Gas Mileage
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Thirdeye, Jan 29, 2020.
  1. Feb 21, 2021 at 10:53 PM
    #41
    mosccat
    mosccat Well-Known Member
    Mark
    Currently in Bend, OR
    2020 OR
  2. Feb 21, 2021 at 11:13 PM
    #42
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    That's..... interesting. I get 21-23 on the highway.
    shakerhood likes this.
  3. Feb 21, 2021 at 11:18 PM
    #43
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    Compared to my old Grand Cherokee, this thing sips gas (Tacoma is as low as it is because a lot of those miles are in 4wd.)
  4. Feb 21, 2021 at 11:21 PM
    #44
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    Winter Fuel mix sucks... mine would drop to around 15mpg in winter.. and also due to the more dense colder air... more fuel is required to leep the fuel air ratio correct. the winter mix has more detergents, and thinners so the gas doesnt freeze up in extremely cold weather. If you fill up with good premium fuel you will see a little jump in MPG.. I typically get about 16-18mpg in winter.. on warmer days mid 30s I can get around 20mpg going 55-60mph... past 75mph my MPG tanks to around 17mpg (according to the computer).. its been fairly accurate.. within 1 or 2 mpg when I have tracked it.
    MountainManGuy and RatAssassin like this.
  5. Feb 22, 2021 at 4:29 AM
    #45
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    For whats its worth, i towed my aluma 5x10 utility trailer with my sled yesterday about 160 mile round trip. Didn't even need the ECT mode...it towed perfect in S5 all the way. 19.8 mpg. Plenty enough power. This was way better that the tundra i had that would only get around 15.5 at best, and that was with no trailer, just the snowmobile in the bed. I couldn't be happier with this taco.
  6. Feb 22, 2021 at 4:57 AM
    #46
    Siebermd
    Siebermd It’s all about the journey
    Virginia Beach
    2016 TRD Off Road
    Alu-Cab canopy Camper, Dobinson's Suspension
    On my last road trip, Virginia To NY and back, I tested MPG with Octane ratings. 93 octane I was getting 17/18 MPG. On 87 I was getting 21. Today on my commute to work, average 65 mph, I was sitting at 24mpg. 2016 TRD Off Road, completely stock.
  7. Feb 22, 2021 at 6:06 AM
    #47
    OrangeRa1n
    OrangeRa1n Well-Known Member
    Houston Area
    TRD-Offroad 2021
    I had to throw mine in 4wd during the Winter Storms (lucky me, I hardly used the 4WD in my F-150 but have had two snowstorms in Texas this year alone!). I think I averaged around 12-13 MPG in 4X4 driving around 35-40 MPH.
    Usually I get around 19-20 MPG, but this number drops dramatically if I warm my car up or idle for extended periods of time (which I always do since I have PTSD of blowing up the turbo on my last car). Cruising usually = good mpg but lots of starts and stops at lights seems to knock that number down quite a bit.
  8. Feb 22, 2021 at 7:07 AM
    #48
    zoo truck
    None
    Yeah, i tried a few tankfuls of E93, it sucked more gas, and made less power. 87 is the ticket, even with a trailer. Found using Ect pulling my utility trailer with my sled probably wasn't more than 1100 lbs, only wasted gas. It should of upshifted a lot sooner. Must better with it off, and using S5 only. Imo, toyota has these 2020 v6 auto's perfectly tuned.
    Siebermd[QUOTED] likes this.
  9. Feb 22, 2021 at 7:43 AM
    #49
    Chicken_Taco
    Chicken_Taco Well-Known Member
    Comfortably numb on the Darkside of the moon
    2019 Midnight Black Tacoma TRD Sport
    Working on it ...
    ^^. This.
    I was averaging between 20 and 21 miles to the gallon. Then winter came in I am now averaging between 18 and 19 +/- miles per gallon. That’s pretty much a combined highway city average.
    Definitely a winter fuel mix difference.
    zoo truck likes this.
  10. Feb 22, 2021 at 9:41 AM
    #50
    zoo truck
    None
    Same here, was averaging over 23 in the hot summer months. Now winter about 20...mix of city/highway.
  11. Feb 22, 2021 at 9:50 AM
    #51
    OpieT
    OpieT Member
    2018 SR5 AC 4x4 V6 MGM
    Yep I lose about 3mpg with the winter fuel. I lost another 2 mpg with all the snow we had in Ohio since the beginning of February.
    The snow and especially the salt slush all over the road will kill your milage.
  12. Feb 23, 2021 at 9:53 AM
    #52
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Haha! My wife actually named it the beast when we were still dating and the name stuck.
    19.5 is great mpgs! If you drive these trucks within 5-10mph of the speed limits, they can get great mileage.
    There is an option to share your fuelly stats in the settings I believe. I’m pretty sure you can only do it from a computer though. You just copy and paste the link provided there. I’ll have a look later when I get home.
  13. Feb 23, 2021 at 10:01 AM
    #53
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Strange, it should get a bit better mpgs if going 65-70, especially with an AT. Maybe your truck is still pretty new and needs to be broken in some more. Do you idle a lot?
    I got 20.5 on my recent trip about 80% highway. MT runs higher RPMs on the hwy. I have no cap but I do have heavier AT tires. I flashed my ECU recently and I’m getting same mpgs as I did in the summer, so I’m sure I’ll see an improvement in a couple of months. Loving the new tune by the way, I just want to keep driving, even after 3-4 hours, haha!
  14. Mar 16, 2022 at 8:42 AM
    #54
    Jwh4x4
    Jwh4x4 New Member
    2020 Army Green Tacoma TRD Pro
    I've got a 2020 Tacoma TRD Pro. I was getting 18 to 20 mpg according to the readouts. I put 31.7 nitto's on the stock 16 wheels. It got a little worse but seemed to always be 16 to 19. Then about three months ago it started bouncing around 11 and 9 and I thought something was wrong with the computer. Took to dealer, they couldn't find anything and said its because my tires. So I've manually calculated three tanks now and I'm averaging about 11.9 mpg. Which is horrible! They can't tell me anything but yeah thats bad alright. Any thoughts?
  15. Mar 16, 2022 at 9:02 AM
    #55
    BarcelonaTom67
    BarcelonaTom67 Lost in Translation....
    Tom
    Laurel County, Kentucky
    2017 Barcelona Red Off-Road DCSB M/T
    I never rely on / trust a vehicles computer to tell me what MPG the vehicle gets. It can't judge how much fuel has been burned, so it is only a best guess. I hand calculated for years, and have been using the smart phone app 'Fuelly' for a few years now. See my .sig below for my Tacoma's numbers.
    The very best my truck has ever gotten is around 19.5 MPG, and only when going long distances at a steady/constant speed for like 200+ miles at a time (eg: highway driving for long distances). And this is empty, not hauling or towing anything. Around town, I get maybe 16.0 MPG if I am really lucky.
    2017 Off Road, 4WD, manual trans, bone stock except for 32" tires (OEM were 30").
    Jwh4x4 likes this.
  16. Mar 16, 2022 at 9:06 AM
    #56
    mosccat
    Mark
    2020 OR
    I can get 11.4 towing a 4,700lb travel trailer!
    11.9 has to be more than just tires…
    Jwh4x4[QUOTED] and Chew like this.
  17. Mar 16, 2022 at 9:08 AM
    #57
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    Hey I now know what is pulse and glide hypermiling...
  18. Mar 16, 2022 at 9:16 AM
    #58
    Otterstuff
    Otterstuff Well-Known Member
    2022 White SR5 Access Cab 4WD V-6
    Tube steps, Vision Turbine wheels, bug deflector, seat covers, and tonneau cover
    I would try the KD Max Pro tune discussed in this forum. It can't hurt and the gas savings should help pay for it. That is terrible and dealers should help but do not.
    Jwh4x4[QUOTED] likes this.
  19. Mar 16, 2022 at 1:15 PM
    #59
    AxisCab
    AxisCab Well-Known Member
    Dave
    Bumville, or some dam place
    2018 2.7L 2WD Auto6, utility Axis Cab
    firewood scratches, Labrador hair/slobber, American flag sticker, Total Chaos bed stiffener, Scepter H20 can, onboard air
    desperately stock (tires, gears, lift...) I get 23 mixed city/hiway/dirt roads in every day life in my small town.
    driving uphill to the Sierra plateau for firewood, 19mpg one way
    driving downhill same exact route home, 31 - 33 w/ full load of wood
    Highway trips, it's easy to hit 25mpg. Driving back and forth from the desert, over the Sierras via Tehachapi to get to Bakersfield, 28mpg each way, going speed limit
    love that 2.7
    Junkhead likes this.
  20. Mar 16, 2022 at 2:09 PM
    #60
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    These trucks hate anything over 65mph for fuel mileage.
    mjam, Vmax540 and Junkhead like this.
