Gas mileage
Discussion in 'New Members' started by grouchy toyota owner, Feb 24, 2018.
  1. Feb 24, 2018 at 6:30 PM
    grouchy toyota owner [OP] New Member
    2016 toyota TRA two wheel TRD
    none
    So far my 2016 Tacoma V-6 TRD is getting terrible gas mileage. I know its a truck so don't tell me they don't get good mileage. I drive 60 miles each way to work and the best I have done with mileage so far is about 19 mpg. If there is even a gentle head wind, my truck stays in 5th gear. It downshifts at every small incline, even for a overpass or exit. I am driving like a grandpa, no jack rabbit starts, slow increases in speed, driving under the speed limit. I'm in Kansas where the speed limit is 75, but my max is 70 just to conserve gas. So far this truck is a total "F". Any ideas???? I want my Ford ranger (200 thousand miles on it) back.
  2. Feb 24, 2018 at 6:32 PM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    Winter gas/temp
  3. Feb 24, 2018 at 7:12 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW..... l wished I got 19 mpg. I’ve had a 2000 x-tra can,a 2005 access cab both were M/T and now a 2014 DCLB auto and the best mpg I ever got has been 16 mpg. All Toyota’s!!
  4. Feb 25, 2018 at 5:27 AM
    none
    The other morning with a bit if headwind my computer said 16.8 mpg at the end of my 60 mile trip (stayed in 5th almost all the way). Not sure the computer is always accurate, but still. I get better gas mileage in town than on the road. I just don't believe that Toyoda can't engineer a better system which gets great mileage. My front wheel drive, low slung, Lexus LS350 gets 30-35 on the road. I know they don't compare in terms of aerodynamics, but if we can send a Tesla Roadster around the sun, we should be able to get better gas mileage here on earth.
    buckhuntin-tacoma likes this.
  5. Feb 25, 2018 at 5:44 AM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    There is a huge exponential increase in wind resistance from 55-65 mph, and as you increase speed from there. Before I added weight to my truck, I could get around 25 avg tank mpg on long highway drives, going 60mph. Watch your mpg gauge. I would also have next to zero clutch slip from a stop, engaging at idle rpm (careful to not ping) with shift points at around 2k rpm, opening it up to almost WOT only when getting on highways just to get the temps up once in a while.
    The Lexus isn’t even close to a reasonable comparison. Probably close to half the mass of your Tacoma. Consider the difference in tire / wheel mass and rolling resistance alone.
  6. Feb 25, 2018 at 5:55 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Ford Ranger is a much smaller truck, what do you expect?
  7. Feb 25, 2018 at 5:57 AM
    Bridge4
    Bridge4 Well-Known Member
    MA
    2003 DCSB Imperial Jade
    Dump that piece of shit and go track down your ranger or one like it. See ya later!
  8. Feb 25, 2018 at 6:42 PM
    Albertgg
    Albertgg Member
    2017 Tacoma Off Road Access
    Have your transmission/engine download the latest updates.
  9. Feb 27, 2018 at 12:13 PM
    EL Taco Verde
    EL Taco Verde Well-Known Member
    2021 TRD Off Road
    Factory lift kit. Lomax tri fold Tonneau.
    are you driving with defrost air conditioner on full time? i run 34psi air in tires. get 21.5 mpg. even during winter snow driving never got less then 19.5
