    Yep. The rolling resistance of those tires is very high.
    If you went to stock you'd see 20/21. But that's it. The 2.7 isn't a new design.....combustion chambers, aero, and direct injection would be the only things to change it's efficiency.
  3. Apr 9, 2014 at 5:04 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    take off the cap for summer too :)
  4. Apr 9, 2014 at 5:05 PM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    There are about 20 threads on gas mileage
  5. Apr 9, 2014 at 5:11 PM
    Yota Nation
    Yota Nation Well-Known Member
    Micah
    Minden LA
    2006 trd off-road
    @project_stealth 2006 toyota tacoma 4x4 with diff lock Anytime fog light mod K&N drop in filter 3inch tuff country lift add a leaf pack rough country shox xd hosses 33 inch nitto trail grapplers black tail lights black grille black roof Black lower valence on front bumper Black headlights with oracle color shifts and rgb projectors by @hazardouslighting Color shift halos in foglights by @oraclelights jvc 7inch touch screen double din radio 1 12 inch sundown audio sa 12 Custom box 2.1 cu ft. Tuned to 33hz and a 4inch port T1250bd 1400rms rockford fosgate amp Component set with 6.5 inch autotek mids and tweets quantum audio 150x2 highs amp 4 boss 6x9s Power acoustik pre amp Monster cable and full 0 gauge install @all4offroad rock lights cherry bomb exhaust 1 to 2 with 3 1/2 inch tips allpro offroad steel rear bumper Dipped dash 2 led pods 50 inch light bar Custom roof mounts Future mods: Roof rack with pods all the way around
    I get 12
  6. Apr 9, 2014 at 5:12 PM
    Charlie5280
    Charlie5280 Member
    Charlie
    Denver/Wyoming
    Bone stock
    ^ This lol
  7. Apr 9, 2014 at 5:14 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Use less skinny petal. I get about 17 out of my auto v6 on 31s. Whats your gear ratio?
  8. Apr 9, 2014 at 5:22 PM
    joeyhunter
    Lebanon,Pa.
    02 Tacoma
    I do have my cap off. My gears are 3.89 I believe, going by the door tag.
  9. Apr 9, 2014 at 5:25 PM
    smmarine
    Melbourne FL
    3.89 might be a little under geared for 31s. At least I think so. My v6 has 4.10, with a 4 cyl i wouldn't want less then 4.56. If you are having to give it a lot of skinny petal cause of the gearing and tires, that is your problem
  10. Apr 9, 2014 at 5:29 PM
    Huntn57
    Huntn57 Well-Known Member
    Justin
    VA
    1995 Toyota Tacoma
    i com 2300 ham radio. for hunting (170 k miles) list of replacements since 166k miles: 4wd solenoid tailpipe muffer catalitytic conver exhaust manifold
    1995 2.7 with 225/60/15 i get 22.5
  11. Apr 9, 2014 at 6:14 PM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    17.5 is right in the ballpark,,for having a cap and non oem tire sizes.
    Every truck is a bit different,,so results vary no matter what you do to try to correct it.
  12. Apr 9, 2014 at 6:17 PM
    Tjsingle26
    Tjsingle26 Well-Known Member
    Tom
    PA
    03 Tacoma xtra cab 4x4
    My last tank was 22.5mpg with 2.7L 2003 tacoma 4x4
  13. Apr 11, 2014 at 7:02 PM
    joeyhunter
    Lebanon,Pa.
    02 Tacoma
    Any value in mpg switching to manual hubs ?
  14. Apr 11, 2014 at 8:20 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Maintenance has a huge part of it too along with tire size, weight, and aftermarket add ons such as aftermarket bumpers, light bars, etc..
    I'm getting about 310 miles on each tank.
  15. Apr 13, 2014 at 2:34 PM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    The 17mpg depends what the the stock tire size was. My truck is stock with 31 x 10.5, except for a K&N flat replacement filter. I've been driving it since new, 260,000 miles now. 20mpg city/ 21-22mpg highway.
  16. Apr 13, 2014 at 2:41 PM
    smmarine
    Melbourne FL
    If you have auto locking hubs, I'm pretty sure they're always locked and the front axle is always spinning. So yes it would improve mpg. I just don't know how much. Someone correct me if I'm wrong
  17. Apr 15, 2014 at 12:41 AM
    donson6
    donson6 Well-Known Member
    2002 4x4
    lots
    Those tires are causing you bad mpg, take those off and put the oem size tire on, and you mpg will go up. Me, I don't care about mpg, love my big tires. I got 37's on my Ram 3500 (diesel) with a 7" lift. I get about 10.5-12mpg in my diesel truck, and spend 120 bucks to fill the beast up. You gotta pay to play...
  18. Apr 16, 2014 at 4:55 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    could be a little from the tires, 31" (30.6) is the norm for 4wd. with 3.89 gears, doesn't seem right to me but maybe Toyota liked to mix it up, but usually 4.30 so maybe need better gearing or to even bump down more on tires?
  19. Apr 16, 2014 at 5:07 PM
    smmarine
    Melbourne FL
    Even my v6 is a 4.10. I would say the tires/gears are the problem. I would go to at least 4.30, but probably 4.56. I thought most 4cyl 6 lug came with 4.56, but I'm finding out it's almost impossible to guess haha
  20. May 17, 2014 at 2:55 AM
    Len04Taco
    Len04Taco Well-Known Member
    Len
    Stow, MA
    04 SR5 Red
    So far, highway driving (200mi R/T) the best I have gotten is 21.5 mpg with 4WD V6 stick using cruise w speeds 65-70 & tailgate up. I have 4.10 gears & stock 265/70R16 knobby tires. Basically this is totally stock, as delivered in 2004.
    Since I drive this route 2-3 times ea week, I really need better mileage. At my destination I must have 4WD. (My 99 2WD 2.7 Taco automatic got 30mpg, but could not get up my driveway.)
    I am looking into 3.91 gears and Manual Locking Hubs. (Actually buying these items presently.)
    Also plan to buy skinny low-rolling resistance tires in the near future. My ultimate goal is 25mpg highway.
    Len
