Gas mileage!
Discussion in '1st Gen. Tacomas (1995-2004)' started by joeyhunter, Apr 9, 2014.
  1. Jun 6, 2014 at 2:24 PM
    #181
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Just put in octane or fuel into the search bar. You'll have reading for days. If you look in your owners manual, it should say the recommended fuel for the 4.0 is 91 octane. The 4.0 is designed to run the best at 91-93 octane. The ECU will detune when it senses knock, meaning retard spark timing and fuel curves, to run 87. I've read a lot of people hearing knock on here cause they run 87 octane. Seems like very few people know the 4.0 wasn't meant for 87 octane
  2. Jun 6, 2014 at 10:05 PM
    #182
    Yota64
    Yota64 Professional Threadjacker
    I know, I stated that somewhere earlier in here, or maybe it was a different thread. I will search that now. Thanks again!
  3. Jun 8, 2014 at 7:19 AM
    #183
    NOLA ItsNotOva
    NOLA ItsNotOva Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Right now on my trip computer, I have 176.7 miles and its in the middle between half a tank and quarter of a tank. I know I need an o2 sensor, but would it affect my gas mileage that much?
  4. Jun 8, 2014 at 8:09 AM
    #184
    Robb235
    Robb235 Well-Known Member
    Chattanooga, TN
    1999 Turbo 4Runner
    Turbo 5vz uaEFI Standalone ECU 231mm Tundra Brakes RR Diff Lock Hayden 699 Transmission Cooler
    Yes. A bad O2 sensor will KILL your gas mileage.
  5. Jun 8, 2014 at 8:13 AM
    #185
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Well, I just replaced the MAF because that was bad. And I didn't see the o2 code until I cleared the MAF code. So, since these two kind of work together, would that mess up my MAF sensor?
  6. Jun 8, 2014 at 8:46 AM
    #186
    smmarine
    Melbourne FL
    That's about the mileage I get haha
  7. Jun 8, 2014 at 8:49 AM
    #187
    Yota64
    ...How do you know when our o2/MAF are bad? And can you get better ones for better mileage?
  8. Jun 8, 2014 at 8:53 AM
    #188
    smmarine
    Melbourne FL
    A code will pop up if they go bad. Or you will see symptoms of them failing. All the will do is measure what they are designed for, and send the data to the computer. So no a different brand won't make better mpg
  9. Jun 8, 2014 at 10:32 AM
    #189
    Yota64
    Roger that
  10. Jun 13, 2014 at 12:00 PM
    #190
    Mikeyjd
    Mikeyjd MPG Enthusiast
    Mikey
    Grand Rapids, MI
    97 3.4L 4x4 DLX
    Grill Block, Front Belly Pan, 3 inch lift shims in front, AAL rear suspension lift, Ultragauge Instrumentation, Flush Topper, Full Synthetic Fluids
  11. Jun 14, 2014 at 5:59 AM
    #191
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    wow, nice tank, must be maximizing the pulse and glide. :bowdown:
  12. Jun 14, 2014 at 6:28 AM
    #192
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    so your getting 35mpg??? or am I reading the chart wrong
  13. Jun 14, 2014 at 6:36 AM
    #193
    Snookie
    Snookie Monkey Tamer
    Snookie
    Lizard Creek Louisiana
    14 Texas Edition 4X4
    91 octane for the 4.0 in a 2014 are U sure Sir :eek: ?
    Where can I find that information ?
    Thanks
  14. Jun 14, 2014 at 6:54 AM
    #194
    Madjik_Man
    Colorado Front Range
    Only the upstream O2 sensor affects gas mileage.
  15. Jun 14, 2014 at 10:00 AM
    #195
    smmarine
    Melbourne FL
    Yes sir. All 4.0. It will run 87, just not the most efficient in power or fuel economy. I don't have direct links, just from reading in threads. Type in octane or fuel into the search bar. You should have plenty to read
  16. Jun 14, 2014 at 11:43 AM
    #196
    Mikeyjd
    Mikey
    Grand Rapids, MI
    97 3.4L 4x4 DLX
    Definitely maximizing P&G. I had a 40 mile stint of 41.3mpg that made an 80 mile trip 40.2. Mostly 33-34mpg trips though.
    Correct :) The warmer weather along with maximizing Pulse & Glide are key factors along with the recent aero work I've done.
    http://csus-dspace.calstate.edu/bitstream/handle/10211.9/169/combined-finished.pdf?sequence=1
  17. Jun 22, 2014 at 4:32 PM
    #197
    Mikeyjd
    Mikey
    Grand Rapids, MI
    97 3.4L 4x4 DLX
    New Best Tank!
    2014-06-22
    478.8 mi
    770.55 km
    13.017 gal (US)
    49.27 L
    438.67 kWh
    $3.68/Gallon ($47.90 total for this fill)
    36.78 mpg (US)
    6.39 L/100 km
    Ultra Guage read 37.21
    80% Back Roads 20% Highway
    87 Octane Fuel (Mobile 1)
    Had to use my heater once during city traffic to nullify thermal runaway of the cooling system. Opened up more of the grill to compensate afterwards. Just finished Air Dam and changed rear differential fluid to Amsoil Severe Gear Synthetic Extreme Pressure Gear Lube 75W-90
