Gas Mixing????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Przemekmsu, Jan 18, 2011.
  1. Jan 18, 2011 at 10:25 AM
    Przemekmsu
    Przemekmsu [OP] Well-Known Member
    Przemek
    South Jersey
    2006 Toyota Tacoma, SR5 V6, 4x4 TRD Off Road
    K&N Air Filter, WickedFlow Exhaust muffler
    Is it OKAY to fill up your tank with Premium and then go back to Regular???? I would like to try to do some experimenting with it to see how our truck do with it. Have anyone tried it???? I know Tacoma calls for regular gas, but will it hurt to put the better stuff in it?????? Thanks
  2. Jan 18, 2011 at 10:37 AM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    It is perfectly ok to mix different octane. That being said you will not see any gains from only one tank of premium...the computer will revert to a different map to exploit the high octane, but it needs more than one consecutive tank to do so and will not stay that way unless you continue to run premium.
    Search yields lots on this topic...
  3. Jan 18, 2011 at 10:37 AM
    olgzr
    olgzr Well-Known Member
    Denton, Tx
    I've experimented with premium and regular on my taco with no problems. On my Miata, I did 5 tanks of premium followed by 5 tanks of midgrade then 5 tanks of regular. I did this all last summer as a gas mileage experiment to see if I got better or worse mileage with one grade or another. I saw no harm to either vehicle as a result of changing grades of gasoline.
  4. Jan 18, 2011 at 10:40 AM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    As everybody else has said, it will not hurt your truck at all.
  5. Jan 18, 2011 at 10:40 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    when you push the midgrade button..the pump dumps a 50/50 mix of regular and premium into the tank.
    it isnt a big deal.
  6. Jan 18, 2011 at 10:43 AM
    racerxtaco
    racerxtaco Well-Known Member
    Joey
    virginia
    01 xtra-cab 4X4 w/cap
    its perfectly fine to switch back and forth, however the benefits of one over the other generally depend on the habits of each specific driver. if you tow or haul a lot, you may want to step up the octane. give it a few tanks with each (maybe 10 tanks reg. then 10 tanks premium) and see if there are any differences. you may see a difference of 1-2 mpg. dont worry about doing any damage though with switching back and forth. also, try to stick with one brand of gas while doing the comparisons only because different make vehicles might prefer one brand of gas over another. they will each have a slightly different mix of detergents varying gas mileage. and one more thing, winter gas (in colder regions) will generally yield worse mpg number. hope this helped.
  7. Jan 18, 2011 at 11:13 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    What were the results with mileage?
  8. Jan 18, 2011 at 11:24 AM
    Trachito
    Trachito Well-Known Member
    New Orleans
    YOUR ENGINE WILL SET ON FIRE!! THEN YOUR GARAGE, AND THEN YOUR HOUSE!!!
    j/k
    bfeth likes this.
  9. Jan 18, 2011 at 11:27 AM
    SmilingMark
    SmilingMark Well-Known Member
    Mark
    Ogden, UT
    2010 Access Cab
    Color matched grill w/ grillcraft. BHLM and Morimoto Mini HID's Debadged.
    FYI, Tacoma calls for 87 octane or higher. Around here, that's mid-grade, regular gas comes in only at 85.
    I've run 4 consecutive tanks at both 85 then at 87. No statiscially significant mileage increase, but does seem to run smoother and more low-end power at less than 2K rpm.
    But no worries about damage, run whatever octane your wallet can afford.
  10. Jan 18, 2011 at 11:34 AM
    kris77
    kris77 Born in the Backwoods
    West Virginia
    08 DC TRD Sport Speedway Blue
    In channel Vent Visors, AVS Bug Shield, Hankook Dynapro RF10 265/70/17
    wow low grade here is 87 mid is 89 plus is 91 and supreme is 93
    Kinda weird. Not all places have 91. some skip from 89 to 93 and there is only a 10 cent difference. but most places skip from 89 to 91 with a 10 cent difference. So if you find the right station, you can get 93 for the same price as 91.
  11. Jan 18, 2011 at 11:37 AM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    I mix different grades all the time. I try to put the high octane in every couple fill-ups... during the summer when towing the boat I only use the good stuff. I also use the techtron gas additive on a regular basis. I've never noticed the engine knocking noise everyone speaks of here. Is it due to the gas or additive? Who the hell knows but I don't plan on changing anything to find out.
  12. Jan 18, 2011 at 11:51 AM
    jmg256
    Al Tonter
    TRD Offroad
    Engine knock and the "tacoma tick" are two total different and separate issues. I don't care to explain the difference right now.
    Engine knock is due to detonation, while "taco tick" has to do with emission systems and other mechanical movements in the engine. Search for further explanations.
    If you have true engine knock, than yes, an increase in octane can alleviate this. However, if your Tacoma is truly knocking or pinging, you probably have other issues than what octane you chose.
    Knocking is more common on higher compression engines.
    Another common misconceptionabout octane...the higher the number dies not equal more energy in the gas, but rather the resistance to detonation
    it's pretty complicated these days BUT, as a
    general guide, higher octane fuels have lower volatility (they
    evaporate slower).
    The octane rating is basically an anti-knock rating. Engine "knock" is also sometimes referred to as "ping". It is basically pre-detonation of the fuel before the piston is in the correct position (either near top of it's stroke or on its way down on the power stroke). Ping occurs while the piston is on the upstroke. Essentially, it is the elevated combustion cylinder temperature mixed with the now elevated cylinder pressure (compression) that will cause fuel it ignite without the spark.
  13. Jan 18, 2011 at 11:58 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Save your money and stick with what the owners manual says, if higher mileage were to be obtained with Premium Toyota would of advertized there truck with higher mileage figures as a selling point. my $0.02
  14. Jan 18, 2011 at 12:04 PM
    jmg256
    Al Tonter
    TRD Offroad
    All from this thread...http://www.tacomaworld.com/forum/2nd-gen-tacomas/108072-premium-gas-more-power.html
    Where is Chris? You guys believe him, right?
  15. Jan 18, 2011 at 12:09 PM
    OffroadToy
    4X4 Offroad
    Sorry...When I mentioned "knock" I was referring to the "tick"...I've never noticed either one.
  16. Jan 18, 2011 at 12:24 PM
    jmg256
    Al Tonter
    TRD Offroad
    Wasn't trying to bust your balls...
    Just trying to use clear, concise terminology to try to avoid confusion. Someone might read you previous statement and come to the conclusion that all new tacoma engines have a problem with detonation.
    One of the curses of doing a lot of technical writing, I guess... Terminology is everything when you are not there to clarify for those reading what you wrote. Just one of 'those things'. I notice every mis-spell and grammatical error too, can't help it.
    And again, just trying to be concise...not point out errors, or put anyone down. Just the way I was taught. Sorry
  17. Jan 18, 2011 at 12:26 PM
    olgzr
    Denton, Tx
    On the taco, I tried premium on a 900 mile highway trip that I had done several times using regular. I got slightly worse mileage, (.5) with the premium gas. On the 2006 Miata, the premium gave me 1 to 1.5 mpg worse on the highway and about .5 mpg worse around town. The midgrade and the regular both gave the same mileage.
  18. Jan 18, 2011 at 8:07 PM
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    Even the V6 taco's call for 87? I always thought it was higher, lol
  19. Jan 18, 2011 at 8:11 PM
    jmg256
    Al Tonter
    TRD Offroad
    Here is a sticky for you:D
    http://www.tacomaworld.com/forum/technical-chat/33253-minimum-octane-rating-gasoline-should-used-my-vehicle.html
  20. Jan 18, 2011 at 8:22 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    mixing grades can sometimes be a cheap way to get that 91 some cars call for when everyone always sells 89 and 93. The chemistry DOES work like that.
